Fuel Regulator
Car: 2000 Chevy Impala, Mileage:113,000. Engine Is Shutting Off Somewhat Intermittently When Gauge Teperatures Are Reading Normal.
smokiee
2004 Nissan Maxima
I Have A Strange Sound Coming From The Engine Of My Maxima Se. It Is A Constant Ticking Sound That Happens When The Motor Is Cold And Gets...
sponge27
NISSAN MAXIMA
Ranger Won't Start
Hi, I Have A 2000 Ford Ranger With 62,000 Mi. And The 3.0 Liter V6. After A Very Cold Night, About 20 Degrees Below 0 The Truck Won't...
shanes
Transmission Won't Shift
I've Got A 92 Ford Tempo With Automatic Transmission. After A Particularly Cold Night, I Warmed The Car As Normal But Discovered That When...
blaydet
FORD TEMPO
2000 Buick Lesabre Transmission Trouble
My 2000 Buick Lesabre With 50,000 Miles Shifts Very Hard From Park To Reverse Or Drive But Only When It Cold Out. Once The Car Is In Gear It...
jolvera04
BUICK LESABRE
Engin Light
I Have A 1991 Chevy Blazer 4 Wheel Drive 128000 Miles My Check Engine Light Keeps Coming On And Off I Cant Afford A Scanning Kit And Auto...
cms
Brakes On '99 Grand Marquis
Please Help! I've Changed Pads/rotors On A T-bird But Not On A Grand Marquis.I Can't Get The Pad Assembly Loose To Drop Down. Am I Trying...
John G.
Question Abt My 94 Honda Accord LX(140k)
Hi, Someone Pls Tell Me Wht Problem With My Car. I Fixed My A/c And Both The Fans Last Month. Bcoz Before I Had A Problem Like The Heat...
reejarejin
1997 Pontiac Grand Prix 93000 Miles
The Heater Fan, On My 1997 Pontiac Grand Prix With 93000 Miles, Only Works On High And The Driver Information Center Light Goes Dim Or Out...
wyatt james
1995 Ford Mustang
When My Cars Idle, The Engine Gauge Temperature Goes To Normal And I Have Great Heat - When I Drive The Car, The Engine Gauge Temperature...
Azreal14
Engine Immobiliser
Using Unchipped Key, Unlocks Car, Turns On Ignition, But Won't Bypass Engine Immobiliser
charlie56
LAND ROVER OTHER
2000 Dodge Intrepid Idles Low And Stalls...
I Have A 2000 Dodge Intrepid With About 107,000 Miles And When I Am Driving At Low Speeds (25-50 Mph) The Car Is Putting Out About 1500 Rpms...
Wilber
DODGE INTREPID
Trans Wont Shift Out Of 1st
I Have A 1986 S-10 P/u With 160.000 Miles. It Started Shifting Hard And Suddenly Wouldnt Shift Out Of First Gear. It Is A 2.8 Automatic W/...
timm
Lack Of Power And Hissing
I Have A 1995 Pontiac Grand Am Se At Over 150000 Miles. About Two Weeks Ago I Noticed The Car Lacked Some Power When I Pressed On The Gas...
txdomino
Ford Futura 1995 Auto
Tapping Noise Coming From The Engine
landmeat
Neutral Safety Switch
Hi, I Have Given My Car-buick Century Customs 11992 Model For Fixing The Neutral Safety Switch, But While Replacing It The Pin Assembly...
madireddy
BUICK CENTURY
No Power AT FUEL PUMP New Pump Not Working
1997 Pontiac Grand Prix Gtp 97000 Miles I Just Had A New Fuel Module And 2 Relays Installed By The Dealer For $1700 Now 1 Week Later...
jenny
93 Izusu Pickup Misses & Back Fires
Truck Usually After It Has Hits Operating Temp It Will Lose Power & Start To Miss. It Will Idle Perfect But Will Not Pull It's Self. If You...
bmpmoss
Auxiliary Fan
I Have Bmw 528i With 109000(1998). I'd Like To Check Out The Aux Fan Since It's Obviously Not Working. When I Turn On A/c It Not Funcioning...
nb0474
BMW 528
Secondary Fuel System Failure 91 Mustang 4 Cyl
I Have A 91 Ford Mustang With Approx. 93,000 Miles On It 4 Cyl Auto, While Driving Down The Road The Car Just Stops Running. No Warning...
junkyardjoe33
Air Conditioner Works Only In Cool Weather Conditions
I Have A 2002 Toyota 4runner 74,000 Mi. The Problem With My Air Conditioner Is That It Only Works During Cool Weather Conditions. It...
cases4him
92 Pontiac Timing?
This Question Involves A 1992 Pontiac Grand Prix Le, 150,000 Miles, And Has The 3.1 Engine, Automatic Transmission A Little History =...
5150
1980 El Camino Issue
I Am Experiencing Lights Dimming And Getting Brighter While Driving At Night. The Battery Light Is Also Coming On And Going Off While...
leonidast70
1980
1990 Nissan Truck Issue
I Am Smelling Gas When I Start The Truck. The Idle Then Increases From Normal To Extremely High. I Am Also Experiencing Bad Gas Mileage....
leonidast70
NISSAN TRUCK
4Runner Shakes When Breaking Downhill Only
My 2002 Toyota 4runner With 74,000 Mi. Has Started Shaking When I Break Downhill. It Does Not Shake When Breaking On Flat Ground (...
cases4him
20169
20170
20171
