2001 Suburban lights dim and sometimes stalls
WHITE01SUB
  • 2001 CHEVROLET TRUCK
I have a 2001 3/4 ton Chevy Suburban. I am noticing that after starting the truck the lights become brighter as I step on the gas. Also, after pull out of a parking spot or shift from drive to reverse or vice-versa the truck stalls. I've noticed the RPM's fall off (low) whenever I shift. Could this be a charging problem?
Do you
have the same problem?
Friday, January 20th, 2006 AT 2:34 PM
SC1 RACING
Check and clean your battery connections
Friday, January 20th, 2006 AT 2:43 PM
Recommended Guides
