Bypass Immoblizer For Rover620diesel Without The...
What Is The Key Fob?
charlie56
1962
LAND ROVER OTHER
Hard Starting
I Just Purchsed A 1994 Jaguar Xj6 From The Original Owner Who Was My Neighbor. The Milage Was 69,700 And Now Has 72,000 Miles On It....
bikewrydr
JAGUAR XJ6
Brake Pad Replacement Service Interval
I Was Advised And Had My Front Brakes Replaced On A 2002 Toyota Camry Le 5 Spd. Mileage: 36700 Miles. Is This Normal? Thank You.
Gerda
Renault Clio Engine Fault
Renault Clio 1997 1.4 8v Single Point Injection. 30,000 Miles. Hey Guys When The Car Is Pulling Away Or Accelerating From Low Revs It...
caledonia_112
RENAULT OTHER
1999-1/2 Jeep Cherokee Trans. Leak
On A 1999-1/2jeep Cherokee Lardo, Where Would Fluid Be Going If It's Not Leaking Out Of Tran? Owner Is Replacing Between 1 To 2 Qt. Per....
sgeer
2002 F-250, 66,500 Miles Stuttering Horn And Then...
I Have A Ford F-250 With 66,500 Miles With The Power Stroke Motor. My Horn Suddenly Started To Go Off With A Stuttering Sound. When I...
wdfblf
White Smoke From Exhaust
Could Be Oil Burning. Check Your Spark Plugs And See If They Are Faulty. Probably The Valves Or The Piston Rings Are Worn Out And They...
fisherman
HONDA OTHER
Ford Escort - Not Starting
My Mom Has A 95 Ford Escort With Approx. Miles Of 100,000+, It Will Crank But Not Ever Start. It Appears That The Starter Is Fine And The...
lishag
Dodge Dakota Will Not Idle
1996 Dodge Dakota Club Cab.3.9l V6. Orignally The Truck Would Not Start And Check Engine Light Came On. Replaced Wires, Plugs, Cap, Rotor...
pastorjeff
CHRYSLER OTHER
Blowing Windsheild Wiper Fuses
1985 Honda Accord. Just Started Blowing The Windsheild Wiper 15a Fuse. Is There A Way To Bypass And Run Straight Off The Battery?
pastorjeff
2001 Mk4 Golf Keeps Shaking And Struggling
When Accelerating My Car, It Keeps Shaking And Struggling To Accelerate. This Happens Whether I Am Driving At 20mph Or Even 70mph. Any...
nisha
97 F150 Overheated
Hi, I Have A 97 F150 4.6l 4x4 Manual. Now Here Is My Question. I Was Driving Home With The Heater On And Everything Was Fine When All Of A...
berg13
99 Ford Windstar Misfires
I Have A 99 Ford Windstar 140,000kms An Wen I Start It Sometimes It Misfires. I Changed The Spark Plugs The Spark Plug Wiring Harness And...
hmann
1991 Suzuki Samairi , The 2 Wires To Ignition Coil.....
One Wire Is Showing Hot R Lites Test Light. The Other Nothing.I Have No Fire At Coil Wire To Distributor. None To Plugs. No Fuel Pump Sounds...
steve_knox37849
MY CAR IS DYING! HELP! 91 OLDS CUTLASS SUPREME 3.1
I Have A 91 Olds Cutlass Supreme With A 3.1 Engine. A Few Days Ago It Started Stalling When I Would Idle Or Stopping At A Light Etc. I...
ibl84that
Heater Trouble On 97 Ram 1500
I Began This Season With Poor Heat. I Decided To Get A New Heater Core. Still Poor Heat, Except When I Use Recirculate. Recirc. Only Blows...
Striderdav
1994 Trans Sport
My Car Will Start The First Time After That I Have To Use Ether In The Carb, And When I Come To A Stop It Stalls Out And Then I Have To Get...
bullitt
Approx. How Many Miles Will The Car Go With NO Fluid ?
Help, If No Fluid Is Put In Radiator After Replacing It, About How Far Will It Drive Before The Motor Ceases? How Much Fluid Should The...
221cav
Truck Problems
I Have A 1999 F-150 4x4 With 70,000miles 4.2 Litre V-6, I Had A Valve Drop Into One Of The Cylinders, Which Led To A Broken Engine. Can...
toddski
Dead===all Dead
1997 Toyota Camry-135.000 Miles. Three Mos. Ago I Had The Thermostat And Water Pump Replaced. During This Replacement, Unbeknownst To Me...
tiana
What Is The Firing Order On A `93 Chev Lumina 3.1
What Is The Firing Order On A 93 Chevy Lumina. We Have The Block And Also Need To Know How The Cylinders Are Numbered.
jimmyp
CHEVROLET LUMINA
Shut Tailgate And Door Ajar And Dome Light Stay On?
My 1996 Explorer Has A Problem With The Tailgate. When I Shut It The Dome Light And Door Ajar Light Stay On. At First I Slammed It And...
timl
1991 Lincoln Towncar Shakes And Backfires While...
Hi, I Have A 1991 Lincoln Towncar Executive With A 4.6 Ohc V8 141,000m, I Have Had This Car For 4 Years And No Problems Until Now, I Was...
vdawg
LINCOLN TOWN CAR
Check Engine Light Troubleshooting
My 1999 Dodge Neon Highline Has 935000 Miles. The Check Engine Light Came On About 5000 Miles Ago (i'm Disabled W/ A Smaller Than Usual...
marti
CHRYSLER OTHER
2000 Olds Alero Turns Over But Won't Start
I Have A 2000 Olds Alero 4 Cyl. Turns Over But Won't Start. Replaced Fuel Filter, Can Hear Fuel Pump Running. Tried Spraying Starter Fluid...
wjbourre
20168
20169
20170
