Engine not starting
JOHNMARKO1977
  • 2009 PONTIAC G6
  • 3.6L
  • V6
  • 75,000 MILES
What would be the location of the fuel injector on my car? The car battery is fully charged and there is gas in my 2009 Pontiac g6 gxp sedan. All inside and outside lights operate normally. With exception to my low beams due to light bulbs.
Sunday, December 1st, 2013 AT 8:24 AM
SATURNTECH9
  • 30,870 POSTS
Really doubt all your fuel injectors failed.does it crank and not start, is your security light on solid or flashing with the key in the run position?
This guide will help us fix it
Sunday, December 1st, 2013 AT 8:37 AM
RONDH
  • 2008 PONTIAC G6
  • 3.5L
  • 6 CYL
  • FWD
  • 76,445 MILES
An error message pops up on the odometer after the mileage pops up. I tried to turn the key and it does absolutely nothing it makes no noise I think it has something to do with the security system or something can you please help me
Tuesday, May 26th, 2020 AT 1:57 PM (Merged)
PACO8224
  • 117 POSTS
Make sure you get your battery tested first this guide will help
RONDH
I tried to jump it. Still did nothing. All the lights are really bright. If the battery was completely shot wouldn't it still take a jump and start? Could it be the starter? It doesn't even click or do anything when you try to start it even with a jump.
PACO8224
  • 117 POSTS
I've seen a few of this before and even with a jump it will not start vehicle. If your starter were to be bad the error code would not, be displaying. Make sure you check your grounds as Well. Go get battery tested you will be surprise on the g6
RONDH
Is not the battery. Any other ideas of what it could be?
PACO8224
  • 117 POSTS
Have you checked if you getting power and ground to starter
CINCYJOE7
  • 2008 PONTIAC G6
  • 4 CYL
  • FWD
  • 99,000 MILES
When I turn the key I hear the clicking, but wont turn over. Sounds like the clicking is the starter trying to start. All electrical things like the lights, radio, etc work okay. It tries to start, but just does not turn on.
RONDH
No. Would the starter just stop working with no symptoms?
HMAC300
  • 48,601 POSTS
Try hitting starter body with hammer while an assistant tries to start car if it does the starter is probably bad. Auto parts can check it.
PACO8224
  • 117 POSTS
Yes it would
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
The clicking could be the battery low on voltage, do a load check to test it, here is a guide that will help.
https://www.2carpros.com/articles/how-to-check-a-car-battery
Let us know what you find so it will help others.
Best, Ken
HMAC300
  • 48,601 POSTS
If it doesn't say expert b y their name the answer is not from 2 car pros. Try resetting your security system if no manual look online.
TONY WEST
  • 2008 PONTIAC G6
  • 3.5L
  • V6
  • 99,000 MILES
My car won't start it just shut off and wouldn't start back up. The lights and everything works inside but it doesn't say anything when you try to crank it. The screen reads error, and it wouldn't read the diagnostic or OH check. Could you please tell me what's wrong with it.
HMAC300
  • 48,601 POSTS
TONY WEST
Is that the same for a 2008 Pontiac G6
TONY WEST
Would that be the same for a 2008 Pontiac Grand 3.5l
TONY WEST
I tried resetting the alarm but the theft monitor light doesn't stay on so is there anything else you can tell me?
HMAC300
  • 48,601 POSTS
Check the 2 items in pic if both are ok then you'll need to get it scanned for codes as it may be a body module problem. Switch the relay with a like relay to test it.
