I think it could be something with the electronic brake force distribution
06MAXIMATN
  • 2006 NISSAN MAXIMA
  • 6 CYL
  • 156,555 MILES
I have the car listed above and I use it for a paper route and over the last three months I have had to replace the rear pads 3 times or once a month. I don't understand why I have never had a problem like this before. What could cause this? I have tested to see if the calipers were sticking and there not they still spin just fine and that was the answer to my question when I asked before. I would like to know what else to try I think it could be something with the electronic brake force distribution system but I don't know anything about those systems. Any suggestions on where to begin?
Friday, July 29th, 2011 AT 12:49 AM
  • 108,300 POSTS
Replacing the brake pads and rotors isn't too big of a job. Usually, you can expect them to last around 25,000 miles, but that is based on driving habits.
First, here is a link that shows how to replace brakes and rotors in general. You can use it as a guide.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Here are the directions specific to your vehicle. The attached pics correlate with the directions.
____________________________________
2006 Nissan-Datsun Maxima V6-3.5L (VQ35DE)
Front
Vehicle Brakes and Traction Control Disc Brake System Brake Pad Service and Repair Procedures Front
FRONT
pic 1
Removal and Installation of Brake Pad
REMOVAL
1. Remove wheel and tire using power tool.
2. Remove lower sliding pin bolt.
pic 2
3. Hang the cylinder body with a wire and remove the pads, pad retainers, and shims from the torque member.
CAUTION: When removing the pad retainer from the torque member, lift the pad retainer in the direction shown by the arrow, so as not to deform it.
INSTALLATION
1. Apply Molykote AS880N grease to the rear of the pad and to both sides of the shim, and attach the inner shim and shim cover to the inner pad and the outer shim to the outer pad.
2. Attach the pad retainer and pad to the torque member.
pic 3
CAUTION: When attaching the pad retainer, attach it firmly so that it does not float up higher than the torque member, as shown.
3. Push the piston in so that the pad is firmly attached and attach the cylinder body to the torque member.
NOTE: Using a disc brake piston tool (commercial service tool), makes it easier to push in the piston.
CAUTION: By pushing in the piston, the brake fluid returns to the master cylinder reservoir tank. Watch the level of the surface of the reservoir tank.
4. Install the sliding pin bolt and tighten to specification. Refer to BR-23, Component.
5. Check brake for drag.
6. Install wheel and tire.
CAUTION: Burnish the brake contact surfaces when refinishing or replacing brake rotors, after replacing pads or linings, or if a soft pedal occurs at very low mileage.
_____________________________________________________
Vehicle Brakes and Traction Control Disc Brake System Brake Rotor/Disc Service and Repair Procedures Front Removal and Installation
REMOVAL AND INSTALLATION
Removal and Installation of Caliper Assembly and Disc Rotor
pic 4
REMOVAL
2. Drain brake fluid.
3. Remove union bolt if necessary, and torque member bolts using power tool, then remove caliper assembly.
4. Remove disc rotor.
- Prior to removing disc rotor, make alignment mark using a marker between the hub and disc rotor, if reusing disc rotor.
INSTALLATION
CAUTION:
- Refill with new brake fluid.
- Never reuse drained brake fluid.
1. Install disc rotor.
- Align marks made during removal on the hub and disc rotor, if reusing disc rotor.
pic 5
2. Install caliper assembly to the vehicle, and tighten torque member bolts to specification. Refer to BR-23, "Component".
CAUTION: When attaching the caliper assembly to the vehicle, wipe any oil off the knuckle spindle washers and caliper assembly attachment surfaces.
pic 6
3. Install brake hose to the caliper assembly, and tighten union bolt to specification. Refer to BR-23, "Component".
CAUTION:
- Do not reuse the copper washer for union bolts.
- Attach the brake hose to the protrusion on the caliper assembly attachment part.
4. Refill reservoir with new brake fluid and bleed air.
5. Install wheel and tire.
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Thursday, February 11th, 2021 AT 5:32 PM
SWALL
  • 2005 NISSAN MAXIMA
  • 6 CYL
  • 166,788 MILES
I have the car listed above SE model. I am replacing the brake pads and rotors on the front and rear I need to know what tools I need to do the job and I need help with directions on how to do them would be extremely helpful.
Monday, February 15th, 2021 AT 9:37 AM (Merged)
I have attached the process out of the manual and attached a couple guides here that will help with this. Let me know if you still need some more info and I will see what we can find. Thanks
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
BILLJANET
  • 6 CYL
  • FWD
  • 54,000 MILES
Front wheels wobble when brakes are applied at higher speeds. Low speeds seem to be okay. Front and rear brake shoes still have life left on them.
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested about front brake pad replacement. First, here is a tutorial to view on the subject:
With this wobble issue you mentioned it could actually be something other than your front rotors warped which could cause this. It is also possible it could be out of balance tires, a front end alignment needed, or front wheel bearings causing this condition. I've attached picture steps below that you requested in regards to replacing the front pads and rotors on your car. Hope this helps and thanks for using 2CarPros.
