Where Is The Knock Sensor Located?
Are The Knock Sensors On The Inside Of The Intake Manifold Or Are They On The Bottom Of The Motor By The Oil Filter?
Winningbig1286
LEXUS ES 300
The Radiator Fans Are Not Turning On, Car Shuts Off...
It Gets Hot When I Put The A/c On. The Fans Are Not Turning On And My Car's Been Turning Off When It Gets Hot Too.
Ana54
INFINITI I30
Turns Over But Will Not Start?
The Truck Ran Fine With No Issues. I Went To Start It Yesterday And It Acted Like The Battery Was Drained. I Charged It And Now It's...
TruBluRookie
Transmission Valve Body?
I Had The Transmission (6r80) Rebuilt By An Independent Shop In January. A Couple Of Months After The Transmission Was Rebuilt, The Truck...
Rusty_R
A/C Blows Cold Then Hot/rough Idle?
When I First Purchased The Car, The A/c Was Working Great But Now Most Of The Time I'll Turn On The A/c. At First It Will Give Cold Air...
Josh Torres
NISSAN VERSA
When Driving There Is A Cracking Sound Coming From The...
At 10/12 Mph There's A Metal Cracking Sound Coming From Driver's Side Rear (popping) Only At 10/12 Mph Then It Stops! Also, Some...
Willie Hurlocker
22 IMAGES
DODGE MAGNUM
Temperature Heat Sensor Blowing Off And Spark Plugs?
Hi There, My Son Started His Car Yesterday Morning And It Sounded Awful. We Narrowed It Down To This Heat Sensor. We Replaced The Sensor...
Bdunkley
Harmonic Balancer, Which Way Does The Bolt Turn On The...
And The Distributor Turn's Clock Wise.
Kenny210
Turn Signal Not Working
I Have Hazard Lights, But No Turn Signals Wondering What The Next Step Is To Getting The Turn Signals To Work
Tod Drage
FORD EXCURSION
Can I Get The Torque For Front Suspension Pieces?
Hub Nut Torque.
Iowan13
MAZDA CX-7
Shaking When Accelerating And Or Not Accelerating...
A While Back The Car Was Shaking When Accelerating And Or Not Accelerating Properly. And Sometimes The Engine Would Stutter When First...
DWSJR
Driving With Power Drive On
I Drove My 2001 Isuzu Trooper On The Highway In Power Drive Mode Because I Thought It Was Used When You Need To Drive At Higher Speeds. What...
Chellly5150
ISUZU TROOPER
A Couple Of Days Ago The A/C Stopped Blowing Out Of...
It Stopped Blowing A/c Or Any Air At All From Vents. But Blows Perfectly My Back Vents.
April Hawthorne
LINCOLN NAVIGATOR
My Ac Does Not Blow Out The Front Vents But Does Blows...
My Front Vents Are Not Blowing Cold Nor Hot Or Anything Out At All, But Back Is Working Perfectly Fine Still It Just Stop Working
April Hawthorne
LINCOLN NAVIGATOR
A/C Compressor Replaced, Will It Harm The System Of I...
I Changed The A/c Compressor, Expansion Valve, Dryer Filter, And Serpentine Belt.
skutar
TOYOTA RAV4
Trouble Changing Gears Between Second To Third And...
Problem One Started Two Years Ago - Fairly New Battery Died Very Early, Needed Replacing Problem Two - One Year Ago- Sound For...
tiffingstar
FORD TERRITORY
No Check Engine Light But Scanner Reads Misfire On...
I Had My Transmission Rebuilt And The Transmission Place Took It For A Test Drive With Scanner On It. No Check Engine Light But Scanner Red...
Jjrobie
Reverse Not Working?
Reverse Quit With No Warning. It Kind Of Catches But It Weak. Temporary Fixes That Have Worked For Y'all, Can't Afford To Replace...
rolnlow
Transmission Codes P0750 And P0755?
Recently Removed Transmission To Repair Front Pump Seal That Was Leaking After Reinstalling Check Engine Light Came On Giving A P0750 And...
Bigjoe5879
CHRYSLER TOWN AND COUNTRY
Misfire Detected Codes Po300, Po405, And P1779-00?
Misfires When Acceleration, Loss Of Power When Pressing The Gas.
Rileyscar23
PONTIAC TORRENT
Fuel Line Removal Issue?
Fuel Line Going From Engine Into Fuel Filter Under Drivers' Side Of Truck Along Frame. Using The Fuel Line Tool 3/8 Size. I Had To Buy A...
Chris
Error Code P1658?
We Scanned My Car And It Is Code P1658. Etcs Control Relay On Malfunction Tacm Relay Stuck On I Pulled Out The Backup Fuse Hoping It...
Debido88
HONDA CRV
Constant Overheating?
After Starting The Car, Within A Few Minutes The Temperature Gauge Is About 2/3 The Way Up. After Driving It For A Short Period The Gauge...
Josh
I Am Looking For Compatible Parts To Boost My Engines...
I Know It's Got High Mileage And I Understand Trying To Build A Car With No Aftermarket Can Get Expensive, I Know There Are Cars Out...
JohnBall
TOYOTA AVALON
Radiator Push Lock Hose Trouble Going Back On?
Hi, I Am Replacing The Upper Radiator Hose And I Got One Side Connected To The Radiator On. The Other Side Is Extremely Difficult To Go On...
Michael Kleon
LAND ROVER LR2
601
602
603
