1995 Dodge Caravan @150,000 K Nop Shift Out Of First
How Are You Doing?First Off Great Page, Tons Of Info. On To My Question.I Have A 1995 Dodge Caravan Se With 150,000 K 3.0 Litre With A 3...
durs845
Smoke...
I Have A 1997 Ford Escort, {stick Shift}this Morning I Drove Home From Delaware And The Car Was Fine When I Turned The Car Off I Noticed A...
AMBEGABE
Stalls With Accelleration... Toyota
1998, Toyota Corolla, 140k. Recently, My Car Started Lunging When I Tried To Accelerate (it Felt Like It Wanted To Stall But Didn't) But...
Shadowlaw5
Speedometer Quit Working
:( : 99 Taurus Stn Wgn Mileage Too High 174000 Just Until Last Week No Problen And Of Course As Soon As Paid Off Warranty No Good My...
taureankat
F-150 Fuel Filter
I Have 1997 F-150. My Fuel Filter Started To Leak. Iremoved It But Found One Of The "o" Rings On The Up Stream Side Was Split. Can I Simply...
fawnbuster
1915
How To Replace A Clutch In A Honda Civic
What I Realy Want To Know Is How Hard Is It Going To Be, And What Do I Realy Have To Do To Replace It. Is There Any Certain Trick To It Or...
sab1919
95 Grand Prix Overdrive Behaves Like Neutral
My Gp Is Mint With Only 85,000km. It's Powered By A 3100 And Geared Via 4t60-e. When Running In Overdrive (d) The Rpms Stay Around 3000...
GrandPrixNewbie
1993 Plymouth Voyager Oil Leak
I Have Recently Incountered A Pretty Bad Oil Leak On My 1993 Plymouth Voyager. Like One Hour Of Driving On The Freeway And I Am Out Of Oil...
ssoutherton
PLYMOUTH VOYAGER
99 Dodge Ram Serpentine Belt-Related Problem
I Began To Hear Screeching In My Engine With Occasional Clicking At Random Times. I Thought The Screeching Was The Belt And Replaced It...
Hawgstruck
Tail Lightand Headlight Problems In 1994 Pontic Grand...
Having Problems With Lights On 1994 Pontiac Grand Am Aprox 150000 Miliage. Headlights Won, T Go From Bright To Dim And Now Both Tail Lights...
moonmad
1994 Dodge Dakota Possible Electrical Or Fuel Intake...
I Have Been Haveing Trouble With The Fuses Under The Hood Constently Blowing, The Last Time They Blew Out, & I Replaced Them The Truck...
cybersurf
Toyota Camry Wont Start
1989 Toyota Camry With 275,000 Miles Wont Start. It Has Been Parked For Over A Year As We Were Deciding What To Do With It. Now Trying To...
rkey
Starter/Fly Wheel
Ford F 150 Custom 1981 125,000 Starter And Fly Wheel Stay Engaged After Engine Starts;replaced Starter And Got Same Results. How...
MBarger
#4 Cyl Misfire - 2002 Taurus OHC 3.0 117k Miles
Engine Runs Fine Except On The Second Start-up In The Day When The Engine Runs Rough At A Stop Light (idle) And The Engine Light Flashes....
SailorMan
How Do I Change Spark Plugs On A 2001 Pontiac Grand Am...
I Can't Find In The Chiltons Mechanical Manual On What Must Be Removed To Change My Spark Plugs And Wires.
karen mennem
My 1997 Probe 2.0L Engine Swap
How Hard Is It To Put The 2.5 L V-6 In My 2.0l 4-cylinder Probe
milner142790
FORD PROBE
Hood Release Cable
1990 Chevy Astro Van(145,000) Hood Release Cable Snapped. Cant Open Hood. Any One Know How To Open It Manually? Installed A New...
nad
4x4 Trouble
94 Ford Bronco 4x4 Full Size, 302 Engine Stuck 4x4 Low
csmoring
My 1997 Forde Probe 2.0L
My '97 Probe Has A Loud Ticking Noise From By The Injectors When It Is At Running Tempreture, Is There Anything I Can Do To Fix This...
milner142790
FORD PROBE
Truck Will Bump Start But Won't Jump Start?
My 95 Gmc S15 Pickup Won't Start. Battery Is Less Than 2 Yrs And Has Good Voltage Reading, Starter Is Less Than 1 Yr And Have Had It...
Pigeon_1969
Car Tries To Start Hooking Up Battery With Keys On...
94 Ford Escort 1.9 Liter 100,000 Miles When Hooking Up The Battery The Car Tries To Start With The Keys On The Floor. What Would Cause This...
stupidwithwires
1988 Chevy Truck Sputters When You Rev No Power
I Have An 88 Chevy Truck With I Believe The 350. I Removed The Throtle Body Off My Truck And Put It Into My Friends Who Has The Exact Same...
tucsonluthier
1986 Ford F150 Brake Problem
1986 Ford F150 With 120,000 Miles. Brakes Were Fine Unitl Front Coil Spring Broke. Brake Light On Dash Came On And Truck Was Hard To...
pjaska
Car Begins To "shake" At 45mph
Yes, I Have A 1995 Toyota Corolla (5 Speed). I Recently Had A 4 Wheel Alingment, And The Brake Line Bled Some. I Had Put Too Much...
kittengirl
1945
Ignition, Key Will Not Turn Past Stage 1
I Have A 325i Bmw 1989.213,000kms It Was Perfect Then I Tried To Start The Key Would Turn To Stage One That Works Radio, Wipers...
jsheret
BMW 325
20136
20137
20138
