700r4 Transmission No Forward Gears, Only Reverse?
I Just Bought The Vehicle Listed Above With The Transmission Disassembled. I Rebuilt It, And Put It In The Van. It Won't Go Forward In...
Allysa Stornelli
CHEVROLET ASTRO
Fan Clutch Removal
I Cannot Remove The Mounting Nut On Fan Clutch. I Have The Oem Tool And A Large Crescent Wrench.
Chap08
Fan Clutch Removal
I Cannot Get The Mounting Nut On The Fan Clutch To Break As I Try To Replace It. I Have The Oem Tool And A Large Cresent Wrench.
Chap08
Head Gasket Replacement?
I Have The Vehicle Listed Above With The 3.5 6ve1 Engine. It Has Jumped Time Due To A Failure Between Dowel Pin Of Intake Camshaft And...
RABisuzu
ISUZU RODEO
A/C Compressor And Cooling Fans Work Intermittently?
As The Title States, They Work Intermittently. They Either Both Work Or They Both Don’t Work. When They Aren’t Working, The Fans Won...
Tyler Saldivar
After Some Time, The Engine Overheat Indicator Lights...
Car Somewhat Struggles To Fully Perform When Going Uphill. After Some Time, The Engine Overheat Indicator Lights Up. After Checking With...
JamesNirmal
TOYOTA VIOS
ABS, Brake, Tire Pressure, Check Engine Lights On Gear...
While On A Trip Don't Know What Happened But When I Turned On The Van A Lot Of The Lights Stayed On Dash The Ac, Radio, Blinkers...
Maria8k
TOYOTA SIENNA
I Have A Rough Idle That Comes And Goes Often After...
So, A Couple Weeks Ago After Cleaning Out The Pcv Orifice In The Intake Manifold (was Clogged Since Owning The Car And Is A Common Issue...
BVerano23
BUICK VERANO
Convertible Top Will Not Go Up, Leaking Hydraulic...
Need To Know How Much It Will Cost, Parts And Labor To Repair Cylinders And Get Top Functional Again…
bobbysbaja
MERCEDES BENZ 500SL
Vacuum Line Diagram Needed?
I Need The Vacuum Line Diagram For The Car Listed Above.
Shelby420
CHEVROLET LUMINA
The Radio Is Locked, How Do I Unlock It?
I Have The Car Listed Above Ltz. The Radio Is Locked, And I Can't Find The Code To Reset It.
Mvh2010
Strong Fuel Smell On Oil Dip Stick?
The Vehicle Listed Above Is A R50. 1) Last 6months Strong Fuel Smell On Oil Dip Stick. 2) No Discoloration In Oil Or Bubbling In...
AMCJavelin
Runs Too Rich And Very Poorly?
No Injector Pulse In Original Ecm But When I Swap The Ecm It Will Work. But The Only Other One I Have Is A 350 Ecm Which Runs To Rich And...
Ron Swanson
CHEVROLET 1500
Loud Fan And Temperature Gauge Going Up Slowly?
So, My Radiator Fan Sounds Loud After 15 Minutes Of Driving. The Temperature Gauge Stays At The Halfway Mark When I’m Driving. But When I...
Dewregard92
DODGE JOURNEY
Engine Will Not Turn Over?
I Don't Know What's Wrong With My Truck, It Won't Turn Over, It Doesn't Even Ding When I Put My Key In. The Light Under...
Harmony817
GMC JIMMY
Codes U0121, And U1002, Will Not Start With Key, But...
It Will Not Start With The Key. All Buttons On Key Fob Work, And I Am Able To Start The Car With Remote Start. Battery Is Good. Codes That...
kbeauch16
NISSAN ROGUE
Blend Door Actuator Not Functioning.
I Admit I'm Not A Master Mechanic Nor Electrician, But I Was Experiencing Two Problems: 1) The Blower Seemed To Only Operate On...
Brandon Ogden
Loud Whine And Weak Acceleration (high RPM)?
The Videos Describe Most Of The Noise, Let Me Know If You Need More Info. Thanks In Advance.
Samiabdan
BMW 328
Key Relearn/ No Security Light On?
I Replaced The Ecm And Throttle Body/throttle Position Sensor And Tried The Key Relearn Process And It Didn’t Work. The Security Light...
Thetahoe08
Do You Have Any Wiring Diagram For The Passenger Door...
I’m Trying To Wire And Splice Together. I’m Looking For A Color Wiring Schematic For The Passenger Door On My Vehicle So I Can Connect...
Randall Clark
Code P1233, Kicking/sputtering And When I Came To A...
So, I Was Driving Home And When I Pressed The Gas The Car Felt Like It Was Kicking/sputtering And When I Came To A Stop The Car Turned Off...
Cesar Villarreal
Hazard Lights Fell Into Console?
The Hazard Light Fell Into The Console While The Lights Were Still On. How Can I Get To That Button And Reconnect It And Should I Turn The...
Treebro
Not Starting After Removing Catalytic Converter P0050...
I Catalytic Converter Was Clogged So I Removed It. Now The Truck Does Not Start. I Will Give You The Code Heater Control Circuit Bank Sensor...
Matt Blondke
ABS Light Odometer Automatically Resets To 0?
First, The Dash Warning Lights Went Out And At The Same Time My Trip Odometer Quit Working. Every Time I Turn The Car Off The Trip Odometer...
Julieannw
CHRYSLER 200
Test Injectors With Test Light?
I Was Going To Test My Injectors And I Believe I May Have Switched The Negative Side Battery Terminal With Positive And Checked For 12v. Now...
Vanmang20
CHEVROLET VAN
621
622
623
