Brake Pedal Goes To The Floor?
I Replaced The Mater Cylnder Due To Having No Brake Pressure And After Replacement I Bleed The Brakes 4 Times To Make Sure All The Air Is...
e46kid
CV Axle Replacement?
So, I'm Trying To Replace My Cv Axle But There Is A Part I'm Seeing On Other Cv Axles That Mine Does Not Have, And I Am Trying To...
zlilleodden
CHEVROLET VOLT
Windshield Wipers Not Working, There Is A Clicking...
Whenever I Go To Use The Front Windshield Wipers No Windshield Wiper Fluid Comes Out And The Wipers Themselves Make This Horrible "...
wakingdd14
A/C Air Not Flowing Correctly?
I Was Having Problems With My A/c Only Blowing Through The Bottom Vents At The Feet. I Have Replaced All Actuators And Still Only Blows At...
Yeezus00
INFINITI G37
After Replacing The Brakes, The Brake Pedal Still Goes...
I Recently Replaced My Brake Calipers And The Pads And Today I Replaced The Master Cylinder. However, My Pedal Is Still Going To The Floor...
Melissa Acosta
JEEP PATRIOT
Left Rear Parking Lights Are Not Working?
The Left Rear Parking Lights Are Inop. I Request A Wiring Diagram. Thank You.
pmech
Grinding When Turning Left?
I Have The Truck Listed Above Lariat (non-heritage). This Is A Problem I Have Been Fighting For A While. I Get A Sound That Sounds Like...
JasonNailen
Shut Off While Driving And Will Not Start?
I Was Driving To The Store And Got About A Half Mile From My House And The Car Quit Running. It'll Turn Over But Will Not Start Back Up...
TonyCG72
SATURN ION
Front Driver Side Tire Hard To Spin, Bearing Hub?
The Front Driver Side Wheel Is To Spin When The Vehicle Is Off Ground. Replaced Caliper, Rotor And Brake Pads And It Still Hard To Spin By...
chrisbuckley110
Strange Metal Grinding/rattling Noise While Driving?
While I Am Driving And Only Accelerating Above 50 Mph, There's A Metal Rattling/grinding Noise That's Loud And Lasts About 3...
illeromm
Do You Have An Engine Replacement Video?
Faulty Engine And I Was Wondering If You Have A Video Showing The Replacement Of Engine. Thank You
Monty Poonia
NISSAN NAVARA
Code 82, No Spark?
Brand New Distributor. Brand New Coil. But I Cannot Get An Rpm Signal To The Ecm. Tried Also Replacing Ignition Control Module And Still No...
William Jarman
GMC TRUCK
Ticking Sound After Engine Has Warmed?
A Tick Like Dead Cylinder Tick. Good Compression, Getting Fuel, Spark Plug Wires Work, Plugs Look Good, No Codes, No Exhaust Leaks. It...
Cowboycadi
CADILLAC ESCALADE EXT
Not Charging At All?
This Is Going To Be A Little Bit Of A Long Question But I'm Starting From The Beginning About 2 Weeks Ago Driving My Truck And It Had...
sgironer
Spark Plug Replacement
Intermittently Drive Rough. Check Engine Light Came On. Code Register P0307, Bad #7 Plug Or Wire. Can I Get By Replacing #7 Only Or Should...
steve brodie
LINCOLN NAVIGATOR
Replacement Part For Turn Signal Lever?
The Multifunction Lever That Controls Turn Signals And Stuff Broke And I Need A New One, But Am Unsure What Years Of Other Deville's I...
Shmeliodas
CADILLAC DEVILLE
Bucking/jerking While Accelerating Unless Using Cruise...
I Think Something In The Transfer Case Is Messed Up, But This Is My Second One In This Car. 4x4 Might Be Engaging While I'm Driving...
Miles Szabo
FORD EXPLORER SPORT TRAC
The Car Bucks And Jerks Very Violently When You Accelerate Using The Gas Pedal, But Very Inconsistently. I Am Losing My Mind Trying To...
Miles Szabo
Miles Szabo
Cannot Get The Control To Change From Heat To Foot Or...
Nothing Is Working Although I Replaced It.
TheElder
CHEVROLET VENTURE
Transmission Removal, What Is The Best Way To Remove...
I'm Trying To Drop The Transmission And Need To Know The Best Way To Remove The Top Bolts.
AngelaFaith22
When I Get To Around 50 Mph I Will At Times Get A Very Rough Idle. Somtimes When At A Complete Stop. Check Engine Light Came On. I Ran Code...
steve brodie
LINCOLN NAVIGATOR
Codes C1632 And C3537?
2 Codes In The Car. C1632 And C3537.
kkellie88
DODGE JOURNEY
What Is The Best Coolant To Use?
Just Looking For What's The Best Coolant To Use In These 4.6 L.
Videogamer88
FORD THUNDERBIRD
Transmission Shift Issues?
When Driving The Car It Would Shift 1st 2nd And If You Are Passing A Car, It Would Stay And 8,000 Rpms And Not Shift And That Happen When I...
Ashes22
TOYOTA CAMRY SOLARA
658
659
660
20259
