Starter
I Have 1994 Chev Cavalier 2.2l :cry: And I Have Replace A Number Of Starters In It Over The Last 3 Years The Last One I Replaced Is A...
chinsy2000
1991 Chyrsler Transmission
Hello, I Have A 1991 5th Ave Chyrsler. 3.3v6. My Transmission Seems To Be Slipping I Have Check All Fluids And Everything Seems Fine. Is...
Bosbaby
1994 Jeep GC Auto/4X4
We Replaced The Transmission About Two Years Ago. I Noticed Today, My Transmission Fluid Looks Similar To Oil (gray-ish Brown) Instead Of...
FRusso
JEEP OTHER
Overdrive Sensor Is Blinking Please Hep!
I Drive A 1997 Mazda 626 Lx, My Overdrive Light Is Blinking And I Took It To My Mechanic And He Said That It's Either My Overdrive Sensor...
jackie
MAZDA 626
2001 Suburban Lights Dim And Sometimes Stalls
I Have A 2001 3/4 Ton Chevy Suburban. I Am Noticing That After Starting The Truck The Lights Become Brighter As I Step On The Gas. Also...
white01sub
98 K1500 Turn Signals
I Have A 98 Chevy K1500. My Turn Siganls Recently Went Out. All My Bulbs Work And My Hazards Still Work. I Recently Replaced My Flasher...
schoffdogg
OVER HEATING
I Have Arover 200, The Temp Showed Over Heating And The Car Lost Power What Are The Common Causes
cazsue1314
LAND ROVER OTHER
Idle Is Erratic Then Stalls
I've Got A Suzuki Ignis Xreg I'm A Delivery Driver And When I'm T Work My Car Keeps Breaking Down. It Jumps And The Rev's Go Up And Down...
ree234
SUZUKI OTHER
Sticky Gas Pedal - 2000 Chevy Silerado
My Gas Pedal Started Sticking Again As I First Take Off. Dealer Recommended Cleaning Fuel System (throttle Body? ) An $80 Job. I Had This...
boogman2u2
96 Pontiac Sunfire Coolant Problem
Please Help! Ok.I Have A 96 Potiac Sunfire 2.2l. It Started Overheating About A Month Ago And Since I Have Replaced The Water Pump, Water...
arkose
PONTIAC SUNFIRE
Broken Spark Plug
Hello I Have An Escort Cabroilet Xr3i 130 Psi. I Have Recently Been Having A Shuddering On Acceleration So I Have Just Replaced The Spark...
big ale
My Car Can Whistle!
Recently I Posted That I Had Water All Over My Floor Boards.I Went To My Fathers And He Took A Railroad Nail And A Mallet And Punched A Hole...
divadayna25
Transmission Stopped Going Into Overdrive
At About 148,000 Miles The Transmission Stopped Going Into Overdrive. I Bought This From My Dad So I Know It Wasn't Beat Or Anything....
zannkind
Desperate For Advice
I Have A 1995 Ford Contour Gl, 4 Cylinder With 169,000 Km. I've Had It For 4 Months, And Just Had The Mass Air Flow Sensor Replaced. And...
kaylene
FORD CONTOUR
1995 Mercury Sable Won't Start In Rain
My 1995 Mercury Sable Wagon Will Not Start Whenever It Rains. When The Rain Stops, It Will Start Right Away.
kenb2005
MERCURY SABLE
98 Ranger Clutch Problem, Trying To Troubleshoot
98 Ranger Xlt Extended Cab, Manual Transmission, Lots Of Miles (205,000). Great Shape Except I Recently Had A Problem Start With The...
milesdoc
Transmission Cooler Breakdown
I Was Wondering If An Unclean Or Defective Used Transmission Can Cause The Transmission Cooler To Be Damaged?
justwondering
CHRYSLER OTHER
Reverse Problem
1997 Chevy Astro Van, Rear-wheel Drive, 133,000 Miles. Shifted Into Reverse And It Simply Didn't Work. No Warning. No Nothing. The Car...
Kapana
CHEVROLET ASTRO
Fuel Pump To Blame?
: I Own An 89 Chevy Sub. 123,000 Miles. Recently I Ran The Tank Low To A Quarter. It Started Lossing Power And Jerking Like It Would If...
swoop
1993 JEEP CHEROKEE
'93 Jeep Won't Start. Battery Is New, Starter New. Lights, Radio, And All Electrical Stuff Works, Engine Won't Even Try To Turn Over...
kprezkop
Whining (gear?) Noise When Car Is Turning And...
Hi. I Have A 2002 Pontiac Bonneville. There Is A Whining Noise When I Make A Turn (right Or Left) And Accelerating (pressing The Gas Pedal...
imind
Speedometer Defective ? Faulty Transmission ?
I Have A 1996 Grand Plymouth Voyager Se. I’m Clueless About Car, Except Knowing Something Is Wrong With Mine. I Have Trouble Shot All...
kellyraye
CHRYSLER GRAND VOYAGER
Chevy Duramax Diesels
I Have A 2004 Chevy 6.6 Diesel And Last Week I Had Water In My Fuel Causing An Injector To Fly Out Of Socket Ruining The O Rings. Now The...
stevekorf
I Need To Replace A Rear Quarter Panel
Hey Guys, Got This Rear Quarter I Want To Replace, Driver's Side. Found A Really Good One In A Salvage Yard. But, I Got To Cut It Off...
Adam Brown
CHEVROLET MONTE CARLO
I Need The Diagram That Is On Top Of The Fuse Box
I Have A 1986 Toyota 4x4 With The 22r Motor. I Need The Diagram That Is On Top Of The Fuse Box That Is Under The Hood. How Would I Go About...
Tammy Jo
20210
20211
20212
