Fuel filter location
AW27932
  • 2001 DODGE STRATUS
  • 4 CYL
  • FWD
  • 96,000 MILES
Hey guys, I have a 01 Stratus SE 2.4l DOHC and I wanted to know if the fuel filter is IN the tank or is it just by the tank and around how much does a filter cost? Thanks for your help
Thursday, September 16th, 2010 AT 4:54 AM
The fuel filter is part of the fuel pump module. To remove the module you must first remove the tank, here's a guide and diagrams for this procedure
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Thursday, September 16th, 2010 AT 5:01 AM
AW27932
  • 6 POSTS
Hey rasmataz, I was told by a guy at AdvanceAuto today that they dont sell the fuel filter and that I would have to buy the fuel pump module and that is $214. I guess that new filters are in the fuel pump modules, is that right? Is there any other way of getting this done? If not I will have to get the module and about how long does it take to install the module?
Thursday, September 16th, 2010 AT 2:56 PM
Double check if its replaceable w/o the module, we talking about big time money on the module-see below
https://www.2carpros.com/forum/automotive_pictures/12900_fuel_filter_5.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_fuel_filter1_1.jpg
Thursday, September 16th, 2010 AT 5:36 PM
AW27932
  • 6 POSTS
From my understanding and from what the guy told me, he pulled it up and it had unserviceable and that I had to buy the module. Also he was telling me that alot of cars are going to that now.
Friday, September 17th, 2010 AT 8:59 AM
AW27932
  • 6 POSTS
Ok I just did some calling around. I was told by a guy at another AdvanceAuto that the pump just has a strainer and that again I would have to drop that tank and put it in.I called Napa and he looked it up and told me that it is just outside the tank and has quick disconnect hoses I believe he said.
Friday, September 17th, 2010 AT 9:18 AM
AW27932
  • 6 POSTS
Ok just returned from Shell station shop. The worker lifted my car we searched and searched and could not find any type of filter outside of the tank. So does that mean the filter is INSIDE the tank and how would I go about getting a filter unless its the one that the guy at Napa showed me but it has some quick disconnect hoses and some type of mounting bracket. Is the strainer the guy from Advance told me considered the fuel filter? I dont know.
Friday, September 17th, 2010 AT 12:17 PM
MULDOON
  • 79 POSTS
I replaced mine on my 1996 Stratus 4 cyl 2.4 l, it was on top of the fuel tank I had to lower the tank, not all the way and then replace, check edmunds book first, make sure tank has little gas, good luck, Declan.
Tuesday, September 21st, 2010 AT 3:28 AM
AW27932
  • 6 POSTS
Hey did it have quick disconnect hoses on yours? I'm thinking mine is different being that I have an 01.I'm going to try and get someone to lower my tank and see if it is there or actually in my tank and if so I will have to get the feul pump module.
Tuesday, September 21st, 2010 AT 12:53 PM
MULDOON
  • 79 POSTS
I believe it had but am not sure, anyway why do you need to change the filter, also get that edmunds book, I like the guys at advance but that book does not lie, sometimes I call a Chrysler dealer and ask to speak to a mechanic, tell them you are a mechanic also but are wondering if there is a short cut, good luck Declan.
Tuesday, September 21st, 2010 AT 7:14 PM
JG_8MAN
  • 6 CYL
  • FWD
  • MANUAL
  • 85,000 MILES
I am wondering where the fuel filter is located on this car and how much mechanical skill is required to replace it. I am in Europe and would like to change it out myself but I don't have access to a garage so any help would be greatly appreciated. Thanks
Jason
Monday, August 6th, 2018 AT 12:56 PM (Merged)
ZACKMAN
  • 4,202 POSTS
You have a fuel strainer at the end of the fuel pump assembly. Replacing the strainer requires dropping the fuel tank down, removing the fuel pump assembly, prior to getting to the strainer filter. It is not advisable to perform the work without a garage, in my opinion.
GRNEYEDKAT
  • 1998 DODGE STRATUS
Where is the fuel filter located on the 98 Dodge Stratus ES
MIKEYBDMAN
  • 623 POSTS
The fuel filter mounts to the frame above the rear of the fuel tank. Here is a guide to show you what yoo are in for when doing the job.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Here are diagrams (below) showing the fuel filter location on your car
Cheers
SCHUYLER WRAGGE
I have a 98 dodge stratus and need to know where the fuel filter is and if it is something my dad could fix?
CARADIODOC
  • 33,742 POSTS
I can add that except for diesel engines, unless the fuel filter is rusted and leaking, you will never solve a running problem on a Chrysler product by replacing the fuel filter. They commonly last the life of the vehicle.
BRINLY
  • 2000 DODGE STRATUS
2000 Dodge Stratus 6 cyl Two Wheel Drive Automatic
Where is the fuel filter located on a 2000 Dodge Stratus?
Fuel Filter
https://www.2carpros.com/forum/automotive_pictures/12900_ff_24.jpg
Fuel Pump Module/Fuel Filter
https://www.2carpros.com/forum/automotive_pictures/12900_ff1_6.gif
FRANK TAYLOR
  • 6 CYL
  • FWD
  • 109,000 MILES
BLUELIGHTNIN6
  • 16,542 POSTS
Fuel filter is located on the frame, above rear of fuel tank. Fuel tank must be lowered for access to fuel filter. Fuel lines are permanently attached to fuel filter.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_55.jpg
Need removal and installation instructions? Just ask and you shall receive.
Thanks for using 2carpros.com!
MSEGOVIA
  • 1997 DODGE STRATUS
Where is the fuel filter on this vehicle?
