1990 Ford Ranger That Won't Start After Sitting For...
Our 1990 Ford Ranger Will Not Start After It Has Been Sitting For Awhile. After Some Time Of Trying Then It Will. It Does Not Do This If It'...
mdsan
Power Door Locks Not Working
I Just Bought My Daughter A 91' Accord And The Power Door Locks Do Not Work. When The Switch Is Moved The Door Lock Controller Clicks But...
kidd546
2000 Chevy Truck Fuel Pump Replacement
Replaced A Fuel Pump Now The Pump Does Not Even Turn On When The Ingnition Does? Is There Are Relay All The Fuses Have Been Checked
tsontag
Malfunctioning "Door Ajar" Indicator
1995 Mitsubishi Diamante, 140,000 Miles. While Driving (with All Doors Fully Closed And Locked), The "door Ajar" Indicator Lights Up On...
monkmom
MITSUBISHI OTHER
Malfunctioning Security Alarm System
1995 Mitsubishi Diamante, 10,000 Miles. Car Came With A Factory-installed Alarm System, But I Never Received A Remote Door Opener. The...
monkmom
MITSUBISHI OTHER
My 93 Chev Lumina Z34 Tranny Has Odd Shifting
I Currently Own A 93 Chevy Lumina Z34 (163,000 Mi). Im Having A Major Problem With The Transmission Not Wanting To Accelerate When I Get Up...
engaging_fear21
CHEVROLET LUMINA
1992 Ford Bronco 4x4 351ci Fuel Injected
My Charing Light Is On In My Truck So I Replaced The Alternator/regulator The Light Is Still On.I Checked Voltage At Battery With Truck Off...
tdwhiteIII
95FORD ESCORT DASH LIGHTS AND SPEEDOMITER
95ford Escort Lx 1.9 No Dash Lights. At First Rpm Lights Went Out And The Three Months Later All Other Lights Went Out. Checked All Fuses...
ISH
Ranger Running Issues
1988 Ford Ranger 2.6l V-6 Loses Power And Rpm's When At Cruising Speed (not Accelerating). When Accelerating The Truck Is Fine. It Also Does...
drharper1
1991 Chevrolet Blazer Has A Tick
I Built A 383 Stroker. It Runs Great. The Problem Is That It Has A Tick In The Passanger Head It Sounds Like A Lifter We Have Adjusted Them...
justin neitzel
Cooling Problem 1996 Mercury Sable
I Have A 1996 Mercury Sable Wagon With A 3.0 V6 With 120k Miles On It. The Problem I Have Is That I Have Change The Thermostat, Cooling...
Larry Garrett
MERCURY SABLE
Clutch Question
I Am 17 And Just Bought My First Vechicle And It Is A 93 Mazda B2200 Truck. It Is 4 Cy, 5 Speed And My Clutch Is Slipping Or At Lest Thats...
Rafuse
MAZDA TRUCK
1999 Grand Am Not Happy
I Have A 1999 Grand Am That Groans Whenever I Turn The Wheel. The Power Steering Fluid Isn't Llow But It's Very Frothy, Sort Of Like A Head...
gregoor78
Cooling Problem W/ My Police Cruiser
Need Some Advise I Own A 1994 Caprice Classic 9c1. Recently I Have Been Having Issues With The Vehicle Cooling Down Properly....
JOHN MAZZELLA
1993 Ford F-150 4x4, Shakes Bad
When Driving Down The Road The Truck Can Hit A Small Bump Or On A Right Hand Turn It Will Shake And Almost Take U Off The Road. It Is...
Stephen_dew1987
Hard Starting 85 Rx7
My 85 Rx7 Carbureted, 1.1 Liter, Manual Choke, Is Really Hard To Start When Cold. Have To Pump Gas Pedal A Lot And Start Maybe 10 Times...
fishingsocprof
1985
MAZDA RX7
Crankshaft Sensor Location?
Can Anyone Tell Me Where The Crankshaft Sensor Is On My 1993 Pontiac Grand Prix? It Has 3.1 L V6. Is It Something I Could Do At My Home Or...
Shane
1993 Jetta With White Smoke
I Have A 1993 Jetta That Has White Smoke Coming Out Of It When It Is Up To Temp In Idle. It Will Not Pass An Emmisions Test Also. I Am Not...
jodydavids
New Thermostat
Hello, I Have A 1993 Acura Integra With A 1.6l Dohc Engine. I Just Replaced The Thermostat And When I Took It For A Drive I Noticed...
nicurt
HONDA OTHER
1964 Chevelle Quits Running Then Starts Back Up
My 1964 Chevelle Has An Electrical Problem Of Some Kind. It Will Loose Ignition For A Period Of Time, Ranging From 1/2 Second To About 10...
deck52
1964
Stereo Radio Light Stays On
Stereo Radio Light Stays On After The Car Is Shut Off And Headlamp Switch Also Is Turned Off. Please Help.
hastingssfd
I Need To Know How To Work Out The Firing Order Of An...
Hi, I'm Studying A Car Mechanics Course At College And I Just Can't Get My Head Around Working Out What Each Cylinder Is Doing. Like The...
leetrials
Chevy 1500 Rear Disc Brakes
I Am Going To Help A Friend Replace Brake Pads On His 1999 1500. It Has 4 Wheel Disc Brakes. The Only Time I Have Worked On Rear Discs Was...
dbeckwith
About The Stick Shift On A Ranger
I Noticed That The Little Ball At The End Of The Shifter Is Missing, Could That Be A Big Part Of Why It Wont Shift Into Reverse? :
4x4guy1984
Window Falling Off Track! Honda Accord
I Cannot Get My Window To Stop Falling Off Of The Track On My Honda Accord. Any Fixes?
Jh_551
20191
20192
20193
