HVAC Cooldown Test Fails Leaving Simultaneous Blinking...
Freon Sufficient In System. Hvac Cooldown Test Fails Leaving Simultaneous Blinking Of A/c And Recirc Flashing. Holding Rear Defrost, Recirc...
R. Pearson
A/C Blows Cold On Driver Side And Hot On Passenger?
Also, My Ax Temperature Flashes When I First Start Up My Car, The Passenger Knob Is Set To Cold So I Don’t Know What’s Going On.
DaevinG
OLDSMOBILE 88
Wire Connector Location?
I Have No Idea Where This Plugs In. Any Possibility You Can Find Where This Goes? It Has Three Wires. It Is Close To The Throttle Body Area
MAZDA 6
Can You Help Me Track This Wire That Splits Out From...
Then This Wire Splits From The Main Harness While The Other Part Goes To The Ecu. Can't Figure Out Where It Connects. It Is Very Close...
MAZDA 6
High Rpm Lousy Take Off
Car Takes A While To Shift When Started Up Right Away And Driven When It’s Hot It’s Better But Still Takes A While To Shift
Sami1064
BMW 328
Scraping Noise?
Anytime I Drive On A Slight Incline Or Reverse On An Incline A Loud Scraping Noise Comes From Right In Front Of My Driver's Side Rear...
joshmadden22
PAG Oil?
Just Watched. How To Vacuum Down And Recharge Your A/c System! How Come The Oil Isn’t Evacuated With The Freon?
jhend1
HYUNDAI SONATA HYBRID
Intermittent Will Not Start?
I Drive A Short Distance, Go For A Walk, And When I Come Back, Sometimes The Car Won't Start. Sometimes It's Completely Dead (no...
LOL4
HYUNDAI ELANTRA
Code P2177?
About A Month Ago I Had To Replace The Belt On It And Reinstall The Tensioner Bolt After Both Came Off Of The Car While Driving One Day. I...
kvanhorn00
MINI COOPER
Codes PO2004 And Po174 After Replacing The Engine?
Hi, I Had A Used Engine Put In My Truck Listed Above Back In April. Right Afterwards The Check Engine Light Came On, Po2004 Code. This...
Talonluvswifi
No Power To Car?
None Of My Lights On And In The Car Are Working Except For My Brake Lights. My Car Won’t Crank Or Start. When I Push The Push To Start...
rmaske
Car Will Not Turn Over Have Power When Turn The Key...
Car Will Not Turn Over Have Power When Turn Key Nothing?
Kent Kramer
MITSUBISHI ECLIPSE
Code P0033, Turbocharger/Supercharger Bypass Valve "A...
The Car Listed Above Is A Zl1 Convertible. P0033 Turbocharger/supercharger Bypass Valve "a" Control Circuit Car Was Off The...
pjm333
A/C System Does Not Work?
A/c Doesn't Work: 1. Blower Works Fines. 2. No Light On At The Climate Control But The Power Is There At The Connection. 3....
Shraneel Dayal
Fuel Pump Relay
Looking For The Fuel Pump Relay In My 93 Ford Festiva
arcadebabe
FORD FESTIVA
Code P2135, RPMs Are Now Going Up When Idle And Car...
I Recently Had My Transmission Replaced. About 1,500 Miles Later The Check Engine Light Came On And Then Traction Control Started To...
StephanieRangel
Seat Belt And Airbag Damaged?
Hi Friends, My Poor Vehicle Was Recently Stolen And Thankfully I Was Able To Get It Back But Not Without Damage. The Thieves Sliced The...
Calicatinlv
Code P0102, No Start?
Been Having Trouble Getting Car To Start Need Repair Guide To Help Me Check If I'm Getting Spark In Spark Plugs, Or Maybe How To Check...
Leyna07830
CADILLAC CTS
Crank No Start Repair Guide
Having Issues Getting Car To Turn On Not Sure If I'm Getting Spark In Spark Plug Or Crank Sensor Fault Have Error Code P0102 But Also...
Meleyna Rodriguez
CADILLAC CTS
Trac Off Light
My Trac Off Light Is On And My Car Is Shifting Gears Hard. Please Help
Babelive00
Transmission Shifting Hard And Trac Off Light Is On?
My Trac Off Light Is On And My Car Is Shifting Gears Hard. Please Help.
Babelive00
Engine Shuts Off When I Remove The Negative Battery...
My 1997 Ford Econoline Alternator Charges At 13.84, But The Engine Shuts Off When I Remove The Negative Battery Cable. Why?
David Jones8
FORD E-SERIES VAN
Wipers Wont Turn Off
Once I Turn My Wipers On They Will Not Shut Off They Run On Low And High No Intermittent The Only Way To Get Him To Shut Off Is To Shut The...
mkowalcyk65
I'm Going To Turn On My Car The Wipers Are Normally Off However When I Use My Wipers They Will Not Shut Off They Run In Low Speed And...
mkowalcyk65
Fuel Pump Constantly Cycles?
The Relay Is Getting A Signal To Make My Fuel Pump Constantly Cycle Between On For Two Seconds And Off For Three Or Four Seconds, I Know It...
Brian333
36 IMAGES
622
623
624
