Multiple Problems For Dodge Pickup
1997 Dodge Ram 1500 8-cyl 5.9l Mileage: 124614. I Have A Number Of Problems With My Truck. First, My Truck Is Leaking Antifreeze...
cutdogg
Brake Lights
Whenever I Turn The Key On My Brake Lights Come On And The Only Way To Get Them To Go Off Is To Unhook Battery
cavguy1964
Starts When It Wants To.
2000 Ford Mustang Gt (57k). A Week Ago It Wouldnt Start On The First Try But It Did On The Second. A Couple Of Days Ago It Took Several...
ferby
2000 Camry Noise/vibration
I Have A 2000 Camry Xle V6 138000 Km. While Accelerating I Get A Noise/slight Vibration From About 2600-2900 Rpm. Only At Those Rpm's. The...
unidad
05 Kia Spectra 38000 Mi. Rear Brakes
How Do You Remove The Rear Calipers From An 05 Spectra Ex. I've Removed The Bolts From The Calipers And The Dust Cover And It Still Won't...
smj690
KIA OTHER
ABS
Hello I Have A 2002 Sebring And When I Brake It Pulls Back At Me. When I Start My Car It Accerlates Pretty High. I Was Wonder What Is...
butterfly_ars
CHRYSLER SEBRING
Buick Regal Custom Brake And Transmission Problems
I Own A 1996 Buick Regal Custom 3.8 With 180000 Miles On It. The Service Engine Light Came On.I Had It Scanned And The Code P1870 Came Up....
Reginatemples
BUICK REGAL
1997 Nissan Altima, Stalling
Hi All, I Have A Problem With My Nissan Altima 1997 Model Car. It Stalls On Me. I Thought It Might Be The Fuel Filter, Changed It...
manujohn
Blown Piston
I Purchased A 1996 Ford Taurus Wagon From A Reputable Car Dealership With A 90 Day Warranty. I Started Having Problems Immediately With The...
Sean S
1999 Ranger Power Steering Noise
Hi I Have A 1999 Ford Ranger Sport 2 Wheel Drive With 72500 Miles. I Have Noticed Latley That If I Turn The Wheels Left Or Right When It Is...
kurt burda
Transmission Fluid Replacement
Vehicle Is 1999 Ford F250 4x4 With About 79,000 Miles. The Manual Says Not To Use A Fluid For Dual Use Such (mercon And Mercon V)....
brgypsyeyes
95 Ford Probe 2.0 4cyl. Cluch Problem
My Cluch Pedal Went All The Way To The Floor And Im Not Sure Exactally Which Part Has Failed. The Cluch Master Cylinder Or The Slave...
glassman
FORD PROBE
Squeking Sound When Car Starts
I Have A 92 Honda Accord With 213,000 Miles On It And Recently Had The Timing Belt And Tensioner Replaced About 4 Months Ago. For About Two...
actionj4614
Fuel/ Rear End Dif
I Have A 89 Ford F-150 2x4 And There Is A Grinding Noise In The Rear Dif (limited Slip) When My One Tire Spins And Someone Told Me I Have To...
Hutch 88
1993 Mercury Villager Brake Rotors
Could Somone Please Tell Me How To Remove The Front Brake Rotors On A 1993 Villager. I Have Had No Luck Getting Them To Budge, Thank You...
jimth
MERCURY VILLAGER
Truck Stalls
My Truck Trys To Stall Or Actually Stalls When I Get Sprayed Under The Engine. What Are The Causes For This?
bartonm
EAGLE VISION
02 Grand Am Problems
Car Sometimes Will Start And Run Fine. And Sometimes It Will Not Start At All. And Sometimes It Will Start And Run Bad. Like It Is Losing...
makenzie
Tierods
Tie Rod End Broke Off The Tie Rod Can I Remove The Tie Rod
craigdars2563
1999 Ford Taurus SE Low Coolant
1999 Ford Taurus Se, 24v Dohc, 80000 Mi. My Low Coolant Light Came On, I Put In Coolant, It Went Out (so Sensor Is Ok). It Came On...
SpacemanStu
Heater Blower
2001 Ford Focus The Low Speed Setting On The Fan Control Are Not Working. Is There A Second Fuse For The Low Speed Setting?
woodman442
97 Chevy S10 Blazer 116,000 Miles
'97 Chevy S10 Blazer 116,000 Miles I'm Having A Problem Removing #3 Spark Plug. It Is Located Right In Front Of The Steering Column...
brios71
Car Makes A Buzzing Noise When In Motion.
I Have A 2002 Chevy Monte Carlo Ss With About 59,000 Miles On It. The Problem Is, When I Am Driving About 30 Mph Or More, My Car Makes A...
michaelmontoya
1992 Pontiac Grand Am SE 4 Cylinder
Okay This Car Started Fine This Morning, I Was Driving For About An Hour, It Stalled Out. I Started It Back Up Then It Would Only Go About...
tazz5893
1995 Tracer 1.9L Cooling Fan Okay But Won't Run.
:we're Pretty Sure The Relay Is Okay, Too. Is There A Temperature Sensor On The Engine That Acts As A Switch For The Relay Or Does It Go...
blockhart329
Headlight Assembly
Hi; I Have A 1992 Dodge Caravan 130000mi. That Needs A Bucket That The Halogen Builb Screws Into. I Have Got A Good Used Assembly But I...
jjwg03
20134
20135
20136
