MY TRUCK WONT START
I Have A 1991 Isuzu Fsr Turbo Diesel! I Had It Sitting In One Place For A Month Once I Wanted To Start It, It Wont Start. The Batteries Are...
kaasikka
1999 Hyundai Accent
Hey I've Got An 99 Accent, About Almost 100k Km On It. Now The Engine Light Is On And Flashes When You Drive Over 40 Km/hr. Very Concerned...
melanie.trinity
HYUNDAI OTHER
2001 F250 Transmission Oil
I Have A 2001 F250 5.4l Auto 4x4. I Am Trying To Figure Out Whether My Transmission Takes Mercon Or Mecon5. Also What Lube To Put Into My...
yakowich
Struts
I Have Been Told That I Need Struts From Several Auto Shops, But When I Go To Buy The Struts Myself I Don't Know Exactly What To Buy. Does...
ngilmore34
MAZDA OTHER
IF INSTALLING....
If Installing A Throttle Position Sensor Do You Have To Reset Your Computer. And If So What Happens If You Don't. Also How Can You Tell If...
asno
85 F-150 Oil Question
Is There Any Way I Can Access The Oil Pump And Pick Up Tube With Out Droping The Transmission Or Pulling The Engine? The Secondary Oil Dirve...
planeguy
1985
84 Ranger 6cyl Cooling System Troubles
Ranger Was Not Building Any Temperature So I Replaced Temp Sensor Which Did Not Help Then I Replaced The Thermostat. Now I Am Building Temp...
tones1628
1984
Car Wont Stay Running
Hi All. I Have A 1991 Chevy Corsica. 3.1 Multi Port Fuel Injected. The Car Sat For 1 Year, And When I Put It Back On The Road The Car Ran...
razz kull
1991 Ford Tempo Problems
When I First Start Up The Car, It Starts Fine. After I Drive It For 10 - 15 Mins And Shut It Off, Then Try To Turn In Back On, The Amp...
Pyrrah316
FORD TEMPO
94' Escort LX Wagon Clutch
What Would Be The Ball Park Cost For Getting A Clutch Replaced On A 94' Ford Escort Lx Wagon?
Jbrake
1999 Jeep Clicking Noise (Transfer Case Problem?)
I Have A 1999 Jeep Grand Cherokee Laredo And Am Currently Hearing A Clicking Noise From The Front When I Brake. I've Had The Brakes Checked...
dierkinj
Overheated Now Wont Start
Have A Chevy S10 1987 Was Driven When It Over Heated And Died Now It Wont Start Turns Over Fine, Acts Like It Wants To Start But Wont
bungiejumper2
Starter R&r 1989 Park Ave
Need To Know If I Can Change The Starter On A 1989 Buick Park 3.8 Without Rasing Or Lowering The Motor The Starter Is In The Front Of The...
boots
Rear Demister Problem
1988 2.6 Lwb Petrol.I Have Had It Since New Now With 90000 Miles On The Clock. It Now Only Does About 2500 Miles A Year And Is Carefully...
jack2133
1996 Ford Contour V6, Lower Brake Only Lights Not...
1996 Ford Contour V6 Mileage: 59,000. When I Step On The Brake Pedal, My Brake Light In The Rear Window Goes On But The Other Brake Lights...
jamiecinco
FORD CONTOUR
95 Asto Van Fuel Pump
Will A Fuel Pump Go Out Instantly? And Do They Have A Fuse Under The Dashboard That Runs The Fuel Pump? Cause It Was Driving That Day And...
killagees
Sudden Drastic Gas Consumption
Hello, I Have An Older Car, A 1991 Corsica. I Typically Put $20 Every 3 Days In The Tank. However, In Just The Past Month, It Has...
OddChick
1993 Grand Am Misses Under Load
Hi, My 1993 Pontiac Grand Am, Quad 4, Distributerless Ignition, Misses Like Crazy Under Load, It Doesn't Matter What Speed Or Gear...
greenbay
93 Mazda Mx3 Will Not Start
The Mechanic Has The Car And They Have Tried A New Distributor And Coil Pack And They Said They Have Tried Everything To Try To Get It Too...
celica man
MAZDA MX5
92 Miata Losing Power
My Wife Recently Purchased A 92 Miata 5 Spd For 2k. Not A Bad Deal Over All And A Fun Car To Drive. The Problem She Just Had Was That She...
protector
'82 Rabbit Diesel, No Heat, Sweet Smell
I Was Driving One Day, The Heater Was Not Working, And The Engine Shut Down About 3 Miles From Home. It Turned Right Back Over And I...
alex_1978
1982
DTC On Hyundai Santa Fe 2.7
Does Anyone Know What U3118 Trouble Code Is For Also Po 081 Undefined Code Or Even A Co 300 None Of These Are In My Books Or Scanners. Any...
bturner
HYUNDAI OTHER
Trun Signals Not Working
Last Night, I Found That My Right Turn Signal Was Not Working. Actually, It Seemed To Be A Loose Contact. So, I Opened The Tail Light...
satrunsl296
97 Grand AM ABS Sensor Problem
I'm Thinking Of Buying A 1997 Grand Am. The Owner Says It Has An Abs Sensor Problem. Here Is What They Are Telling Me: " Has Some Abs...
abdlund
2003 Dodge Ram 1500 SLT Won't Start
Ignition Will Not Turn Over. Battery Is Low But Not Dead. A Red Light Is Flashing Just To The North West Of The Fuel Gauge. Before I...
alex_1978
20189
20190
20191
