1992 Grand Prix Intake Manifold Gaskets
3.4l Dohc V6, 87,000 Miles. Any Ideas On How Long It Should Take A Pro To Replace The Intake Manifold Gaskets, And A Bearing In The...
cartroubles
1998 Ford ZX2 Won't Start
It Shut Off While Going To Work, Could Not Hear The Fuel Pump Running. I Checked The Fuse And Shut Off Switch In The Trunk, It All Checks...
Calvin51
95 Ford Taurus Starting Problems
My 95 Ford Taurus Starts And Immediately Shuts Off And The Battery Light Comes On. I Sometimes Have To Start It Several Times And Rev The...
Dolores Martin
4wd Problem 1992 S-10 Blazer
When I Want To Engage 4 Wheel Drive High, It Don't Work. But If I Engage 4 Wheel Low And Then Go From Low To High. Its Makes A Very Loud...
Matthew196
Smog Fail - No Data (Hyundai Elantra)
Hi All, I Have Hyundai Elantra 1996 And It Failed In Smog Check Due To 'no Data' Available To Read. My Check Engine Light Was On Last...
vmahadik
2002 Grand Prix- Fuel Injection?
My 02' Grand Prix Has Roughly 80,000 Miles On It. For The Past Few Months, I've Been Having Problems With The Car's Acceleration. 90% Of...
jm_lmx
94 Grand Voyager Starter Problem
I Pulled Into The Garage And Tuned The Key Off And The Motor Stopped But The Starter Engaged As Though It Was Trying To Start The Van. I...
pooker
94 Ford Ranger Clutch Has No Pressure
My 94 Ford Ranger After Replacing The Fly Wheel Which Was Missing Three Teeth, Now Has No Clutch Pressure, We've Bled An Entire Bottle Of...
selina
2000 Ranger 4x4
I Have A 200 Ranger 4x4. Sometimes When I Activate The 4x4 Switch On The Dash It Will Not Go Into Four Wheel Drive. It Seems The Warmer The...
berlincop
It Starts Fine, But Once It Warms Up It Idles...
It Starts Fine, But Once It Warms Up It Idles Extremely Fast. Then It Starts To Shake And Eventually Coughs Out. It Will Only Restart If...
Knife-guy
Porsche Trouble Please Help Me
I Have A 1987 Porsche 911 Turbo And Love It The Other Day My Boost Gage Began To Rise Even When It Was Not Supposed To Be Spooling Up. The...
crider
Need Help
I Have A 1989 Ford Probe 266,000 Miles How Can I Tell If My Rings R Blowen And My Car Is Idleing At About 1500 Rpms And Somtimes It Surges...
chuck1983
STARTING PROBLEMS
I Have A 97 Z-71 Chevy K1500 And Am Having Problems Starting It Up. Sometimes It Will Turn Right Over And Then There Are Times I Have All...
mikeschevys
Fuel Gauge/pump Problem
The Fuel Pump My 01 S10 Does Not Run When The Key Is Turned, But Will Run If The Relay Is Jumpered. In Addition The Gas Gauge Is Dead...
jmurty1257
2001 Jeep Grand Cherokee Idle RPM Fluctuation
Hi There, I'm Having Problems W/ My '01 Jeep Gc Limited. When Idling, The Rpms Fluctuate From 500-1000. I've Had The Car Die A Couple...
zxcaesarxz
Drive Belt Pulley Problem On 2.2CL
I Have A '97 Acura 2.2 Cl. Recently One Of My Drive Belt Pulleys Began To Squeal And Has Since Burned Through The Spindle Bushing. I Know...
sergiolo1
98 Ford F150 Oil Pressure
I Have A 98 F150 That The Oil Pressure Falls Off To Zero. The Pump Was Replaced And After 4-5 Minutes It Still Falls Off To Zero. Any...
patgeorge
Power Loss & Speedo Drops To Zero
I Have Been Experiencing An Intermittent Problem. The Speedo Suddenly Drops To Zero And There Is A Noticeable Loss Of Power Which Can...
uzi9mm
Mazda Protege' 2002
How Do You Remove The Tail Light Assembly To Replace Bulbs? Does The Inner Liner Need To Be Removed Or Can The Assembly Be Pulled From The...
cascadecruiser
MAZDA PROTEGE
2002 Dodge Grand Caravan
I Have A 2002 Dodge Grand Caravan That Is Having "radiator Cooling Fan Issues". They Continue To Run After The Car Has Been Shut Off, Even...
Peter Hayden
No Interior Or Running Lights
The Running Lights And Interior Lights On My 1995 Ford Ranger Recently Stopped Working. I Replaced A 15amp Fuse (3rd Run Across Top)...
tstarkey
Burning Oil?
My 1995 Sc Buick Riviera Is Burning Oil Especially At Idle And Take Off. What Kind Of Simple Things Can I Check Before Looking At More...
wezzley
Where Is The Fuel Filter Located? I Need To Replace It Along With Adding Fuel Injector Cleaner To It Before I Re-fill On Gas And My Tank Is...
braun_316
"thunk" In 2000 Mustang
After Stopping Heavy On My Brakes And Coming To A Complete Stop And Then Starting To Take Off, I Get A "thunk" That Occurs. I Took My...
shadow8
1986 4x4 Auto Trans Proplems
I Have A Problem When Taking Off. It Wants To Bypass 2nd Gear And Go Directly Into 3rd' Also My Overdrive Doesn't Work When This Is...
toyotaboy77
20207
20208
20209
