F150 Poor Mileage
1987 Ford F150 302 Auto 110,000 New Tune Up Plugs Wires Cap. Doesn't Use Oil It Seems That When I First Got This Truck I Got About 15-...
cat1947
1915
Hello.
Hello, My Name Is Johanna. I Am 43. I Need My Car To Just Work Like Its Supposed To! I Am Hoping To Return To Work Soon And We Will...
DragonLady62
250,000 Mile Saturn 1997
97 Saturn Sl2 - This Actually Makes Me Rather Sad Because It's Been A Great Road Car. Some Months Ago While Driving On The Highway, The...
kdmsa
95' Dodge Neon Stalls Out After Around 15mins Of...
Please Give Me Some Input On To What Might Be The Cause For This Problem. My Car Stalls Out After Around 15mins Or So Of Driving And Will...
wikkenone
Van Keeps Flooding It's Self
My Problem Is My 87 Plymouth Voyager Keeps Flooding It's Self Off And On. I'm Not Too Familiar With The Newer Fuel Systems So I Was...
Caravan
CHRYSLER GRAND VOYAGER
Temperature Oscillation In 2002 430E
I Have A E430 (2002) For Several Months Now. What I Have Noticed Is The Temperature Gauge Will Oscillate Between 80-90 C While In Traffic...
tomk99
MERCEDES BENZ OTHER
Tire Pressure
I Have Toyota Hilux Surf. Tire Size Is 265x70 R16 How Much The Tire Pressuer Should Be In Psi.
mpj111
1981 Olds.
When I Put My Turn Signals They Just Stay Solid, They Don't Blink. If Any Answers Please Let Me Know. Thanks
cowjawone
1981
96 Intrepid Transmission
Have You Ever Heard Of A Transmission Locking Up The Front Wheels While Going Down The Road? If So What Could Be A Possible Cause? Took It...
xbag
2000 Ford Focus - Smell Burning Oil
We're Not Sure Where The Oil Leak Is! The Smell Of Burning Oil Is Coming Through The Air Vents And Is Only Intermittent (approx. Every...
uschnc
How Do I Remove The Water Pump From A Caravan (97 - 3....
I Have Pulled All The Pulleys And Removed All The Bolts From The Water Pump, But It Appears As If There Is One Bolt Remaining, However The...
EdP
CHRYSLER VAN
Hard Starting Cadilliac
Our 1996 Eldorado With 67k Miles Has Been Hard To Start Recently. Only The First Start Of The Day, Does Fine Otherwise. Is It The Fuel Pump?...
Boley
Malfunction Indicator Lamp
I Have A 2000 S-type Jag. 3.0. The Malfuntion Indicator Lamp Warning Light Came On. What Is Wrong With The Car? I Have Noticed For A...
rebecca howell
JAGUAR XJS
Overheating I Have Replaced The Thermostat?
We Recently Bought A 1983 Hond Accord. I Have Replaced The Thermostat, And Fixed A Hole In The Radiator. The Water Pump Appears To Be...
jahacsmith
Vibration After Alignment
I Have A 2001 Honda Accord 5 Speed With 30,000 Miles. I Love And Baby This Car Which Had No Vibration And No Other Problems Except It Needed...
Cheetah
95 Jimmy(location Of Flasher)need To Know Asap!!!
Wondering Where It Is Checked Fuse Panel On The Driver Side Wasnt There, Plz Let Me Know, Thankyou. I Need To Know Asap So I Can Get It...
crandall_17
GMC JIMMY
'91 Ford E150 Water Leak
I Have A Serious Water Leak In My '91 E150 Van. It Comes Out When The Engine Revs But Not When Idling. I've Narrowed The Leak Down To...
cagrote
95 E-350 Misfire
I Have A Van With 140,000 Miles With A 460, It Runs Fine When Its Cold, But After It Gets Up To Temp It Begins To Miss Severely On...
Emod 21
Ignition Timing
Greetings To You. I'm Trying To Get Information On The Correct Ignition Timing For A 1995 Dodge Dakota 2.5l 4 Cyl. W/ Manual Trans. ...
hayseed
CHRYSLER OTHER
Saturn '99 SL 1 Idle Problem
I Have A '99 Saturn Sl1 Single Cam. For Weeks The Service Engine Light Has Been On & I Have Replaced The O2 Sensor, Cam Shaft Position...
Redsnipper
1999 Ford Ranger ABS Brakes
My 1999 Ranger Has 150km And Has Developed A Problem With Braking. Frist One Only Accurs When It Wet Or Very Damp Outside And The Truck Has...
Batman
1988 Ford Mustang Gt Altinator Problem
My Problem Is Driving Me Crazy! My Mustang When Running On Idle About 750-850 Rpm My Meter In The Dash Shows That The Car Is Not Charging. I...
dj-taino
Fuel In Engine Oil Saturn Sc1
Why Would There Be Fuel In The Engine Oil. And What Would Be The Repair 4 It.
lighthouses
Fuel Pump Relay
Can Anyone Help Me Find The Fuel Pump Relay In My Car? According To The Chilton's Electrical Diagram Of The Car There Is One On It, But...
bodurham
Alternator, Battery, Wiring?
Hi, I've Got A 1987 Olds Cutlass Supreme With The 3.8l Engine. Recently Having Problems With What I Thought Was The Alternator. Car Was...
hearts88
20231
20232
20233
20260
