HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Engine
Symptoms
Stall While Driving
Stalling after starting?
PREV
1
2
NEXT
KEN L
MASTER CERTIFIED MECHANIC
Yep, you can be correct, test the compression and inspect the plug plugs as they are removed which can help tell you which cylinder is having the issue. These guides can help
and
Please go over these guides and get back to us.
Sunday, July 27th, 2025 AT 11:01 AM
NETDALE10
MEMBER
So I’m back with the head cylinder pressure readings on my 2004 Honda Civic EX
They are as follows:
#1 cylinder 175 psi
#2 cylinder 220psi
#3 cylinder 195psi
#4 cylinder 195 psi
Now I need to add something interesting and points to the obvious.
Water sprayed out of cylinder #2
Monday, July 28th, 2025 AT 12:16 PM
KEN L
The compression readings are good, but you mentioned coolant shooting out of the #2 spark plug hole, this is a sign the head gasket is blown. FYI.
Monday, July 28th, 2025 AT 12:51 PM
NETDALE10
MEMBER
Of course. I have started the removal process
Thank You
Monday, July 28th, 2025 AT 12:55 PM
KEN L
Sounds good, please post a new question if you need help with the head gasket.
Monday, July 28th, 2025 AT 1:33 PM
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
Car "died" Today. Nothing Electrical Works. Not Even...
While Driving The Radio Started To Go On And Off Every Few Seconds. Later Dash Lights That Only Show During Ignition Started Going On And...
Asked by
ebueno
2004
HONDA CIVIC
VIDEO
Code Read Retrieval/Clear Honda
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
2004 Honda Civic Stalling.....
My Truck Starting Bucking Today Early This Morning Near The End Of My Commute To Work And The Start Of My Commute Home It Stopped After A...
Asked by
ahmer ammar
2004
HONDA CIVIC
Stalling While Driving
I Have A 98 Honda Civic Ex. Its 4 Cyl 1.6l And When Ever It Gets Below Half A Tank Of Gas As Im Driving It Will Sometimes Stall. It Is An...
Asked by
aaaplop
1 IMAGE
1998
HONDA CIVIC
Battery Light Turned On Two Days Late The Car Shut Off...
My Battery Indicator Came On The Other Day And Then Went Off. Two Days Later The Car Shut Off While I Was Driving It. I Jiggled The Battery...
Asked by
bparsons
2 IMAGES
1998
HONDA CIVIC
2003 Civic Vtec Engine Cuts Out Above 3400 Rpms
2003 Civic Vtec Engine Cuts Out Above 3400 Rpms, All Check Engine, Seat Belt And Key Lights On Dash Stay Lit.
Asked by
hbsb2carpros
9 IMAGES
2003
HONDA CIVIC
VIEW MORE
Code Read Retrieval/Clear Scion
Topdon OBD2 Scanner Review - This thing rocks
Code Read Retrieval/Clear Chevrolet
