Fuel/ rear end dif
HUTCH 88
  • FORD F-150
I have a 89 ford f-150 2x4 and there is a grinding noise in the rear dif (limited slip) when my one tire spins and someone told me I have to add an additive to the dif is this true, also I just changed my gas tank and the white clip broke on the return line and I put the hose on and my truck will not start and when I stop turning it over the return line spits out gas towards the tank do I have to buy a new clip to hold in on better?
Do you
have the same problem?
Monday, March 13th, 2006 AT 7:39 PM
RAYHUT
Yes you will have to add and buy.
Tuesday, March 14th, 2006 AT 5:35 AM
Recommended Guides
