84 Jetta Battery Probs
So, My "new" 84 Jetta Runs Like A Champ! Problem Is After It Is Jump Started And It Runs For Hour Or More And Ya Turn It Off, Then...
DarkKnight
1984
2000 Mustang GT 4.6 Clutch Out
I Need Help Or Advice. I Have The Above Vehicle, A 2000 Ford Mustang Gt Convertible 4.6 Liter Motor, 5 Spd Trans. Just Turned 33,000 Miles...
Gandalf
1992 Pontiac Grand Prix 3.4L V6 DOHC High Idle At Cold...
The Car Has Around 87,000 Miles. I Am Having Trouble With The Car Idleing Around 22-2500rpms With A Cold Start. It Takes It About 15...
cartroubles
Car Stero
How Do You Take The Dash And Factory Cd Player Out Of A 1998 Mazada 626 So That I Can Install And New Cd Player?
mattp30
MAZDA 626
1996 Sable.low Engine Operating Temp.
Running At 2500 Rpm For 15 Min Gets Engine To 190 But Engine Won't Warm Up Above 160f Under Normal Driving Conditions. New Thermostat. New...
peter
Engine Codes
I Have 1997 Ford Probe 2.0l A Engine Code Showed Up 1133gtd Manufactures Code Where I Find Out What This Code Is.
probedjg
FORD PROBE
95 Lumina
Big Problem With 1995 Chevy Lumina. Bought It Used, Everything Was Going Good Until It Started Over Heating. The Temp Gauge Would Go All...
JD
Air In The Brake Lines
Hi, I Have A 1996 Chevy Cavalier And Have Taken It To A Mechanic 3 Times To Fix The Brakes. Each Time, It Works For A Week Or So And...
geasland
Pouring Oil Out Filter
Have A Pontiac Grand Prix That Is Pouring Oil Out Around Oil Filter. Changed Pump 2 Months Ago Due To No Oil Pressure. Is It My Pump Again...
pappagg
Hello
Im Not A Master Mechanic But I Will Try To Help Out As Much As Possible Here. My Name Is Wade Im From West Memphis Arkansas (yes We Have...
sc1 racing
1987 S10 Engine 2.8
I Have A 1987 Chevy S10 With A 2.8. I Am Having Trouble With The 4 Wheel Drive, It Will Not Engage. The 4 High And Low Lights Will Come On...
brock1234321
Total Restoration
My Fiancee Wants To Hold On To Her First Car Her Mother Bought Her An Rx7 1988, But She Wants It Totally Restored. I'm Not Really A "car...
KingDavid756
MAZDA RX7
1995 Eagle Talon Help Please
Hi, 2 Weeks Ago The Fuel Pump Went Out On My Car I Replaced It. Was Running Great. Then Today It Appears Like The Same Problem However...
tduncan3
EAGLE TALON
Blower Motor Not Working
I Have A 1991 Isuzu Pickup, 80,000 Mi. The Blower Motor Does Not Work. * I Pulled The Motor Out, And Connected It To A 12v Source...
rdarche
1995 Rodeo/ No Tran Drain
I Want To Change The Transmission Fluid On My 1995 Isuzu Rodeo. I Have The Haynes Book And I Have Changed The Tranny Fluid On Many Other...
AndrewO
'00 Amigo Transmission Engagement Problems & Fuel...
2000 Isuzu Amigo, V6, 4x4, Automatic Transmission, 78000 Miles Transmission Engages Slowly, Meaning It Doesn't Immediately Go Into...
jackreece
Ford Clutch
I Have A Ford Truck Standard The Clutch Petal Vibrates Really Bad And Makes A Banging Niose It Only Does This Sometimes Should I Be...
theclaw127
4.3 Crank Sensor
I Did A 4.3 Engine Swap In A 96 Astro Van. I Used A Block From A 91 Blazer And Put Heads And Everything Else From The 96 On The 91 Block....
jptruax
Corsica: Uncontrollable Shaking
I Have A 1988 Corsica With 125,000 Miles That Has Had Always Had A Slight Shaking Problem While In Idle. The Problem Would Only Go Away When...
RJM23DX1
Breaks
I Just Had The Cylinders, Shoes, And Pads Replaced On The Rear Breaks Of My 1998 Kia Sportage. They Also Re-sized The Drums And Removed...
shutterbur
KIA OTHER
Alternator Problem, I Think
I Have A 1995 Nissan P/u With 140000 Mile. My Battery And Brake Light Came On And I Took It To The Local Part Store And They Told Me That...
rsconner
NISSAN OTHER
Power Steering
I Have A 96 Sonoma 2.2cc Two Wheel Drive. The Problem Is The Steering Won't Center, I Can Go Round A Curve In The Road And Let Go Of The...
wardoe2000
GMC SONOMA
1998 Oldsmobile Intrigue Fuel Injectors
After Driving My Car For About 7 Hours Straght. I Had Got To My Distnation And Turned It Off. About 30 Minutes Later I Went To Turn It On...
JLil
Engine Main Oil Leak
Hello. I Have Been Having Some Oil Leaks Under My 93 Mercury Villager Van. Noticed There Was Oil Around Valve Cover Gasket. So Had That...
wendypeeples
MERCURY VILLAGER
Oxygen Sensor
If The Oxygen Sensor Was Bad, Would It Affect My Idle?
mjwidd
20209
20210
20211
