98 Dodge Neon
JNEALY69
  • 1998 DODGE NEON
I let my Neon sit outside during the winter for ~6 months andtoday was the first time I had it back on the road. I gave some peculiar symptoms:
1. Every time I stepped on the gas (soft or hard) there is a noticible "lag" and drop in power for the first cm of the gas pedal.
2. It sounds and feels like there are 3 of 4 cylinders firing so I though the gas had turned into water. I proceeded to add dry gas and some octane boost. Drove it for about and hour to an hour and a half.
No change. Except this, the check engine light came on and remained solid for the last ten minutes of the drive.
Questions, comments, criticisms welcome.
Do you
have the same problem?
Saturday, February 4th, 2006 AT 5:56 PM
JACK42
Could be a sticky injector
Tuesday, February 7th, 2006 AT 4:50 PM
Recommended Guides
