Caliper Problems
I Just Replaced A Cracked Rotor And A Caliper On My Husbands 1996 Chevrolet Silverado C1500, (passenger Side). I Also Put On New Break Pads...
allybar2
1995 318i Transmission Problem
I Have Recently Encountered A Problem With The Automatic Transmission On My 318. When Taking Off It Occasionally Feels As Though The...
JT
98 Honda Accord Suspension Problem
I Slid In The Snow And Hit My Front Right Wheel On A Curb. When I Looked At The Damage The Next Day My Stabalizer Bar Link Connector Was...
camronallen
1993 Nissan Sentra 1.6 216,000 Miles
I Have A Nissan Sentra That Cranks One Minute And Then Not The Next. Sometimes It Takes Many, Many Cranks Before It Decides It Wants To...
jay1pizza
Steering Wheel Shakes Violently?
Just Bought It, 76000 Miles, Just Replaced Rear Drive Shaft U- Joint, And Both Upper Control Arms. But Now The Steering Wheel Shakes...
lauracsb
MAZDA TRUCK
1991 300SE - Oil/Coolant Leaks
1991 300se Has Slight Oil And Coolant Leaks -- A Few Drops Each Day. It Appears To Be Coming From The Rear Of The Block On The Passenger...
dhwhite
1997 Dodge Dakota
I Have A 1997 Dodge Dakota That I Have Changed The Plugs, Wires, Rotor And Cap. In The Last Week Or Two My Truck Has Started Stalling...
woolsey
Repair Manual
I Am Looking For A Repair Manual For My 1988 Mercury Tracer. I Can't Seem To Find One Anywhere. Has Anyone See One, Have One, Or Know...
Shermara
98 Ranger Clutch Problems
98 Ranger Xlt Extended Cab, Manual Transmission, Lots Of Miles (205,000). Great Shape Except I Recently Had A Problem Start With The...
milesdoc
1996 Rodeo Oil Pressure
My Rodeo Has 140k When The Engine Is Cold The Oil Pressure Is 40-60 Psi' After Driving For About 10 Minutes The Oil Pressue Drops To About...
jre133
Timing Belt
I Had To Replace The Water Pump On My 95 Isuzu Rodeo 3.2 V6 And In Order To Do That I Had To Remove The Timing Belt. I Was Removing It ...
mario valadez jr
Number 4 Cylinder Not Firing At Low Revs
:( I Have A 1992 Honda Civic 1.5lsi Saloon With D15b2 Engine 16v Fuel Injection. While Travelling Down The Motorway There Was A Short Dip...
alsypetch
Cooling Problem
I Know Cooling Problems Are Brought Up Quite Often And Get Kinda Old. I Think My Problem Is A Little Differnent In The Sense That I Have...
justspeed
Wont Start When Is Cold?
Car Wont Start When Cold.I've Check Main Relley, And Distributor, -its Ok. There Is New Car Battery. There Is Spark On The Plugs, And...
Momak
99 Honda Prelude 5 Speed - Can't Shift Into Reverse??
He Guys, Question. I Just Purschased A 99 Honda Prelude 5sp With 66k. It Was Checked Out Before I Purschased; However...
Hondarules
HONDA PRELUDE
1991 Dodge Spirit -stall/startup Problem-
Hey There, I Have A Problem Regarding My Dodge Spirit 1991 - 176 000 Kms, 2.5l. The Problem First Occured A Few Months Ago, When It...
Palmiros
DODGE SPIRIT
1995 Nissan Altima No Dash Lights Or Power Antenna.
I Was Putting In A New Cd Player And When I Got Done The Dash Lights And The Power Antenna Did Not Work. I Checked All Of The Wires And...
videogfiend
1986 325e Shocks And Idle Problems.
Are There Struts Or Shock On The Front Of A 1986 325e And Are They Difficult To Change? What Are Common Problems That Would Cause A High...
rgby12
84 Jetta Battery Probs
So, My "new" 84 Jetta Runs Like A Champ! Problem Is After It Is Jump Started And It Runs For Hour Or More And Ya Turn It Off, Then...
DarkKnight
1984
2000 Mustang GT 4.6 Clutch Out
I Need Help Or Advice. I Have The Above Vehicle, A 2000 Ford Mustang Gt Convertible 4.6 Liter Motor, 5 Spd Trans. Just Turned 33,000 Miles...
Gandalf
1992 Pontiac Grand Prix 3.4L V6 DOHC High Idle At Cold...
The Car Has Around 87,000 Miles. I Am Having Trouble With The Car Idleing Around 22-2500rpms With A Cold Start. It Takes It About 15...
cartroubles
Car Stero
How Do You Take The Dash And Factory Cd Player Out Of A 1998 Mazada 626 So That I Can Install And New Cd Player?
mattp30
MAZDA 626
1996 Sable.low Engine Operating Temp.
Running At 2500 Rpm For 15 Min Gets Engine To 190 But Engine Won't Warm Up Above 160f Under Normal Driving Conditions. New Thermostat. New...
peter
Engine Codes
I Have 1997 Ford Probe 2.0l A Engine Code Showed Up 1133gtd Manufactures Code Where I Find Out What This Code Is.
probedjg
FORD PROBE
95 Lumina
Big Problem With 1995 Chevy Lumina. Bought It Used, Everything Was Going Good Until It Started Over Heating. The Temp Gauge Would Go All...
JD
20208
20209
20210
