Fuel Line Problems
My '92 Subaru Legacy Recently Developed A Slow Gas Leak. It Only Leaks When It Runs Which Leads Me To Believe That Something Is Wrong With...
ACsubaru
SUBARU OTHER
1998 Ford Windstar - Oil In The Coolant.
My 98 Windstar Has Oil In The Engine Coolant. What Is The Possible Source?
RRichardd
Ford Focus Timing Belt
Can You Estimate How Much It Would Be To Replace The Timing Belt For A 2000 Ford Focus.
conorod
2001 Chrysler Sebring Humming Noise Turning Right...
I Have A 2001 Chrysler Sebring With 63k Miles. Whenever I Am Above 30 Mph, Especially In The 40 Mph Range, And I Make A Right Turn On A...
wendortb
CHRYSLER SEBRING
Pick Up Coil
Is The Ignition Coil And A Pick Up Coil The Same Thing
cgertken
MAZDA OTHER
Radio Got Loud And Full Of Static And The Headlights...
Hi, I Own A 2002 Dodge Ram Conversion Van, 1500. My Wife Was Stopped At A Red Light And All Of A Sudden The Wipers Turned On, The Radio...
dub143
2001 Grand Prix Heater Fan Switch
144,000 Kms. The Blower Motor Failed About 2 Months Ago And At Which Time I Replaced It With One Out Of A '02 Grand Prix. At That Time I...
bwhebby
Check Engine Light On Mazda 626 2000
One Morning, My Mazda 626 2000 Refused To Start. I Called Aaa Roadsie Assistance To Jump Start The Same. The Mechanic Found The Batteery Ok...
shekharbhonde
MAZDA 626
Catalytic Converter
I Have An Oldsmobile Cutlass Supreme Brougham 1985. Im Having Problems With The Pipe Coming Out Of The Catalytic Converter. Its Rusted So...
securis4
Explorer Starting Problem, Anti-theft Related?
I Have A '98 Explorer Xlt 5-speed. If I Short-cycle The Ignition Switch ( Release It Before The Engine Has Completely Started) While It Is...
DrEsquire
2001 Ford ZX2 Headlights
Hi, Recently, My 2001 Ford Zx2, 70,000 Miles, 100% Stock, Has Had A Problem With The Headlights - It Will Flicker And My Entire Set Of...
RockMonkey17
Newbi, First Post
Hey Everyone, I'm Awfully Glad That I Found This Forum. I Just Have A Couple Of Questions. So Let's Start Off Simply. This Diagnostics...
Ricer333
-Turn Signals-
Hi, I Just Recently Put In New Sockets For My Front Signals For My Honda Civic 93. When I Signal Left Or Right, All Of My Front And Back...
ambience8
1998 Monte Carlo Starting Problem
1998 Monte Carlo With 110,000 Miles On It. No Car Problems At All Since We've Had It, But Now It Has Been Slow To Start Recently. The...
hittle
CHEVROLET MONTE CARLO
Front End Or Tire
Need Help Hear Duh! My Sons Friend 1989 Aires Had A Front Rim Which Was Bent Up. The Boys Hammered The Rim The Best They Could. Can This...
gk3209
CHRYSLER OTHER
97 K1500 Truck Distributor Issues
I Recently Broke One Of The Dog Ears On My Plastic Distributor Where The Cap Screws Down To The Main Shaft. Apparently This Is A Common...
JMark
Stripped Keyway
1990 Montero - The Balancer Came Loose And Is Stripped Out Pretty Bad, The Crank Shaft Took Some Abuse - The Keyway Is Now Oversize In...
kpg
MITSUBISHI OTHER
1990 Accord - Acceleration Problem,/idle Control Valve
Fuel Injection/2.2 Engine/4 Cylinder According To What I Know, As Soon As The Vehicle Is Turned On About A Minute Afterwards The Rpm...
waffletown
Pontiac Aztec
While I Was Driving Today My Car Power Turned Off And Then Turned Right Back On. It Did This Twice. Is This A Problem With My Alternator?
dnordwick
Timing Belt
Had My Timing Belt Go On Me And Ive Replaced It But I Dont Know How To Position The Pulleys.(Finding Tdc)any Help In This Would Be...
harber5
CHRYSLER OTHER
1991 Honda Accord Wierd Idle, Fast Idle Valve?
For About A Year My 1991 Honda Accord With 230k Miles On Has A Wierd Idle Only When Warming Up. It Is Does Not Always Consistently Happen...
dtmfzr
1986 For Bronco 2
My Bronco Is Gettin No Spark At All When Cranked Over. I Replaced Plugs And Wires And Cleaned Out Distributor I Am Gettin The Coil Checked...
jonny12baseball
Holden Vectra
Hi All, I Was Wondering If Someone Could Help Me Out. I Have A 2001 Holden Vectra Equipe And It Started Making A Kind Of Thud Noise...
Sammy
HOLDEN VECTRA
97 Chevy Tahoe Shifting Problem
I Was Driving My 97 Tahoe And Went To Pass A Car And It Would Not Shift Out Of 1 Gear. It Will Go Into Drive Park And Reverse With No...
texasinglemom
1999 Blazer Heat Blowing Cold Air
The Heat Is On But Blowing Cold Air - Does Not Get Hot. Is It The Thermostat? 4.3 V6 Engine - Is The Thermostat Hard To Replace? Where Is...
larrydrude
20182
20183
20184
