Where Is The MAF Sensor Located?
Please Tell Me Where The Maf Sensor Is Located.
Fayealdrich
MERCURY MARINER
New Starter Clicks?
I Just Installed A New Starter And All It Does Is Make A Click Sound. I Tried To Turn The Crank A Few Times, I Even Sent Power To The...
Ronald DeVold
Where Is The Output Speed Sensor Located?
I Been Having The Problem Of Gear No Shifting Right And Getting Worse Took It To Get Checked The Code Was P0722, They Tell Me That Is...
Nely26
OBD2 Codes $07E8 And $07E9?
Obd2 Codes $07e8 And $07e9 Are Coming Up On My Car I Purchased The Obd2 Scanner On Ebay And Wanted To Know Why My Check Engine Light Was On...
Sean Carmelly
MITSUBISHI LANCER
Engine Will Not Idle After Installing An Aftermarket...
I Bought An Aftermarket Iac Valve For My New Engine, And It Starts And Stalls Won't Idle, On Inspecting The Iac Valve The Pintle Won...
tunst
Message Center Drains The Battery?
My Message Center Stays On And Drains My Battery. It Says “security” But I Don’t Have An Alarm Or Power Locks.
Keith Lutz
Scan These Data
Fuel Consumption
Nadheer
TOYOTA RAV4
How Do I Remove The Front Axle On Passenger Side?
Removing Front Axle.
LAND ROVER LR2
ABS ESP Lights Are On?
“abs Esp Unavailable” Car Starts And Upon First Acceleration The Car Grinds A Bit Then It Goes Away. My Mechanic Said It’s A Wheel...
luckyd1ce
MERCEDES BENZ R350
Melted Dashboard Melt In The Heat On The Dashboard?
I Had These Little "mochi Squishies" Which Are Like Little Rubber Toys On My Dashboard, As It Got Hotter Outside, They Melted...
TabbyKatto
The Driver's Side Front Door Has Lost All Power?
I Have Checked All Fuses And Relays. It Had Started To Kind Of Lose Power But Just Every So Often 1 Time In 3 Months. That Was Why It Wasn...
Kyle Whitson
CHEVROLET AVALANCHE
The Vehicle Keeps Forcing All The Coolant Into The...
The Vehicle Keeps Forcing All The Coolant Into The Overflow Tank Until It Starts To Overheat.
birdmaster
DODGE NITRO
How Difficult Is It To Just Replace The Rod Bearings...
We Replaced The Chain As It Had A Bit Of Noise, We Still Have Some Noise Coming From The Bottom Of The Engine. This Is The 2.5 Sky Active...
MAZDA 6
Code P0135?
I Want To Know The Location Of This Sensor So I Can Replace It.
Caleb Wageman
Repairlink
I Know That I Am New Here But Wanted To Share Some Information That I Think Might Be Beneficial To Everyone. There Is An Online Resource...
Brendon S
Struggling To Start?
Not Starting But I Got Fuel And Spark And Just Replaced The Crank Sensor, It’s Splutters And Back Fires But Up To That Point It Was Fine...
ThatBritishGuy
VAUXHALL CORSA
Now The Car Will Not Start? Code P0355
I Had Code P0355. I Changed The Crankshaft Sensor. Now The Car Will Not Start. I Don't Know If It's Something Else. I Turned The Key...
prryperrys
Codes P0700 And P0742, Torque Converter Clutch...
Hello Again, I’m Hoping You Can Help Me With Another Issue With My Vehicle Listed Above. I Randomly Keep Getting A P0700 And P0742 Code...
bdab68
HYUNDAI TUCSON
Hard Starting Car In The Morning?
My Car Starts Up Lazy In The Morning And When It Warms Up It Becomes Okay. I Floor The Acceleration Pedal And It Is Not Picking Up Speed....
arinaitwe
Transfer Case Is Stuck In 4 High?
This Is The Second Time It Has Happened. The First Time I Took Out The Transfer Case And Put It Back In Awd Manually. Now It Is Stuck Again...
Rooster325
DODGE DURANGO
4x4 Stuck In High
So My Durango Got Stuck In 4wheel Drive A Couple Months Ago. I Figured Out That It Was The Transfer Case. So I Took It Off And Put It Back...
Rooster325
DODGE DURANGO
Power Steering Fluid Leak?
My Serpentine Came Off Apparently Because It Was Slick With Fluid. I Recently Changed My Ps Reservoir And After That Had Noticed Small Loss...
Mark Rodgers
Tire Blew Out On The Passenger Rear Side, And It Tore...
I Had A Tire Blow Out On The Passenger Rear Side, And It Tore A Harness Completely Out. I Know It’s Not The Fuel Pump, But It Is Beside...
Michael Tehonica
OLDSMOBILE AURORA
RPM Fluctuating And A/C Stops Working During That Time...
Am Having This Issue For While Rpm Fluctuating Car Jerking And Sometimes Rpm Drops Down Till It Switches Off And During The Fluctuating The...
mohamed.aboulwafa
Vortec 350 To 454 Vortec Swap?
I Have Done Most Of The Hard Part On This Swap, I Took A 454 From A 1996 Gmc Suburban 2500 (2wd) And Successfully Swapped It Into My 2000...
MumMushroom
CHEVROLET 2500
651
652
653
