How to Replace an Automotive Heater Core
A heater core is positioned inside the car and is part of the HVAC system. Hot engine coolant is run through the core which air is blown through via the blower motor which provides heat for the passengers.
What Goes Wrong?
When a heater core fails it can do so in one of two ways, either the core can become plugged due to poor cooling system maintenance or it can leak allowing antifreeze (coolant) to be present on the passengers side floorboard. This will usually be accompanied by a foul odor being expelled from the ventilation system.
Cost to Replace?
The heater core itself should cost about $120.00 (US) depending on application. The labor is the tricky part, some heater cores are easily replaced while others seem like the car is built around them, so it is important to know the labor time before you get started or have the core replaced. Also, most core replacement will require the air conditioner system to be vacuumed down and recharged. This is because the evaporator core is included in the HVAC plenum which will be removed along with the heater core. Using a resource like AllData will help show you step by step how to do the job (specifically), additionally they show labor time, cost and part numbers to the parts needed to do the job. If you have additional questions our 2CarPros experts are here to help (free).
Replacing the Heater Core
The following guide shows what needs to be done when replacing the core which can be used to see what you are paying for when the job is being done by a shop, or what you are in for when doing the job yourself. (It helps to visualize how the dashboard was installed at the factory).
Start with the engine cold, wear appropriate clothing and safety gear (goggles, gloves etc.). Remove the negative battery cable, move the cable end far enough away to avoid an accidental connection. (Cars 2017 and newer may need a CAN memory device connected to preserve settings). Allow a minimum of 10 minutes before working with the airbag system.
negative battery terminal removed
Release the radiator cap (engine cold), and loosen the radiator drain valve or remove the lower radiator hose to drain the cooling system, have a fluid catch basin ready.
coolant draining
Most vehicles utilize a common plenum for both heater core and evaporator core, these types will require the refrigerant be evacuated from the system, once evacuated, disconnect heater hoses and necessary air conditioner hoses (lines).
drain refrigerant
Using the hose clamp removal tool, loosen and remove the heater hoses from the heater core inlet and outlet fittings. Check the condition of the heater hoses and replace if needed.
remove heater hoses
Locate and remove upper dash mounting screws. Remove any mounting hardware across the top of the dash assembly, which is usually covered by pop-in trim pieces along the base of the windshield.
removing dash screws
Locate and remove the lower dashboard mounting bolts. (Note: Some vehicles require the center console to be removed to access center mounting bolts.)
removing lower dash mounting bolts
Use a small socket or screwdriver to remove mounting screws to the lower bezel allowing access to the lower steering column mounting bolts.
removing lower panel
You will need to lower the steering column to allow dashboard clearance. This is done by removing the shift indicator cable (if applicable), then removing the nuts/bolts that hold the column to the dash assembly. This will allow the column to become loose from the dashboard, in most instances allowing the column to rest on the drivers seat will supply sufficient room. Locate the left side dashboard mounting hardware and remove.
remove steering column mounting bolts
The dashboard should now be loose from the vehicle with nothing but electrical connectors or vacuum lines, gently pull the dashboard away to inspect.
dashboard removal
Slowly pull away from firewall while keeping an eye out for any wiring or vacuum lines, once back far enough support (hang) dash assembly in a position that will allow for enough room to remove the HVAC plenum.dashboard removed
The HVAC plenum will now be exposed.
heater plenum
Remove electrical connectors from the blend door actuators, temperature sensors, blower motor also, remove any vacuum lines if equipped  (use your cell phone to snap pictures of the wiring if needed).
removing vacuum lines
Remove ductwork including windshield and mid-vent distribution ducting. Locate inner heater plenum mounting bolts and screws to remove them.
removing mounting bolts heater plenum
Inside the engine bay, locate the heater plenum mounting bolts and remove. This will allow the heater box plenum to become free of the vehicle which will allow removal of the unit.
removing outer mounting bolts
Gently pull backwards on the plenum assembly (this can be stuck slightly due to sealing gaskets from the firewall to the plenum). Keep an eye out for anything that you missed, then remove the HVAC plenum from the vehicle. Again use your cell phone to take shots of the assembly to ensure proper reinstallation. (There might be coolant leaking from the heater core so use an old towel to help control spillage.)
removing heater plenum
Place the HVAC plenum assembly on a suitable work area for disassembly.
heater plenum removed
This is what it looks like after the HVAC plenum has been removed. On this application you can see the air condition evaporator core which did not need to be removed in this instance.
To remove the heater core the plenum will need to be disassembled. Locate and remove plenum screws to dissemble and gain access to the heater core.
disassemble heater plenum
Gently pull the plenum open to expose the heater core.
Remove the mounting screws holding the core to the housing.
remove heater core mounting screws
Remove the core from the housing mounts.
remove heater core
Match the new heater core to the old core to ensure a proper installation, reverse these steps to reassemble. Ensure the heater core hose connections are in good condition (round with no dents, this will allow coolant to leak). In our shop we would test for leaks before installation. Use caution when installing the heater core, these units are made of thin metal and plastic and are easily broken. Clean and inspect the HVAC unit to make sure seals and gaskets are reusable and in good condition, reassemble the HVAC plenum accordingly.
new heater core
Reassemble heater plenum and reinstall connecting all hoses, wiring connectors, control cables and vacuum lines using the cell phone pictures from earlier. Reassemble completely by reversing the order.
Refill with coolant and start the engine while adjusting the heater to the highest setting while topping off the coolant.
After completing the job, recharge the air conditioner (if needed.) Recheck the system for leaks while testing the blend door operation, verify all dash functions operate properly.
Questions?
If you have a car repair question, you can ask the 2CarPros community for help. We hope this guide helped you understand the repair. Please visit our 2CarPros YouTube channel for more helpful repair videos.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
