1995 Pontiac Firebird
How Much Can I Expect To Pay To Get The R F Hub Bearing Replaced?
golfhans
PONTIAC FIREBIRD
1999 Plymouth Breeze Computer Swap
The Engine Computer On My Wifes Car Needs To Be Replaced And I Was Wondering If I Found One At A Junk Yard, Off Another Breeze, Would It...
onevatoloco
White Smoke Out Of Tail Pipe?
Hi Guys, I Have 91 Crx And The Question I Have Is, When The Car Is At Idle I Have No White Smoke Out Of The Tail Pipe But When I Throttle...
jbsantos
HONDA CRX
'04 Olds Alero Rattling Sound
I Hear A Rattling Sound From The Front End When Entering A Bumpy Driveway Or Uneven Pavement. The Car Was Checked By A Certified Mechanic...
jacquied
Transmission?
I Have A Mercuy Sable And Yesterday The Trani Quit Working, It Still Runs, Sounds Fine, But Does Not Go Into Gear, Could I Be Lucky And...
Denise Eckley
MERCURY SABLE
1988 Plymouth Voyager
It Starts Fine But When It Warms Up I Put It Into Gear It Shuts Off And Will Not Start Again Until It Sits For A Few Hours. The Diagnostic...
Somlamda
PLYMOUTH VOYAGER
93 Caddy STS OBD Ground
My 1993 Cadillac Sts Is Missing The Ground To Further Diagnose An Obd Code. Supposedly The Ground Is Sometimes Removed So That Only The...
donnels99
CADILLAC STS
Pontiac Clock Display
My Clock Display In My 1999 Pontiac Grand Prix Has Gone Out, I Was Told The Only Way To Fix This Was To Get A Different Radio Put In, Is...
Sparky
1993 Infiniti Q45 Fuel Pump
I Live In Nc And Am Looking At Buying The Above Mentioned Car, With 218k Miles. I Was Told That The Fuel Pump Needed To Be Replaced. Can...
SkankCheese
INFINITI OTHER
Will Not Start, Just Cranks
Will Not Start, Just Cranks And Here What I Have Done So Far: Good Fuel Pressure(36psi), Good Spark On All Plugs, Timing Is Correct, No...
2carprosuser
LINCOLN LS
88 Bronco 2 Fuel System Trouble
Hope Someone Can Help. Thing Cranks After 2 Or 3 Attempts And Runs Fine. Turn It Off For About 15 To 20 Minutes And It Won't Crank. Wait...
dls65
Ford Escort Idle Trouble
Hi There, I Posted This Subject A While Back And Still Havent Managed To Rectify The Problems I Am Having, So If Any You Could Help It...
Ash Blewer
1996 Chrysler LHS
My Lhs 3.5 Litre Check Engine Lite Is On When Checking The Code It Comes Up With A Code #66. Have Replaced The In Dash Circuit Board Already...
ppfrank
CHRYSLER LHS
Multiple Failures 97 Rodeo
I Have A 97 V6 2wd Rodeo With 133k Miles That's Causing Me To Pull My Hair Out. After A Recent Valve Job, The Transmission Failed...
amednick
2005 Chevy Aveo Stalls
I Have A 2005 Chevy Aveo, Has Only 10,000 Miles On It And Yesterday It Stalled Twice. I'd Only Driven 3 Miles From Home. The First Time It...
SharieGroot
96 Buick Century Problems Stalling Out
I Have A Problem With My Car Stalling Out As I Drive. It Cuts Out As If I Turned It Off While I Am Driving. If I Try To Restart It Right...
kazarnie
BUICK CENTURY
Fuel System Problem....
My Blazer Is A 2001 And Is Not Getting Enough Fuel To The Engine. I Have Checked Fuel Pump Pressure And I Have Replaced The Fuel Filter And...
dpogoap
Weird Starting Problem
When I Start My Ford Escort Zx2 1998 When It's Cold It Starts Up And Then Immediately Stalls, I Turn The Key And Try Again And It It Always...
Geordie
'93 Deville Showing E41 Code
Code 41 Showing (cam Reference, Signal). What's Up With That And What's The Solution. Just Replaced Distributor Due To Broken Coil Pick-up...
sgt1205
1992 Pontiac Grand Am Stalling And Revving
I Am Writing From Canada Yet We Are Having Quite A Mild Winter This Year. It Is Only -10 Degrees Farenheigt Tonight. Im Not Sure If This Is...
katjafallingstar
2003 Grand Am Squeaky Noise
We Purchased My Car New About 2 Years Ago And Haven't Had Any Major Problems With It. I Wrecked It About 6 Months Ago And Had To Have...
angelashley
Windstar 1996 Start Problem
My Windstar 1996 That Have Only 37300 Km, Have A Problem To Start After It Has Been Stop For About 1/2 Hour To 1hr And Sometime More But...
sylva1n
1992 Lincoln Town Car
I Am Considering Buying A 92 Town Car With 67000 Miles. Looks And Runs Great. Two Issues Of Concern. The 1st Issue Is The Climate Control...
gtabird88
LINCOLN TOWN CAR
1989 Honda Accord Misfires
My Car Misfires When It Is Raining And Not Fully Warmed Up. I Installed A Nwe Distributor Recently And Have Replaced The Distributor Cap...
shagman20
2001 Chevy Venture Blowing Oil Filter Gaskets
My 2001 Chevy Venture Keeps Blowing Oil Filter Gaskets. I Had Someone Tell Me That It Might Be The Oil Pump Reg. Value, Oil Pressure...
vkingdking
20188
20189
20190
