What Is The Easiest Way To Complete An Engine...
I Have An Engine Replacement Coming Up Soon On The Vehicle Listed Above 3.2 And I've Been Searching Forums And Trying To Figure Out The...
Kingjd123
AUDI Q5
Wipers Not Working?
I Have No Wipers, I Have Checked All Fuses, Relays, Replaced Ign Switch. I Have No Voltage At 20-amp Fuse On Left Side Of Dash. I Have...
easyrider8700
Car Not Starting?
I Had A Weird Situation Going About My Day, I Went To Cut My Car Off And It Started Screeching When I Did. Now It Won’t Start Anymore…...
Thatredneckmechanic
No Crank No Fuel Pump Both Test Good
I Bought This Car At An Auction Had A Key Made For It But The Bushes Didn't Work. It Would Show Hot On The Temp Gauge But Be At Normal...
Lenny reinke
CHEVROLET MONTE CARLO
Keep Blowing Fuse?
The Fuse Listed As Efi Or Ecd No. 2 That Is Located On The Fuse Block Inside The Vehicle And Adjacent To Left Foot. It Is A 10a Fuse....
File Guy
TOYOTA LANDCRUISER
Oil Sludge Possibility?
Hello. I Recently Just Got My Oil Changed About Two Weeks Ago. When I Got It Changed The Guy Said There Was No Oil That Drained From My...
pnipper29
NISSAN VERSA
How To Remove Garnish Panel From Rear Hatch Door?
The Rear License Plate Lamp Melted On The Left Side; The Right Side Is Still Good. Purchase Oem Replacement Which Is 2 Lamps With Harness....
avecchio946
HYUNDAI SANTA FE
Engine Replacement?
Kingjd123
42 IMAGES
AUDI Q5
Makes Clicking Noise On Deceleration
When Slowing Down Without The Brake A Loud Clicking Noise Can Be Heard From Under The Car Close To Were The Passengers And Drivers Feet Are...
Cam Cruz
INFINITI FX35
Oil Type Needed For Oil Change?
Hello, I Have The Vehicle Listed Above That Needs An Oil Change, The Odometer Shows A Milage Of 101,000 Miles. The Motor Shows That It...
Hasan Ramadan
HONDA CRV
Oil Change
Hello, I Have My Honda Crv 2013 That Needs An Oil Change, The Odometer Is Showing A Milage Of 101,000 Miles. The Motor Shows That It Needs...
Hasan Nemeh Ramadan
HONDA CRV
Oil Change
Hasan Nemeh Ramadan
HONDA CRV
License Plate Lights Not Working?
For Some Reason Both Of My License Plate Lights Are Out. I Have Replaced Both Bulbs And Checked All The Fuses, But I Still Don't Have...
Jfullhart
CHEVROLET CRUZE
Front Right Signal Light Is Not Working?
I Have Replaced The Bulb, But Not Successful. What Can Cause That Problem? I Checked The Socket, It Was Fine. Footwell Module Have Some...
tadayyon1
BMW X5
Codes P1174 And P1175, Vacuum Leak?
While Checking For A Vacuum Leak Using A Smoke Machine. While Running The Smoke Though The System I Noticed Smoke Was Coming Out Of The Oil...
Crzyfo0
GMC ACADIA
After Replacing The Starter And Putting It Back...
Installed A New Starter. Hooked Up The Battery Cables And Everything Started Smoking. What's Causing This?
jwillbigred
ACURA TL
Starter Installation, Wiring Diagram Needed?
I Was Replacing My Lower Intake Manifold Gasket On My Car Listed Above Sfi And Someone Took My Starter. I Bought A New Starter For It, And...
EddieHensley
BUICK CENTURY
Car Start Then It Dies, Turns Off
Since I Changed Sparks Plugs, Wires, The Fuel Injectors, Fuel Throttle Censor, Basically Re-did Motor N Had Transmission Re-done It Will...
Edgar Viramontes
A/C Blower Fan Intermittently Turns On/off But Mostly...
Hi, The A/c Fan Blower When Switch Is Turned On 1 To 4, Sometimes It Turns On But Most Of The Time It Does Not. It Does Not Matter Any...
plagooms
KIA PICANTO
We Tried To Start It, It Would Not Turn Over?
I Drove My Van From Tennessee To Georgia On 5 Cylinders To Help Get It Fixed, It Drove Fine That Night But The Next Morning When We Tried...
Nicole Helms
Code P0976?
Can You Please Send Me The Wiring For The Truck Listed Above, 2-3 Shift Solenoid Valve Control. I Got The Code P0976; What My Truck Is...
Andrew Vincent William Thomas
Battery Won't Keep Charge
Replaced Battery, Alternator, Starter, And Both Cables. This Has Been Going On For 3 Weeks Now And It's Getting Frustrating To Me...
MrandMrsblizzard
DODGE INTREPID
Battery Drain?
I Replaced The Battery, Starter, Alternator And Actually Changed The Positive And Negative Cables About 5 Months Ago. For About 3 Weeks...
MrandMrsblizzard
DODGE INTREPID
How Many Catalytic Converters Does This Vehicle Have?
I'm Trying To Find Out How Many Catalytic Converters My Car Has.
alyssaharvey528
PONTIAC VIBE
Will Not Stay Runnung?
When Attempting To Start The Vehicle, It Will Turn Over For Just A Few Seconds And Stops. You Can Hear The Fuel Pump Running. Never Had Any...
fireguy5
TOYOTA PICKUP
687
688
689
