2001 Dakota Trouble Code P1391
The Stock Engine Blew Big Time. I Picked Up A Used Engine From The Junk Yard, Installed It And Now I Get A Hard To Start, Barely Running...
blvdbuzzard
Airbag Light On - 2004 Hyundai Sonata
We Have A 2004 Hyundai Sonata & The Airbag Light Stays On. How Can I Fix This Problem?
steiner9546
01 Grand Cherokee 6 Cyl Running Bad
I Went Shopping Yesterday And Everything Was Fine. When I Came Out Of The Last Store I Had To Go To I Started My Jeep And It Ran Like Crap....
mach73
Truble Codes
I Have A 95 Chevy 3500 Td, I Would Like To Know What The Truble Codes Are And What Connecters To Jump On The Test Port To Pull The Codes....
kickerskick
Problems With My 1999 S-10
I Have A 1999 Chevy S-10 And I've Been Having Problems With It, And I Need A Little Advice On What May Be Wrong With It. It Has 94,000...
deplachettW
97 B4000 Stuck In Park, No Brake Lites
My 97 B4000 Is Stuck In Park, I Changed The Brake Switch- Nothing. Bulbs Are Good. I Can't Locate A Fuse For The Brake Lights. Any Help...
vinny311
Ford #2 Cylinder Misfire
I Have A 1997 F150 4x4 With 4.6 V8. I Get The Trouble Code #2 Cylinder Misfire. I Have Changed Plugs, Wires, Injecors, Crankshaft Position...
helispaz
2005 Civic Hybrid Makes A Popping Sound
Recently I Ran Over A Big Rock And My Car Has Very Low Clearance. I Mean Like 8 Inches You Cant Even Get Under The Car So It High Centered...
guz920
Firing Order
Wires Got Mixed Up When Replacing Spark Plugs On An Alero, 3.4 Engine. Need Firing Order.
John Blake
Struts On A 98 Firebird
I Am Having Trouble Taking Off The Struts On The Front Tires. There Seems To Be A Trick To Actually Getting To The Top Nut To Disconnect...
jrobou1
1995 Chevy Corvette Overheating
I Have A 1995 Chevy Corvette. The Car Has 35000 Miles On It. It Runs Great On The Highway Or As Long As Its Moving. When The Car Is Sitting...
mdccrook
96 Grand Am 3.1, Oil Pan Removal
How Do You Remove The The Bolts On The Sides Of The Oil Pan To Remove Oil Pan? Engine Is Completely Against The Trans On Back Side. Can Not...
gweather1
89 Ford Festiva With Tranny/clutch Leak !
My Little All Around Car Has Recently Sprung A Leak And I'm Puzzled. I Thought It Was Engine Oil At First Because It Is Coming From The...
Bill Wahlers
FORD FESTIVA
1996 Tahoe
I Have A 96 Tahoe That Is Idling Rough And Will Hardly Run. I Just Changed Plugs, Wires, Cap, And Button And Its Running Even Worse....
bub
98 Dodge Neon
I Let My Neon Sit Outside During The Winter For ~6 Months Andtoday Was The First Time I Had It Back On The Road. I Gave Some Peculiar...
jnealy69
New Rear Sway Bar And Alignment?
I Recently Added A Rear Sway Bar To A Fwd 2000 Dodge Avenger Sport. This Car Only Had A Front Sway Bar Before This. I Have Been Told...
jonw
CHRYSLER OTHER
Focus2000 Got The Code, Now What?
P0420 - Catalyst System Efficiency Below Threshold (bank 1) Four Instances Of The Code Being Generated, Each Time Carchip Reports The...
jbrevard
1990 F-250 Fuel Issue
I Have A 1990 F-250 With The Dual Tanks. I Cannot Get Fuel From Either Tank. I Replaced The Fuel Relay Switch With No Different Result. I...
scpaisley
What Does ECT Mean
I Have A Hilux Surf Year 1998 Used Car In Japan. There Is A Switch Next To The Handbrake Lever. I Want To Know What Is The Function...
mpj111
1994 Mazda 323 WILL NOT START
Hi, My Girlfriend Has A Mazda 323 Hatchback Which Died About 2 Weeks Ago And Was Not Getting A Signal From The Distibutor. I Was In The...
picklesd45
MAZDA 323
1994 Ford Ranger 4x4
When I Try To Start My Truck It Doesn't Turn Over The Cellinoid Clicks And The Fuel Pump Is Working But The Truck Won't Turn Over. The...
vinnie
95 Toyota Camry Door Locks Malfunctioning
When The Car Is Either Being Driven Or Parked, The Power Door Locks Unlock Repeatedly At Any Given Time. If You Lock The Car. And Walk...
mitchellmoore
2000 Pontiac Sunfire
Hello Everyone I Could Use Some Help Please The Wife Has A 2000 Pontiac Sunfire With 41000 Miles Other Day It Would Naut Start. So I...
diamit
PONTIAC SUNFIRE
Service Engine Soon Light
I Recently Bought I 1998 Escort Zx2. The Car Seems To Run Great But Every Time I Put Gas In The Car The Chek Engine Light Comes On. I Went...
nickakendall
Shifting Back And Forth From Overdrive To 3rd
My New 1989 Cherokee Keeps Shifting Down Out Of Overdrive, Revs In 3rd And Switches Back To Od Quite Frequently On The Highway. When I...
matt_man
20186
20187
20188
