Fuel filter location?
LIANECHU
  • 2002 FORD RANGER
Where is fuel filter located on 2002 extended cab Ford Ranger 2.3 L?
Tuesday, April 14th, 2009 AT 7:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Under driver side of vehicle mounted on fuel rail. Disconnect negative battery cable. Here is a guide so show you what you are in for and a video to help you release the fuel lines from the filter with diagrams below to show you the location:
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
and
https://youtu.be/Boi0DPXVHbM
Thanks for using 2CarPros.com!
Tuesday, April 14th, 2009 AT 10:30 PM
BILLY PRIDE
  • 2002 FORD RANGER
  • 6 CYL
  • 27,000 MILES
Where is the fuel filter for a 2002 Ford Ranger Extended Cab? Will this cause the truck to not start after running for awhile. Truck starts intermittently. Looking for direction to start first.
Saturday, August 25th, 2018 AT 3:24 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Check for fuel pressure
it should be 40 to 55 PSI .
Check for codes
Check for spark after it fail to start.
https://youtu.be/YV3TRZwer8k
CJEFF34
  • 2002 FORD RANGER
Four cylinder two wheel drive automatic.
I do not know where the fuel filter is located. Can you help me?
JEEPFAN
  • 135 POSTS
The fuel filter should be located on the drivers side on the frame back towards the gas tank.
Slide under the truck in front of the back tire and look on the inside of the frame you will see it.
RANGEMAN
  • 1999 FORD RANGER
  • 4 CYL
  • 125,000 MILES
Where is the fuel filter on 1999 Ford Ranger?
MJR346
  • 132 POSTS
Left frame rail just below drivers door.
  • 108,348 POSTS
Driver's side mounted on the frame rail.
GONZO1347
  • 2000 FORD RANGER
  • 6 CYL
  • 120,800 MILES
Where do I find the fuel filter on my 2000 Ranger? Is it on the bottom of the engine, or somewhere else? Thanking you in advance.
MERLIN2021
  • 17,250 POSTS
Most Fords it is on the frame rail
ROB2008
  • 258 POSTS
Under vehicle, driver side, below seating area, front of fuel tank, mounted on frame rail in fuel line. Check out the images (Below). Please let us know if you need anything else to get the problem fixed.
JEREJANET
  • 2000 FORD RANGER
  • 6 CYL
  • MANUAL
  • 68,900 MILES
Where is the fuel filter located on this vehicle and can it be replaced apart from taking it into the Ford Dealer?
The truck turns over well, but will not fire. Pumping the accelerator and continual turning over the engine will eventually cause it to fire, but lope terribly, until the engine warms up a bit then the engine will run normally, and start promptly until it cools off when left sitting for a period of time. I also have the check engine light showing now.
Any help appreciated, I am leaving Hawaii and want to sell the vehicle before I leave. I do not want to pour a lot of money into repairs.
Jere
Saturday, August 25th, 2018 AT 3:25 PM (Merged)
98RANGERXLT
  • 301 POSTS
Under vehicle located underneath the drivers door. You can do it yourself but you need a special tool that ford makes, as for the check engine light if you have an AutoZone in Hawaii get the codes and post them here.
QUINTT
  • 2000 FORD RANGER
  • 4 CYL
  • MANUAL
  • 130,000 MILES
My truck seems to hold back when laboring a hill or higher revs. Could this be fuel filter? If so, where is it and do I need special tools? Many thanks. Q
98RANGERXLT
  • 301 POSTS
It is located under the seating area bolted to frame inline and yes you need special tools.
CAMERON6890
  • 2003 FORD RANGER
  • 4 CYL
  • MANUAL
  • 75,000 MILES
I know my fuel filter is located on my frame on my driver side, but I was wondering how I would change my old fuel filter with looks like it has not been changed since 2003 with a new one I just picked up from checkers?
DAVE H
  • 13,383 POSTS
Removal and Installation:
Note:There is an early and late build version fuel filter. The procedure is similar for both.
Disconnect negative battery cable. Release fuel pressure. See FUEL SYSTEM PRESSURE RELEASE . Remove fuel filter fittings. See FUEL LINE CONNECTORS . Remove fuel filter from bracket. See Fig. 88 . If necessary, remove the nut and the bracket. To install, reverse removal procedure.
Fig. 88: Removing & Installing Fuel Filter (Late Build Shown; Early Build Is Similar)
Courtesy of FORD MOTOR CO.
https://www.2carpros.com/forum/automotive_pictures/266999_filter_1.jpg
KEBON77
  • 2002 FORD RANGER
  • 4 CYL
  • MANUAL
  • 90,000 MILES
I need to replace the fuel filter on my 2002 Ford Ranger. Could you please provide the steps?
Sunday, August 26th, 2018 AT 10:27 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2003.jpg
