Ticking Sound After Engine Has Warmed?
A Tick Like Dead Cylinder Tick. Good Compression, Getting Fuel, Spark Plug Wires Work, Plugs Look Good, No Codes, No Exhaust Leaks. It...
Cowboycadi
CADILLAC ESCALADE EXT
Not Charging At All?
This Is Going To Be A Little Bit Of A Long Question But I'm Starting From The Beginning About 2 Weeks Ago Driving My Truck And It Had...
sgironer
Spark Plug Replacement
Intermittently Drive Rough. Check Engine Light Came On. Code Register P0307, Bad #7 Plug Or Wire. Can I Get By Replacing #7 Only Or Should...
steve brodie
LINCOLN NAVIGATOR
Replacement Part For Turn Signal Lever?
The Multifunction Lever That Controls Turn Signals And Stuff Broke And I Need A New One, But Am Unsure What Years Of Other Deville's I...
Shmeliodas
CADILLAC DEVILLE
Bucking/jerking While Accelerating Unless Using Cruise...
I Think Something In The Transfer Case Is Messed Up, But This Is My Second One In This Car. 4x4 Might Be Engaging While I'm Driving...
Miles Szabo
FORD EXPLORER SPORT TRAC
The Car Bucks And Jerks Very Violently When You Accelerate Using The Gas Pedal, But Very Inconsistently. I Am Losing My Mind Trying To...
Miles Szabo
Miles Szabo
Cannot Get The Control To Change From Heat To Foot Or...
Nothing Is Working Although I Replaced It.
TheElder
CHEVROLET VENTURE
Transmission Removal, What Is The Best Way To Remove...
I'm Trying To Drop The Transmission And Need To Know The Best Way To Remove The Top Bolts.
AngelaFaith22
When I Get To Around 50 Mph I Will At Times Get A Very Rough Idle. Somtimes When At A Complete Stop. Check Engine Light Came On. I Ran Code...
steve brodie
LINCOLN NAVIGATOR
Codes C1632 And C3537?
2 Codes In The Car. C1632 And C3537.
kkellie88
DODGE JOURNEY
What Is The Best Coolant To Use?
Just Looking For What's The Best Coolant To Use In These 4.6 L.
Videogamer88
FORD THUNDERBIRD
Transmission Shift Issues?
When Driving The Car It Would Shift 1st 2nd And If You Are Passing A Car, It Would Stay And 8,000 Rpms And Not Shift And That Happen When I...
Ashes22
TOYOTA CAMRY SOLARA
Misfire On 2000 Ford Crown Victoria Lx
I Still Have A Misfire After Replacing Spark Plugs, Coil Packs, Fuel Injectors And Air Intake. Also New Maf, Egr Valve And Pressure/...
Richard Hough
FORD CROWN VICTORIA
Shuts Off While Driving?
I'll Be Driving Then The Car Will Stop Running. I Will Have To Wait A While For The Car To Start Again, It Always Happens When I Have...
Reuben Humphery Van Kempen
Reverse Lights On With Headlights, But Not In Reverse?
Earlier Last Year I Replaced The Stock Headlight And Taillight Assemblies With After Market Equipment As Well As Installing A Backup Camera...
Gareth Owings
DODGE MAGNUM
Stuck In Neutral
I Turned On My Car Put It Down To Drive And Accidentally Put It On The Last Gear Then Back To Drive And It Went Into Neutral. I Then Put It...
Gigglez420
No Start. Getting Fuel.
Cranks Will Not Start. No Spark. Where Is The Second Crank Sensor Going To The Icm. Getting Power To Module.
Tamara Bates
PONTIAC AZTEK
A/C Not Working Properly?
Hello, On A Hot Day Starting The Vehicle And Putting The A/c On Max It Does Not Blow Cold While The Vehicle Is Parked But Once I Start...
beetlepunk21
Crank No Start, Not Getting Fuel To The Fuel Rail?
About A Week And A Half Ago I Was Driving, And My Car Shut Off On Me While I Was Driving And Ever Since Then The Car Would Not Start. My...
2JZLexus
LEXUS IS 300
Someone Tried To Steal The Car And Broke The Ignition?
So, The Other Night Somebody Tried To Get In And Still My Car And Broke The Ignition Including Copper Wire That Connects To The Amplifier...
Dicksonred2
LEXUS ES 300
Driver Side Coolant Transmission Line
I Purchased A Doorman Driver Side Coolant Transmission Line Part Number 624-351. My Question Is Do I Need Doorman Line Connector Part Number...
Nibs5800
Issues With Driving Faster Than Five MPH, Transmission...
I Have The Car Listed Above, Its Having Problems Driving Faster Than 5 Mph, It Makes A Clunk When Putting It From Park To Rev And Sport...
Patyonemura80
4L60E Issues
My Husbands 05 Chevy Silverado 1500’s Pulling 2 P0700 Codes (transmission Malfunction). It’s A 4l60e Transmission. He Put It In A Ditch...
Dumbcargirl122
New Off-road Bumper Options?
While Researching Off-road Bumper Options For My Truck Listed Above, I've Noticed That Quality And Extra Features Are Critical. Can I...
MartinLemons
TOYOTA TACOMA
659
660
661
20259
