Powerseat
Powerboat Stuck On One Side
obinna
MERCEDES BENZ CLS550
Transmission Cooler Replacement Instructions Needed?
Hello! I'm Seeking Advice About Replacing The Transmission Cooler (radiator) Situated In Front Of The A/c Radiator. There Is A...
Valatcarpros
MERCEDES BENZ SPRINTER
Car Would Randomly Struggles To Crank Over?
The Past 2 Weeks My Car Would Randomly Struggle To Start/turn Over. Maybe Nothing Longer Than A Solid 4 Seconds, But It's An Obvious...
Storm23
I Went To Start It Up And There Was Nothing, No Sound...
Some Background Info That May Or May Not Be Relevant To The Problem. A Few Months Ago, I Had Another Key Made At Ace Hardware Because My...
Bphill
Can I Install A Turbo On My Cruze?
I Would Like To Install A Turbo And Was Wondering If It’s Even Possible
Poongridlock
CHEVROLET CRUZE
When Stopped With The Engine Running And The...
When Stopped, But In Gear, Like At A Light, The Whole Car Twitches, And The Engine Feels Like It’s Threatening To Shut Off. However...
Rachel Lennie Armstrong
HONDA FIT
How To Change/swap The Clutch Fan To Electrical?
I'm Looking To Swap The Factory Clutch Fan Out For Electrical Driven Fans. Is There Any Way You Could Help Answer A Few Questions For Me...
CCarnes25
Squeezy/chirpy Belt?
I Start The Car Cold, It Chirps. When The Car Warms Up It Stops. In The Past I've Put Corn Starch On The Inside Of The Belt...
ahartley
BUICK LESABRE
When The Ignition Is Turned To The On Position And The...
When I Put My Scanner On The Vehicle It Doesn't Show That Any Codes Are Stored So I Don't Know If There May Be An Issue Or Not. I...
jhare213
118 IMAGES
Battery Light Turns On When I Start Driving The...
I Have A Battery Light That Was Coming Off And On, Now It Is On Solid. Replaced The Battery Had The Alternator Checked It Read 15 Volts....
fordescape123
Keyless Remote, I Can Unlock My Doors Using The Key...
They Lock And Unlock Using The Lock Switch Inside The Car.
Bjsmusic
Keyless Remote
I Can Unlock My Doors Using The Key Fob But Can Not Lock Them? They Lock And Unlock Using The Lock Switch Inside The Car
Bjsmusic
Overheated Then Shut Off And Will Not Start?
I Bought My Vehicle Listed Above From Facebook Marketplace, Previous Owners Told Me The Head Was Cracked, Drove It From 40+ Minutes Away...
Kaleb65
16 IMAGES
DODGE DURANGO
Catalytic Converter Replacement, Not Sure Which One To...
I Have To Replace The Catalytic Converters On My Vehicle. I Was Told There Are Three Of Them. I'm Trying To Purchase Them Online, But I...
Mraustin86
FORD FREESTYLE
Engine Rattling?
Hi, My Car Never Had Any Warning Light Apart From Dpf And Servicing Then When This Happened The Oil Light Came On. I Was Driving It Went...
rachipoo6
BMW 118D
After Replacing The Head Gaskets, Runs Fine For About...
I Changed The Head Gaskets In It. Idles And Runs Fine Until An Hour Or So Of Driving Then Acts Like It Runs Out Of Gas Restart It And It...
Doug Statham
CHEVROLET LUMINA
Code 001161, Cam Position Solenoid Valve?
I've Done A Pedal Test, Code 001161 Showed Up. I Recently Had A Replacement Used Engine, Should This Error Be Occurring? Or Should It...
JackieJ77
VAUXHALL ZAFIRA
Radiator Hose Dry Rotted Causing The Engine To...
My Radiator Hose Appears Dry Rotted. Causing Hot Antifreeze To Explode All Over My Engine And Battery And I’m Going To Assume My Throttle...
Tim Lee
I Need To Replace Ambient Air Temp. Sensor Circuit And...
Use A Code Reader Obd2 Got Three Codes P0072 & P0073-ambient Air Temperature Sensor Circuit ( Low And High) Got Code P0272 Cylinder 4...
Quant2134
MINI COUNTRYMAN
Right Side A/C Vents Blowing Heat, The Left Side...
I Changed The Right-side Blend Door Actuator Behind Glove Box, The Old One Had A Strip Gear. I Removed The Driver Side Actuator And...
shogn24
LINCOLN MKS
Coolant Fans Won't Kick In Causing It To Over Heat
Over Heating Coolant Fans Won't Kick In
Juli Prouty
OLDSMOBILE DELTA 88
Code P0017, Where Is The Camshaft Position Sensor...
Camshaft Position Sensor Bank1. I Have Searched All Over The Internet To Get An Actual Diagram Of Where The Sensor’s Location Is To No...
Dublr79
INFINITI QX60
Engine Shut Off While Driving, Would Crank But Not...
The Smell Of Gasoline Was Really Strong. Had Van Towed To My House. Checked For Codes, There Were None. Replaced Crankshaft Position Sensor...
jscampbell
Issue When Attempting To Fill The Fuel Tank?
I Try Putting In Fuel But Every Time I Do It Acts As If The Tank Is Full, And It Isn’t.
amyalanae
MINI COOPER S
Fuel
Every Time I Try Putting Fuel Into My Mini, It Stops As If The Tank Is Full But It Isn’t. I Can Only Put In A Little At A Time And It...
amyalanae
MINI COOPER S
605
606
607
