92 Tercel temperature dropping problem
PETER411
  • 1992 TOYOTA TERCEL
Color=black]My girlfriends canadian 1992 toyota tercel has 230k kms and recently had a head gasket done.
Ever since, when you drive at freeway speeds for 20 minutes or more, the temperature gauge drops to almost the C (cold). It then sometimes raises slowly to a normal reading, in the middle. The thermostat was replaced once with the head gasket, and again approx 1 month later with no improvement. What could be causing this? Should I try a toyota brand thermostat? Is the temperature sender faulty? The heater seems to blow colder when the gauge reads low. Thanks[/color]
Do you
have the same problem?
Saturday, March 4th, 2006 AT 1:25 AM
KGOPEL
I'd try a new thermostat.
Sunday, March 12th, 2006 AT 1:26 PM
Recommended Guides
