1989 Olds Cierra-dripping Antifreeze On Passenger Side...
Help! I Am Dripping Antifreeze Inside My Car On The Passenger Side Of The Car. What Could The Problem Be? I Have A 1989 Cutlass...
jlmflood
97 Firebird, Engine Problems
I Own A 1997 Pontiac Firebird. The Other Day It Started To Overheat. I Checked The Antifreeze Level And It Was Bone Dry. Then I Go An Check...
Xaugh
PONTIAC FIREBIRD
1968 Beetle Crankshaft
Hello, I Have Recently Purchased An Older Bug, And Have Found By Removing The Flywheel, That The Dowels Connecting The Flywheel To The...
Denny Bouse
1968
Post Timming Chain Replacement Trouble On 93 Nissan Pu
I Recently Purchased A Replacement Timming Chani Kit For My 93 Nissan Pu 2.4l 4cl 12 Valve 2wd Ka24e Engine. The Kit Contained Both Main And...
ken dietz
NISSAN OTHER
Oldsmobile Aurora Steering Rack Problem
I Have A 95 Oldsmobile Aurora. It Has 118k Miles And I Would Like Keep It Going For Another Year Or So. My Power Steering Works...
wapitiwalo
1990 Ford Bronco II - Engine
Hi, I Just Bought My Bronco( :d ) Privatley. It's Been Sitting For About 2 Months, Just Because The Owner Bought A More Economic Vehicle....
RockMonkey17
94 Blazer Oooops
We Loaned Our 94 Blazer To Our Room Mate To Go To Jury Duty. It Was A Very Cold Foggy Morning. She Got About 15 Miles Down The Freeway And...
bitsey
93 Probe GT Engine Light, Obd1 Code Of 5
My Check Engine Light Comes On With A Code Of 5. Can Not Find A Source To Find Out What That Code Is. The Manual Has 2, 3, Then 8. Also...
Mark Slocum
1990 Plymouth Acclaim Thermostat
Was Wondering If Anyone Could Tell Me The Location Of The Thermostat In A 1990 Plymouth Acclaim. Thanks
ssgolf
PLYMOUTH ACCLAIM
Trans Leak 98 Hombre V6 Auto
Hi, I Have A 98 Isuzu Hombre V6 Auto (like Chevy S10) With An Ever-growing Trans Fluid Leak. It Appears To Be Leaking From The Passenger...
Hombre Dave
1995 Jimmy Blower Moter
The Blower Moter On My 1995 Jimmy Works Fine The First Start Of The Day, After The Vehicle Is Shut Off The First Time It Is Hit Or Miss As...
KayKay
GMC JIMMY
4Runner Not Level
1992 4runner - Right Front Side About 1 Inch Lower Than Left. What Are My Options For Leveling? I Was Told About Adjusting The Torsion Bars...
rdimaggio
99 Chevy Tahoe Sport 4WD 5.7 Noisy Fuel Pump Howls
: 1999 Chevy Tahoe 2dr 4wd 5.7 Purchased Recently With 113,000 Miles. Fuel Pump Noise Or Howling Noise Coming From The Rear At Idle And In...
tad54
Dripping Coolant
I Have A 1994 Chevy Corsica, 3.1 L, V6. The Engine Coolant Is Dripping Until The System Is Empty, Through A Pipe Located Just Behind The...
beleu21
Torquing Pressure Plate To Flywheel
My Husband Removed A T5 And Hydraulic Clutch From A 1985 Camaro 2.8l And Is Rebuilding The Clutch. The Clutch Disk Bolts Are 8mm And...
juniperlover
2000 S-type Coolant Level Sensor Elimination
The Coolant Expansion Tank On My 2000 S-type Was Replaced, But The Replacement Tank Has No Place For The Coolant Level Sensor. A Jaguar...
garygable
JAGUAR XJS
Engine Noise
I Have A 2000 Dodge Caravan With A 3.0 Motor That Makes A Chattering Noise In The Mornning Sounds Like Colasped Lifters But Goes Away...
leeohm5
CHRYSLER VAN
4 Wheel Drive
L Have A 1993 Gmc Jimmy. When L Push The Botton For It To Go Into 4 Wheel Drive The Lights Flash And Then L Hear A Buzzing Noise Around The...
jack45
GMC JIMMY
No Spark
I Am Getting No Coil Output On A 87 F-250 With A 302 Engine. I Have Replaced The Ignition Module, Coil Wire & Coil, And Cleaned All...
B79251
What Temperature Thermostat
I Am Installing A New Thermostat In A 1992 Gmc Suburban. There Are 3 Choices - 160, 180, 195 Degrees. Which One Should Be Used? I Am...
hampster
96 Galant Rough Idle & Shift Auto-Trani After...
Recently Had The Harmonic Balancer Replaced, Which Also Broke The Lower Case Of The Timing Belt Cover. After The Repair Was Complete, My...
AZTucson
94 Pontiac Grand Am 3.1 Barely Starts
Have A Grand Am That Doesn't Wanna Start Turns Over And Over But Doesn't Start Till You Hold The Gas Pedal To The Floor Then Spits And...
llambertjr
F-150 Loss Of Power
I Am Having Some Promblems With My 1993 Ford F-150 It Seems I Am Losing Power.I Mean I Can Get Up To 55-65 With No Promblem But If I Go To...
maxx
1915
Saturn Transmission
I Have A 2000 Saturn Sl1 (automatic Transmission). I Just Had To Have The Transmission Filter Replaced Because The Seal Was Gone On It....
scribbles_tam
Oldsmobile Alero
My Temperature Gauge Has Been Acting Up. It Stays Above The Middle And Goes Up And Down While I Am Driving. It Will Go All The Way To The...
jacy332
20199
20200
20201
