Power Windows
I Have A 94 Mazda Protege And My Driver Window Has Stopped Rolling Down. Can The Fuse Be Blown Even Though The Others Still Roll Down. Or...
caarthur
MAZDA PROTEGE
Cylinder Head
I Had Millkshake Coolant And White Exhaust Coming From My '85 325e- I Thought It Was The Head Gasket So I Pulled The Head Off And. No...
southcaliking
BMW 325
97 Mercury Rubbing Noise From Back End
The Noise Is Not Consistent, But Only Happens When I Am Not Braking. It's A Rythmic Rubbing Noise (high Pitched) That Accelerates As The...
df_cubs
MERCURY OTHER
I Cant Find The Battery
Where Is The Battery In My 97 Dodge Stratus? 2.4 L Dohc
goodmonkeey
CHRYSLER OTHER
1993 Nissan Maxima 3.0l
Where Are Spark Plugs Do Not See? Vin #e 4th Code 4th Letter.
galdora
NISSAN MAXIMA
1996 Dodge Neon Check Light
I Was Driving The Otyher Day It Just Came On Did A Cheap Code Check Withthe 3 Times Igntion On/off Gave Me A 12 And A 21 Does Anyone Know...
cervance
1997 Ford Escort
I'm Having Problems With The Automatic Transmission. I Was Drive Along And Stopped For Gas. When I Left The Gas Station. The Transmission...
martmans55
Van Air Conditioning Vents
My Air Conditioning Vents Are Not Working In My Van The Air Is Only Coming Out Of The Defrosters And Not Anywhere Else What Could Be...
kevincamper456
CHRYSLER VAN
Ford E-150 Won't Start After Warming Up
My Ford E-150 Cargo Van Has Always Run Great. I Went To Crank It The Other Day, It Cranked Up And I Drove It For Several Miles. It Would...
brianlpate
1915
93 Ford T-bird Misfire And Rough Idle
Hopefully Someone Can Help. I Have A 93 T-bird V6 3.8ltr. I Put A New Engine And Transmission In It. I Drives And Runs Great, Seems To...
baggedbird93
Question About My 95 Taurus
My Engine Seems Alittle Loud When I Reach 40 + Mph And It Seems Like I Need To Accelarate (press The Peddle) More Than I Used To. My Last...
rmk74
Car Dies After Deceleration
Please Bare With Me. My Car A 94 Formula Firebird Was Dying After Decelrations, Basically After Slowing Down For Lights Or In Parking Lots...
im3good4u
Cruise, Daylight,overdrive, ABS, Parking Light
Hello, I Am Looking For Some Suggestions. I Have A 1992 Dodge Dakota Extended Cab, 4x4, 3.9l, That's Fuel Injected. The Abs Light And...
dakette
92 Pontiac Firebird Won't Start
We Have A 1992 Firebird That Will Not Start. The Problem Started A Few Weeks Ago And When You Turn The Key, Nothing, No Clicks/grinds...
spbeta
PONTIAC FIREBIRD
? For A Certified Mechanic?
I Had A Bad Exhaust Leak Manifold Bolts Were Loose And No Gaskets. Flange Gasket Was Blown Had 2 Broken Studs. Would That Have Any Effect On...
10foTuck
MAZDA OTHER
Check Engine Light Flashing In 2002 Rodeo
2002 Isuzu Rodeo. The "check Engine" Light Has Come On. It Flashes When The Gas Pedal Is Applied Or When Down-shifting. It Stays On (...
march25
Car Starting Problems
Hello, I Have A 98 Toyota Corolla. Sometimes My Car Will Start Right Away, Sometimes It Takes 4 Or More Tries :cry:. Once It Starts It's...
packywacky1b
1990 Camry "lights" Sign In The Dash
I Have A !990 Toyota Camry, And I Have A Problem With The Light Sign That Shows Up In The Dash. I Have Replace Every Rear Light Bulb And...
Killacam17
Condensation
I Have A 97 Grand Caravan With 138,000 Miles. I Have This Problem Only In Winter. When I Use The Heater In The Winter Time I Get Alot Of...
map97caravan
No Spark 86 Cammaro
I Have An 86 Camaro With A 2.8 L V-6(fuel Inj) Here's The Problem At Times I Go To Start The Car And It Has No Spark. When I Check For...
driverdad55
1991 Dodge Grand Caravan 3.3L - Drive Belt Tensioner
Should I Be Able To Move The Tensioner? Do I Need To Loosen The Nut On It First. How Do I Tell If The Tensioner Is Working Properly? I'm...
jsepter
1989 Cutlas Cierra-heater Core
Thanks For The Reply! Does Anyone Know. When Replacing The Heater Core On The 1989 Cutlas Cierra, Does The Dashboard Have To Be Removed?
jlmflood
97 Blazer
My Husband Was Driving My Blazer The Other Day And About 1 Mile Away From Our Home, It Died And Wouldn't Restart. My Husband Said It's...
TOtterbine
How Can I Tell If I Have A Bad Mass Air Flow Sensor?
Please Help!
leafs7777ca
Spark Plug
I Have Just Bought A 1988 Chrysler New Yorker And I Have Been Having Troubles Starting It Im About To Change The Spark Plug But I Have Never...
Darren
CHRYSLER NEW YORKER
20198
20199
20200
