Engine Overheating?
TEXASMOON39
  • 2001 CHRYSLER SEBRING
I have a 2001 Chrysler Sebring LXi 4 door Sedan (2.7L 6 cylinder 4A). It is overheating. The thermostat has been changed, the hoses are not clogged or leaking, radiator cap is in good condition, no noise coming from the water pump, no water in the oil, But when we try to add water/coolant, the engine wont take it. It wont suck the water in through the motor. The water is blowing out all over my drive way and is overheating.
My questions to you are:
Why will it not take in water?
Does the water pump have to make noise to be bad?
By the way it has 120,000 miles. Please help.
Thank you in advance.
PS: This will be the last Chrysler I buy.
Wednesday, February 21st, 2007 AT 10:47 PM
  • 108,192 POSTS
Overheating can be caused by a few different things. First, I noted that you replaced the thermostat. Was the system flushed when you had the coolant removed? If not, that would be the next step. Here is a link that shows how that is done:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Also, if you are trying to add coolant and it won't take any, it may simply be full. When the engine is cold, open the radiator cap and check level. If it is full, start the engine and see if it drops. If it does, and it then. Make sure the overflow reservoir is at a proper level as well.
After it is filled and the cap is still off, allow the engine to warm up for two reasons. First, confirm that the level doesn't drop any further and second when it hits operating temp, you should be able to see the coolant flowing through the radiator. Note that when you fill the radiator, make sure the heater is on high to ensure the heater core is full as well. If there is no heat, then either the core is plugged, there is air in the system, or there is no circulation of coolant.
To answer a specific question you asked, the pump does not need to make noise to be bad. It can, but often times it will develop a leak through what is called a weep hole. See pic 1
Here is a link that you may find of interest and helpful. It discusses common symptoms of a bad water pump.
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
One last thought. If everything above shows normal, then we need to check if there is an issue with a head gasket. Take a look through this link. It explains how to determine if that is the issue.
Here is something I want you to try as well. With the engine cold, remove the radiator cap and start the engine. Does coolant shot from the radiator or leak out rapidly? If it does, then we have compressed air entering the cooling system most likely the result of a bad head gasket.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Wednesday, March 25th, 2020 AT 8:39 PM
TDELPHONSE
  • 2000 CHRYSLER SEBRING
  • 4 CYL
  • 105,000 MILES
Five days ago my AC went out - the fan was blowing but it was not cooling. Now my engine is overheating and I do not think that the engine fan is working. The thermostat is fine. Is it possibly a fuse? What is the issue?
Thank you
Saturday, September 26th, 2020 AT 10:14 AM (Merged)
  • 108,192 POSTS
Hi:
Does the engine overheat at highway speed? Also, make sure the belt hasn't come off the AC.
TDELPHONSE
Thank you for responding - Actuallly, we have found that the Fan motor was not operating and got a used replacement. It worked when tested at the shop, but does not seem to be working when we put it in the car. Is there a possibility of an electrical problem?
Thanks,
TDelphonse
  • 108,192 POSTS
Hi:
The temp sensor sends a signal to the computer and the fan relay which inturn starts the fan. Have you check the relay or temp sensor?
LILBMF
  • 8 POSTS
  • 6 CYL
  • 115,000 MILES
I have a 2000 seabring. Last year my car ran hot in the summer. This summer the same thing. Only differance is that this year it boiled out of the overflow tank. Since then I have replaced temp sensor, thermostat, dipped the radiator and flushed it, replaced hoses, the fan works like it should, and had a pressure test done to it with the results of no leaks. The car still runs hot. It takes about 15 min driving, and longer when just sitting there parked(like when I was burping it) I replaced the radiator cap and the one to the overflow tank. At the shop they tried to do a block test I think it was called, but the car kept burping water up so they couldnt do it. The reverse test came back fine. The water pump is not leaking and I am not looseing fluid. Any ideas on that is some other possibilities? The radiator looks fine also. Was told last year after the dip that wasnt the problem. Could it be that part of my skid guard is missing?
Saturday, September 26th, 2020 AT 10:15 AM (Merged)
AUTOKARMA
  • 13 POSTS
Sounds like the same problem I am having with my 2000 JXi. The water overheats and overflows from under the radiator cap. Had a new radiator installed, engine gaskets changed, new transmission gaskets, but still it does the same overheating thing. Have you found out what your problem was, and how was it fixed? Please help! Thanks. Now it's backfiring too! What else?
DJCL
  • 767 POSTS
You need to have the head gasket checked. Either with a block test or exhaust gas analyzer. Befor the coolant backs up do the block test or have a gas analyzer sniff the coolant befor the back up.
AUTOKARMA
  • 13 POSTS
Just had the head gasket fixed, all gasket replaced and block was Tooled and all
put back together. Then backfiring started! How would coolant get into the gas? Is that what this gas analyzer is for? Could it be something simpler?
DJCL
  • 767 POSTS
Exhaust gas can be getting in to the coolant. The gas analyzer will check this
CANAAN
Heater problem
2000 Chrysler Sebring 6 cyl Four Wheel Drive Automatic
My car keeps overheating. Friends said it could be heater core because it's leaking fluid under the passenger dash board. I replaced the thermostat.
If there's a leak on the heater core the engine will overheat its losing coolant. You sure its not a clogged-up AC drain tube
CANAAN
If you will, could you tell me where to look for the AC drain I took out the heater core yesterday night. There were two tubes connected, one actually said heater on it and i'm not to sure what the other one was, i'm guessing it was for the AC. Thank you for your time
The 2 heater hose goes to the heater core in and out-the coolant has to go back to the engine. As for the AC drain tube dunno where it is-
CHARMY3743
  • 6 CYL
  • 15,000 MILES
Car overheated as I was on the highway driving. I took it to a mechanic and said that needs timing belt and water pump and radiator. With labor is 1200. Is it comparable to most places? Just wonderng. Thanks
  • 108,192 POSTS
First, all of those things don't go bad at the same time. As far as the price, it's not bad. But does it need everything? Is the water pump leaking? I want to explaine something. First, if you replace the water pump on this engine, it is a good idea to replace the timing belt too, so I can understand where he is coming from there. However, if there is no leak from the pump and it isn't making noise, chances are it is fine. He can't see through the aluminum housing to determine if that is the problem. The radiator, on the other hand, may need replaced or may just need flushed. It could also be a 5 dollar thermostat that has gone bad.
Has he been able to justify why everything needs replaced? Was the radiator leaking? Was the waterpump leaking or making noise?
LILBMF
  • 8 POSTS
  • 6 CYL
  • 115,000 MILES
My 2000 seabring hardtop 2.5L runs hot, at the h, during the summer. Until this week it has never boiled over. This time it boiled in the overflow tank. I have changed the radiator hose, thermostat, hoses, flushed radiator. I can see water movement when it is running, and no milky substance in the oil, I made sure that there was not air bubbles 3 times. Replaced the temp sensor. It still goes to the hot line. It heats up to the half way mark right after starting engin for first time. What else can cause it to run hot? My overflow tank has a crack on the peice the hose conects to going into the tank its self. Could that cause it? Or am I over looking something.
If it stills overheating with all that replacement stuffs/checks-time to block and pressure test it-could be a blown headgasket, cracked head or block, and intake
LILBMF
  • 8 POSTS
IS THERE ANY WAY TO DO THAT MYSELF OR DOES IT HAVE TO GO TO THE SHOP AGAIN. AT THIS POINT I AM PRETTY TIGHT ON MONEY WITH ALL OF STUFF I PAID SO FAR
You can get the block and cooling system pressure tester at the major parts store and DIY
