Problems with 4X4 not working?
STEELER_NUT
  • 1998 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 10,800 MILES
I noticed another guy on here having the same problem with his 4x4 not working. Light doesn't come on on shifter put shifter falls into each position just fine, but still No 4x4 working, you mentioned to him souds like the actuator is weak and is not fully engaging your four wheel drive, My question is: Can this actuator be easly replaced without taking it to a professional?
Thanks
Noel
Saturday, December 15th, 2007 AT 7:29 PM
DENNYP
  • 1,823 POSTS
Yes you can replace the actuator yourself here is a diagram to help you get the job done. The actuator encoder as they call it is on the side of the transfer case.
Check out the diagrams (Below)
Cheers
Sunday, December 16th, 2007 AT 7:48 PM
98 CHEVY
  • 3.7L
  • V8
  • 4WD
  • 209,000 MILES
How do you engage the four wheel drive? Does it have to be in neutral and drive or do you start it off and drive or put it reverse? I have heard all kinds of different subjects on how to engage the four wheel drive and then how to disengage the four wheel drive. It is a very old truck listed above (Z71). I would really appreciate your help, thank you.
Wednesday, September 2nd, 2020 AT 10:48 AM (Merged)
STEVE W.
  • 13,002 POSTS
First 1998 is not very old.
Second, that should have shift on the fly in it. That means it has an inter axle disconnect in it and you can shift between two High and four High without stopping. You pull the lever or push the button and the transfer case will shift into four high and the front drive shaft starts moving. At the same time there is a switch that activates the front axle interlock. This moves a collar that locks the right hand axle together and you are now in four wheel.
To shift into four low is different. You cannot shift into that on the fly. You have to stop, put the transmission into neutral, shift into four low and then shift into drive/reverse. Reverse the process to go back to four high or two high.
DANAAT2610
  • 5 POSTS
  • 5.7L
  • V8
  • 4WD
  • 170,000 MILES
I have a 1998 z71 4wd truck that I have owned for 10 yrs. I recently replaced the trans and it works fine, but the 4wd doesnt engage. I have replaced the actuator on the front transfer case. I read the power to that plug and had 12 volts. The lights on the 4lo/hi switches blink. I have checked the fuses (2). Not sure where to go next. Money is very tight.
HMAC300
  • 48,601 POSTS
Have it scanned for codes auto parts can do for free
DANAAT2610
  • 5 POSTS
Thanks very much. Wish I could take to a shop but not possible now thanks again
CGUNDERSON
  • 5.7L
  • V8
  • 4WD
  • 130,000 MILES
When I start the truck two wheel drive light is lit up. When I push the four high button it will flash and go off. Do not hear or feel the transfer case engage. I hooked a jumper up to check for codes and there are none. Any advise?
Wednesday, September 2nd, 2020 AT 10:49 AM (Merged)
CGUNDERSON
We have now changed the tccm on the transfer case and still does not work
HMAC300
  • 48,601 POSTS
You cannot jump anything to read codes a scanner would be needed for this. Put old tcm back in if you have it and check to see if power is going to encoder motor on tcase. Check fuses where shown in pic and also check to see if encoder motor is getting power and working. Finally check switch on tcase where arrow is to see if that is working.
PAUL PLONKA
  • 1997 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 155,000 MILES
4x4 will not engage
  • 108,269 POSTS
Do you have a manual shift 4wd or electric?
WJC1973
  • V8
  • 4WD
  • 100,000 MILES
97 chevy 1500 4x4 does not engage. Replaced acuator still nothing. Light comes on but front wheels don't pull.
  • 108,269 POSTS
Make sure you are getting power to the actuator. Check the actuator on the front axle.
TONY E HILL
No power to actuor I replaced switch in cab still dosnt work is their a fuse inline ihave checked all outher fuses
  • 108,269 POSTS
I attached a wiring schematic for the transfer case electrical. Take a look and see if it helps.
LHAMMO
  • V8
  • 4WD
  • 23,100 MILES
I have a 97 chevy 4x4 that the 4-wheel drive want engage. It has a manual shifter. The transfer case will engage but the front tires will not lock in. It made no noise when it quit. I went to use it and it wouldn't engage.
BEN BAUERLE
Have you replaced the front diffs actuators if not replace it and it should work like new I had the same issue with mine that should solve your problem
DARRELJONESK9
  • 1996 CHEVROLET SILVERADO
  • 5.7L
  • V8
  • 4WD
  • 188,000 MILES
I have a 1996 chevy z71 4x4. When I try to switch it to 4wd the little flashes on 4hi. It does engage but the light keeps flashing. I took it to the dealer and they pulled the dash and replaced the things under there. I have no clue on the names of the parts but they said they replaced everything under the dash. They also replaced some sensor on the transfer case. Still does the same thing. What else could be the issue. Transmission is new. The dealer said it could be up to 1500 dollars to get it to work. Any ideas would be helpful. I have dumped over 4000 dollars into this truck.
HMAC300
  • 48,601 POSTS
Unfortunately you 'll have to have it scanned for codes, any garage can do which are cheaper than the dealer. It may be the encoder motor on tcase or a wiring issue but it needs to be scanned first to see what code it is.
DARRELJONESK9
I did have them check for codes. Nothing showed up. So they told me it could be the actuator or transfer case motor or 4wd module. Went to parts store and they said they show no 4 wd module for that year of truck.
