Car stall while driving?
22JJW22
  • 1996 TOYOTA CAMRY
  • 2.2L
  • 4 CYL
  • 186,000 MILES
Can anyone give any suggestions on this? It usually runs great except if it is raining and it will die and will not start back until it has sit for awhile. Only code it gives it is p1300 we have replaced igniter & distributor.
Saturday, January 24th, 2015 AT 4:46 PM
  • 108,289 POSTS
When this happens and it doesn't start, do you still have spark to the plugs? It could be several things, but I feel it has to do with a poor connection between the distributor and electronic control module (ECM).
this guide can help us fix it
https://www.2carpros.com/articles/engine-stalls
Saturday, January 24th, 2015 AT 6:06 PM
AGGIEGIRL
  • 1996 TOYOTA CAMRY
I have a 1996 Camry, automatic, with 241,000 miles on it. I have taken good care of it over the years, but it's giving me grief now. After I come to a stop and then try to go again, it either acts like it's going to stall, or actually does stall out. Today was the first day it actually did the stalling out, previously it just felt like it was going to die. I'm terrified to drive it now. It stalled three times today. I had it in the shop and it tested out fine on the computer and some other checks. What might be the problem? I had the IAC replaced two years ago and the throttle body cleaned at that same time.
Thanks for any advice you may be able to give.
Thursday, June 18th, 2020 AT 9:56 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
I think you should start by cleaning the IAC and throttle body
It’s very common on them Toyota
Good luck
Let us know
CHRISSLAIGHT
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 149,800 MILES
My Camry (1996 LE four door) has a stalling problem when you accelerate too fast or go onto the highway. It's not while your driving, but when you go to stop. The car's RPMs will drop really hard and the slower you get, the engine will slowly sputter out. The rpm goes down to 200 and the car shakes a lot. The car will then struggle for a few moments to stay on and bounce between 200 and 500 rpm before finally shutting off and displaying the check engine light and the oil light. Then, I just put the car in park and start it while giving it some gas and it starts up and runs fine.
It all started after I accidentally skimmed a large puddle and was particularly bad in wet weather for a while.
I had a mechanic look at it and they replaced the distributor cap and wires saying they were bad and causing it, but it returned the next day.
I noticed that when I avoid the highway and keep the rpms below 3000 when driving, it doesnt happen. I also put the a/c on if I think it's idling too low to keep it running.
My research has led me to believe it's either a dirty EGR valve or a bad fuel filter.
The car has 149,800 miles with new spark plugs and I just got an oil change.
Please help, thanks!
Thursday, June 18th, 2020 AT 9:57 AM (Merged)
STALLING96CAMRY
I too have the same problem with my 1996 toyota camry. I have also read various posts on the internet about the same problems with this year/model.
What happens to my 1996 camry is sometimes when I hit the brakes the cars rpm's start to fluctuate up and down rapidly. More downward then up, as if it is having a hard time keeping the idle. Then if I dont step on the accelorator to give it gas and get the rpm's up, it will stall. So sometimes I find myself at a stoplight with one foot on the brake and the other on the gas to keep the rpms steady and from dropping and stalling. Lately the car is doing this more often. Everything else on the car runs great.
I have tried to have it fixed by 2 differant mechanics. They both didnt know exactly what the problem was but one who is a friend of my family and very honest tried to clean out the fuel injectors, change some plugs, change the idle rpms. None of this worked. His computer also read "multiple missfires" from the code from my cars check engine light. The other mechanic said the problem was a cold start valve, he changed this on my car but it was not the answer. All that did was have the car start great but still having the same prob
PLEASE HELP: I know this is a common problem with this car from what I have been reading. CAN SOMEBODY WHO HAS FIXED OR CORRECTED THIS PROBLEM OR KNOWS HOW TO PLEASE TELL US HOW?
THANKS.
IBM650
May be the coil in the distributer, it has been noted by others, you need to also replace the little o ring. Use a genuine toyota coil. Let me know, I will be changing mine soon.
BALKY
I have this exact problem with my Camry. And I have looked on this forum and found 3 others with same post. But no solid solution.
Best response I have found is this one that it may be the distributor coil.
I replaced mine and it didn't seem to fix the problem. However, I bought a used one and didn't replace the small o-ring which is required per repair instructions. I may have replaced my problem with another problem. I don't want to go through this again if this isn't the cause of the issue.
Hopefully an answer will arise on these threads soon.
IBM650
Apparently may be an issue with toyota, probably best to clean it, Toyota seems to have quality problems with this part.
AWENDS86
Hey did anybody figure out what was causing the car to stall? My 96 camry is doing the exact same thing now. I drive it on the highway and when I stop or slow down the rpms will jump from 500-700 then to 0 and stall out. It only happens after driving on the highway and doesn't happen all the time. I had the spark plug wires changed and the throttle body cleaned, I then drove the car cross country and the car only stalled once after 2k miles of driving. It is now doing it more and more.
TCAMRY89
  • 1996 TOYOTA CAMRY
  • 181,995 MILES
I have a 94 toyota camry and it just stop working while I was driving. I pused the gas but the spedometer kept going down then my battery light came on followed by the oil light and when I tried to push the brake the brake wouldn't work so I had to use the emergency break nos its making the sound like it wants to start but its not turning over. Please tell me what's wrong with my car!
SAHIL99
Please help
Review this link and then let me know what you have: https://www.2carpros.com/articles/car-cranks-but-wont-start
TCAMRY89
@ rasmataz The link is helpful but it requires a device that I do not own. But thank you
  • 52,797 POSTS
Those toyotas are very reliable cars. When this issue happens, the most likely cuase in my eyes is a broken timing belt. When did you have it changed last?
Luckily, it is not an interference motor and can be changed with no possibility of bent valves.
Have a shop check it for you to confirm.
I am assuming it is a 4 cylinder
TCAMRY89
@ asemaster6371 I honestly don't know but I do know that it is a 4 cylinder. When I bought the car it was used and the guy I bought it from said everything was either new or fixed since then I've been back to that place 3 times for them to fix things the right way. My dash lights weren't working when I first got it and I couldn't unlock my door from the driver side only the passenger side. Btw if anyon is around ct and looking to buy a car do not I repeat go to bouelvard motors in new haven.
TANGOROMEO89
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 144,000 MILES
I drive a 96 toyota camry with about 144,000 miles on it, I was driving it the other day and I went to go press the accelerator and nothing happened, it just coasted. The check engine light and oil light went on as I was coasting, the radio was still on and everything and it had a full tank of gas. As it was coasting I pulled to the side of the road and turned it off and put it in park, tried starting it again and all I heard was the starter winding. I had a friend come by and he thought it was either the fuel filter/fuel pump because it didnt seem like fuel was getting to the engine for it to start. Someone help please, thank you.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
  • 52,797 POSTS
Ok, you still need to find a solution. You need a shop, another shop, to check it for you.
SPLANCH
  • 6 POSTS
  • 1996 TOYOTA CAMRY
96 Camry 4 cyl - 70K - Car stalls when I stop occasionally - No Check Engine Light On, had a major tune up around 50K miles. Car will also hesitate when accelarating then will catch up - Just had Fuel Pump, and Timing Belt service done.
Car will take a couple of tries to start - I check all connections and can get it to turn over - Also ran at 2000 RPM in Park - Put into to Drive car stalled
Bringing in for Service on Weds 11/21 - I need some suggestions
Check the idle air control valve, throttle position sensor, EGR, and fuel pressure.
