Vortec 350 To 454 Vortec Swap?
I Have Done Most Of The Hard Part On This Swap, I Took A 454 From A 1996 Gmc Suburban 2500 (2wd) And Successfully Swapped It Into My 2000...
MumMushroom
CHEVROLET 2500
350 Vortec To 454 Vortec Swap
MumMushroom
CHEVROLET 2500
After Replacing The MAP Sensor Do I Need To Reset The...
Map Sensor Replacement.
iguerre
BMW 535I
Location Of The BCM And ECM Needed?
Been Having Some Electrical Issues With My Car And Would Like To Test The Control Modules To See If They Need Replacing Or Not.
ryurei4444
CHEVROLET SPARK
Won’t Accelerate In Drive
Car Runs Great When You Put It In Reverse It Goes Just Fine But As Soon As You Put It In Drive, There’s No Acceleration It Just Idles...
Blondechick73
NISSAN MAXIMA
Air Conditioner Not Working
Have Checked Refrigerate Pressures With Gauges Is Good. Fans Are Good. Clutch On Compressor Works When You First Start Car And Blows Cold...
Larry A
HYUNDAI TUCSON
A/C Starts Blowing Warm Air After Driving Two To Three...
Put On Gauges Everything Checks Good As Far As Refrigerate Goes And Pressure. Fans Working No Leaks. Clutch On Compressor Works And Cold Air...
Larry A
HYUNDAI TUCSON
Shut Off While Driving And Would Not Start?
It Cranks But Won't Start. Replaced Fuel Pump And Filter, Ignition Module, Map 02 Sensor, Plugs And Wires. I'm Getting Code 43....
Angi Allard
No Injector Pulse?
This Vehicle Sat In Someone's Yard For About Ten Years. I Was Homeless And Bought The Car For $500.00. Initially The Security Feature...
warnershawnutah
BUICK RIVIERA
Is There A Way To Distinguish A Bad Head Gasket From A...
Toyota Is Saying That I Need To Replace My Engine Or Buy Another Car. To Have Them Verify/troubleshoot The Problem It Will Cost Me $2,125.00...
Vll
TOYOTA PRIUS V
No Acceleration When Transmission Is Shifted Into...
Car Will Go In Reverse, Just Fine With Throttle But When You Put It In Drive, There’s No Acceleration.
Blondechick73
NISSAN MAXIMA
Replacing Radio?
The Radio In My Vehicle Listed Above Does Not Have A Cd Player. There Are Salvaged/used Kia Sorento Radios With Cd Player Built In For Sale...
Fewen
KIA SORENTO
Only Cylinders 3 And 5 Have Spark?
Cranking Good But Just Cylinders 3 And 5 Have Spark. My Analyzer Says No Codes If I'm Right Computer Deliver The Spark For Each Cylinder...
Victory76
HONDA PILOT
Left Front, Back Of The Tire Area Has Scraping On The...
What Are All The Causes For That To Happen?
Charles Ewart
FORD E-SERIES VAN
Code P0306, Cylinder Six Misfire?
P0306 Code. Missing On Cylinder 6. New Fuel Pump, Fuel Filter, Pcv, New Injector Spider. New Plugs. Good Spark When Removed, Checked...
Coolwhipl
CHEVROLET EXPRESS
The Rear Running Lights Not Working?
Rear Blinkers Work, Reverse Lights, Work Brake Lights Work, But Rear Running Lights Don't Work. I've Checked All Fuses And Relays...
Nick Luttrell
CHEVROLET 1500
What Is The Correct Way To Line Up Timing Marks On Oil...
Timing Marks, Oil Pump, And Distributor.
Loretta Lyons
1983
Code P0753 X2, Where Is The Shift Solenoid Located?
Can't Find The Shift Solenoid.
Amanda Armstrong
21 IMAGES
How To Replace The Rear Quarter Window?
Long Shot, But I Need To Replace The Shattered 1/4 Rear Window Glass On It, Removing It Will Not Be Hard I Believe, But Do You Have Any...
MINI COUNTRYMAN
Engine Shut Off While Idling With The A/C On?
When My Car Was In Park, Was In Idle And The Air Conditioner Was On, After Some Time The Motor Turned Off.
vmstagg
Wobbles When It Hits A Bump At 50 To 60 MPH?
Did Brakes, Front Lower Control Arms, Front Shocks, Steering Dampener, And Alignment.
Ddmyers24
Why Is My 02 Sensor Not Pulsing And Not Throwing A...
I Have Tracked Down All Vacuum And Exhaust Leaks, I've Replaced The Spark Plugs, Wires, And Coil Pack, I Replaced One 02 Sensor...
2004mustangv6
Cruise Control Only Works Under 50 MPH?
You Can Set The Cruise And It Works Until You Try And Bump It Up Over 50 Then It Shuts Off.
Jjamesw1
DODGE AVENGER
Rear End Or Transfer Case Issue?
Bought It As Is, There Is Binding Or Vibration Type Feeling When Turning While At Low Speeds Such As In The Driveway, Going In A Straight...
LAND ROVER LR2
Torque Specs?
Hi, I'm Currently Looking To Purchase A Torque Wrench With An Appropriate Range. I Was Wondering What Would Be The Ft-lb Torque For The...
David3611
TOYOTA HIGHLANDER
652
653
654
