Lost Key, How Can I Shift The Transmission Into...
How To Put In Neutral Without The Key?
Jontralewis29
Where Is The Fuse Or Relay For Horn Located?
Horn Does Not Work After Accident.
Derek1649
JEEP COMPASS
Car Shaking Between Twenty And Forty MPH?
My Car Starts To Shake At 20 Mph And Then Its Vigorous Shaking At 40 Mph Until About 55 Then It Stops, Also If I Take My Foot Off The Gas...
Njerseychick1
TOYOTA CAMRY SOLARA
Engine Will Not Stay Running?
My Car Will Start Just Fine At The Start Of The Day Or Sitting For Over An Hour, But If I Drive It For Roughly Half An Hour Or More And Let...
Rwiggin5
SUZUKI GRAND VITARA
A/C Blows Air In Reverse When Car Unlock?
This Is Intermittent Issue When I Am Switch Off The A/c And Engine And Then Locks The Car By Remote Keys In Parking And Come Back After 1 Or...
drfirojtadavi
GMC ACADIA
A/C Issue?
I Finished The Valve Cover Gasket In It, And All Is Good But I Noticed Ac Was Not Working, Compressor Not Kicking In. Checked The Wire And...
BMW 550I
Alternator Burned Now Problems Ensue?
The Vehicle Listed Above Is A Cherokee Laredo. I Parked The Car For About 2 Hours And When I Came Back, I Started It And Was Idling For...
LepriKaan
68 IMAGES
JEEP GRAND CHEROKEE LAREDO
Brake Lights Work But Taillights Or Parking Lights Do...
The Taillights (both Sides) On My 2007 4runner Are Not Working But All Brake Lights Are Working: - Headlights Work - Turn Signals Work...
mrshanno
Charge Lamp Not Working?
Charge Lamp Does Not Work On Start-up And Does Not Come On Even With No Charge Condition.
Fixmyproblem
Rattling Noise When Pressing The Accelerator Pedal?
My Car Has Been Making A Rattling Noise For Over A Year Now And It’s Getting Worse, Every Time I Push Down On The Gas It Starts Making...
Rae00
MITSUBISHI MONTERO
Will Not Crank Over, Jumped Starter Relay And It...
Wont Crank Over Jumped Relay It Cranks Over, Installed New Relay It Does Not Crank.
lgduda
PORSCHE BOXSTER
Electrical Issues - My Question From Yesterday Didn...
Hi, I Really Don't Want To Have To Retype The Whole Thing I Sent In Yesterday, So The Short Version Is That After A Bunch Of...
Imprint4139
MAZDA MPV
Charging System Light Not Working?
Charge Light Does Not Come On During Start Up And Does Not Come On When Running And System Is Not Charging. Installed New Alternator With No...
Fixmyproblem
Fuel Pressure Sensor Fault?
I’ve Been Trying To Locate The Fuel Pressure Sensor On My Car Listed Above Exclusive 1.4vti Petrol 2010 And Struggling.
Jamie Rudd
CITROEN C3
Where Is The Fuel Pressure Sensor Located?
Jamie Rudd
CITROEN C3
Ignition Fuse Blows When Starting The Truck?
My Ignition Fuses Keeps Blowing Every Time I Try To Start My Truck. Okay, So Here's What Happened: I Hit A Puddle Of Water And Then I...
James Martin2
ABS Module, Used Replacement?
I Have An Abs Module That I Tried To Have Rebuilt But Was Told It’s Unrepairable Because Of Software Issues. I Found A Used One From The...
kurz2busy
Engine Cranks, But There Is No Spark?
Car Is Not Getting Spark Ran Fine One Day Came Back Out The Next No Spark But Cranks.
Dominick Vargo
BUICK REGAL
When I Crank, The Starter Does Not Turn Over The...
It Engages, But I Only Hear The Noise Of The Starter Spinning Fast, Without Engaging The Motor. Do I Need To Change Solenoid, Starter...
Mariusz Herejczak
BUICK LESABRE
Gurgling Sound Coming From The Rear Of The Vehicle?
I Test Drove This Vehicle Earlier Today And There's A Noticeable Gurgling Sound Coming From The Rear Of The Vehicle. It's More...
Jr47
Max Cylinder Head Temperature (diesel)?
Have Installed An Overheating Sensor, What Should I Set The Max Alarming Temperature At? Thanks.
nealwest
KIA SPORTAGE
Rear End Clicking Sound When Backing Up And Turning?
The Rear End Has A Clicking Sound When Backing Up And When Turning On The Passenger Side Recently Replaced Front Passenger Side Cv Axle...
jackryan177971
Drained Battery, Black Gunk On Battery?
Hi, My Battery Drained And I Was Going To Jump My Car With Cables, But I Noticed All Around The + And - Battery Nodes There’s This Brown...
v.gabrielle
Electric Door Locks Not Working?
They Don't Work, The Car Locks Are Frozen They Click That's It I Have One Door That Opens. What Do I Do?
Ronald Smith2
TOYOTA AVALON
Battery Drain?
My Battery Was Drained, And The Cd Stays On The Display. Also, The Cd Player Was Making A Noise When The Car Was Off. Can I Take The Fuse...
Maria9
BUICK RANIER
637
638
639
