Turn The Key And Get No Crank No Start?
Once The Starter Switch Is Installed, The Truck Will Start With The Key In Switch. It Has Good Battery And New Starter, And The Starting...
dodgeschick
Cylinder 3 And 4 Miss
I Got A 02 Sonoma V6 4.3l Thats Got Cylinder 3 And 4 Misfire. I’ve Replace Injectors, Maf, Plugs, Wires, Cleaned Cap And Rotor Points...
Cli3200
GMC SONOMA
How Many Catalytic Converters?
How Many Catalytic Converters Does A 2019 F150 5.0l V8 Truck Have? Thanks
Nathan Jahns
Transmission Swap?
I Have A 1987 Gmc 1500 With Th400 Transmission With No Governor On Side Looking To Replace It With A The Th400 With The Governor Cover And...
Carl Macallister
Cranking Issue With Rough Idle?
The Car Acted Like It Had A Drained Battery. Checked The Positive Terminal It Was Loose, Terminal Wouldn’t Tighten, So I Replaced...
TaylorO
KIA SOUL
Shuddering While Shifting And Weird Pinging Rattle...
When I Push The Gas Pedal While Coasting It Rattles And It Affects My Acceleration. And When Getting On Freeway And Shifting From 3 To 4...
Tyler Chamberlin
Engine Shutting Off?
Okay, Try To Figure This One Out. This Thing Started When You Put It In Reverse It Would Shut Off Not All The Time. When It Did It Would...
Randy1955
Timing Belt Marks Needed?
Marks.
Lal sidhu
MITSUBISHI GALANT
Codes P0072 And P2503?
Those Two Codes Came Up On. My Car Listed Above The Other Days. One Says Charging System Low And The Other One Says Ambient Air Temp Sensor...
Rachelkristina7787
MERCEDES BENZ C250
Replaced Blend Door Actuator?
I Bought This Vehicle A Couple Weeks Ago Air Conditioner Worked Great But Absolutely No Heat. I Heard The Blend Door Actuator And Then I...
Jennifer Rolf
Codes P025c, P300, P301, P302, And B210068, Misfires?
Has Codes: P025c P300 P301 P302 B210068 I Am Leaning Toward A Fuel Problem.
MERCEDES BENZ C250
Transmission Completely Blinding Out?
Okay. So, I Bought This Vehicle Listed Above Probably About 4 Months Ago. It Seemed Like It Was Going To Be A Pretty Good Car, It Seemed...
Dicksonred2
LEXUS ES 300
1989 Chevy S10 Durango 2.8ltr
Won't Idle Lost Power Have To Pump Accelerater Fast To Keep It Running Dies When I Put It In Gear And Backfires Through The Carburetor...
T-bone Taylor
All Brakes Gradually Lock Up As You Drive?
I Have The Car Listed Above That Has Front Disc Brakes And Rear Drum Brake. I Replaced The Rear Drum With Disc Brakes Along With A New 1 1/8...
Donald Oglesby
1970
OLDSMOBILE CUTLASS
Code P1775, Jerks When Coming To A Stop?
I Was Having Trouble Shifting From 2nd To 3rd With Codes P0841 And P0700. I Ended Up Replacing The Solenoid Pack With New Atf+4 Fluid And...
austin501011 l
CHRYSLER CONCORDE
P1775
Hello, This Will Be Long So Bear With Me. I Have A 2003 Chrysler Concorde And Originally I Was Having Trouble Shifting Out Of 2nd Into 3rd...
austin501011 l
CHRYSLER CONCORDE
Rumbling, Vibration, Alignment Goes In And Out?
Hello, My Car Listed Above Airmatic Started Acting Up At Mostly At Highway Speeds. My Alignment Was Done A Week Ago And Had All Wheel...
Genesis88
MERCEDES BENZ E320
Transmission Issues With Fault Codes
It Threw P0740, P043, P0750, P0753, P0755, P0758, P1747, P1754, P01760. It Was Running And Drive Great Yhen Came Out Store Got In Started...
Tj Bell
Tj Bell
Tj Bell
Sputtering When Starting And Idling?
When I Start The Vehicle It Sputters, And I Have To Keep My Foot On The Gas And Brake When I Come To A Stop Light Because It Wants To Stall...
Charlani
JEEP LIBERTY
Over Charging Alternator When RPMs Are Around 3,000...
The Charge Voltage Increases To Around 18vdc When The Rpms 3,000. It Does Not Stay At 18v For Long, Usually Drops Back To Around 14 When...
SCXJ
Fuel Pump Color Code Wiring Diagram Needed?
I Dropped My Tank And Didn't Unplug The Wiring Harness And All The Wires Come Out Of The Plug And They Were Two Different Colors On Each...
Robert 4×4
MAZDA B2600
Starting Issue?
The Car Has Power, And All The Lights And Indicators Are Coming On. But It Won't Turn Over. I Have Replaced The Battery, Starter (...
MazdaMan96
MAZDA 5
Shuts Off While Driving?
Car Stops While Driving And Also Doesn't Start Up Unless You Push It.
Brianjrosejax
LINCOLN TOWN CAR
679
680
681
