I had the motor (rebuilt) replaced last year on drivers side power window because it would not go up all the way, all the time. 11 months later, I now can not move the window at all - I don't think motor is working - no noise when flipping switch. All other windows work without a problem
Could this be a problem with the motor again or possible fuse? Someone said that it's possible it coule be a fuse if there is a separate fuse for each window. Not sure if Toyota has that.
Any help would be appreciated. Don't really feel like spending another $300 to replace motor again. THANK YOU !
Friday, February 19th, 2021 AT 6:51 PM
(Merged)