BADSADE
  • 2004 NISSAN MAXIMA
2004 Nissan Maxima
I was driving when I heard a loud pop sound. It has been two weeks since I got my brake pads replaced and my rotors were truned. But my prob is that there is like a piece of metal showing like a clip or some type what does that mean. It wasnt like that before I got my brakes pads replaced.
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_brakeclip_1.jpg
Does it look something like these pieces. If it is, your brake pads re not seated right on the bracket. You have to re-do/re-seat the brake pads on that side.
2CP-ARCHIVES
  • 4,540 POSTS
  • 2002 NISSAN MAXIMA
  • 145,000 MILES
Hi- I recently got new front rotors and pads plue rear pads and my car still shakes when I brake. What could it be?
CARADIODOC
  • 33,752 POSTS
What do you mean by "recently"? If new rotors were put on about three months before the pulsation started they are likely the rotors and have "aged" on the car. We let cast iron parts age 90 days before their final machining. Have the new rotors machined lightly and they will be fine. If the problem started right away when new rotors were installed, most commonly one is warped, but you also have to check for debris like rust and scale stuck between the rotor and hub. That often gets overlooked during normal brake service.
CMDRDATATX
  • 54 POSTS
  • 6 CYL
  • FWD
  • 130,000 MILES
Recently my car started to have a grinding noise (I'm pretty certain it comes from the front drive train, and the noise is very similar to worn pads and disk grinding contact). I took the wheel off, then the calipers off thinking it needs a new set of pads, but they still look rather new (almost as thick as the new set I just bought). So I am wondering if my front wheel bearing is about to go? In the past (on a different car) I associate this with worn brake pads when the screechers were installed incorrectly, thus not giving that high pitched noise. And from my experience, bearing noise usually manifested itself when going slowly and NOT while braking. What do you think is the cause of this noise?
AUTOZONEBRAKESEXPERT
  • 47 POSTS
If you hear grinding sounds when you apply the brakes:
* The most common cause for this condition is when the lining has worn past its service limit and the metal plate is contacting the rotor.
* Some drivers may experience a grinding noise only when the pedal is slightly applied and the vehicle is moving very slow (such as slightly releasing the pedal from a stop position). This operation is normal.
If your brakes squeal when you don’t have your foot on the pedal:
* It is possible the wear indicator is contacting the rotor because the linings are too thin. It could be time to change your brakes.
* Caliper slide pins that are not properly lubricated may bind causing brake drag. Also, corroded brake hardware and/or bracket will cause brake drag as well.
CHANCELYN77
  • 2001 NISSAN MAXIMA
2001 Nissan Maxima
How do I change the brake pads?
Monday, February 15th, 2021 AT 9:38 AM (Merged)
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_01maximabrake_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_01maximacaliper_1.jpg
CAL4591
  • 2000 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 90,000 MILES
I can't budge the caliper holder bolts to get the rotors off
MASTERTECHTIM
  • 4,749 POSTS
If the head is not deystroyed you can use a impact screwdriver. If they are stripped you can use a whiz wheel cutter and cut a slot in the bolt then use a regular screwdriver to remove it. Also you can use a torch.
JONTOG13
  • 1998 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 155,000 MILES
Hi, my front brake pads are about 30k miles old. Most of those miles are highway and I am easy on my brakes. When do they need to be replaced?
Thanks!
BLUELIGHTNIN6
  • 16,542 POSTS
There is no certain interval at which to replace the brakes. However, they should be inspected every 7,000 miles recommended by the dealer as the braking system is a necessity for a vehicle to be driven safely.
Thanks for using 2CarPros. Com!
CESD
  • 1990 NISSAN MAXIMA
  • 160,000 MILES
I don't know how to figure out what exact type of break pads and rotors I need. I checked my owners manual hoping it would have the make model of those but it did not. How do I know what exactly I need to purchase and where do I go to buy? I was thinking Fortins maybe
Monday, February 15th, 2021 AT 9:39 AM (Merged)
CARADIODOC
  • 33,752 POSTS
You wont find that kind of information in an owner's manual. Owner's manuals tell you how to operate the car, not how to repair it.
Any auto parts store will have the brake pads for your car or they can order them and have them in a day or two. Sometimes there's multiple applications based on optional equipment like heavy duty vs. Standard brakes. They'll ask you relevant information like engine size, two or four-door, etc.
The most important factor with brake linings is the front and rear were matched at the factory to provide a specific "coefficient of friction", and that must be maintained for even braking front-to-rear. Aftermarket suppliers of brake pads and shoes adhere to those same specifications. Sometimes a lining may present more friction than the originals, so they will be narrower or shorter, but they'll still fit and install the same way.
There's a whole bunch of things professionals do to prevent causing brake noises and pulsations, and there's a lot of things do-it-yourselfers can do to causes those things. I can run through the list if you want me to.
JCHAMPAGNE
  • NISSAN MAXIMA
I have a 2000 Maxima SE, I am replacing the rear brake pads. One side was no problem, but on the other side I cannot get the piston back into place to be able to fit the new pads. I probably went too long before replacing. Is there any trick to this?
