MAP sensor location
KATHIE
  • 2005 FORD ESCAPE
  • 12,770 MILES
Where is the MAP sensor located? I had it diagnosed and they said it was the MAP sensor.
Friday, September 23rd, 2011 AT 7:01 PM
PROMECHANIC
  • 536 POSTS
Here are the locations for both a 2.3L engine or a 3.0L. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
Friday, September 23rd, 2011 AT 7:37 PM
BSHOT11
  • 2005 FORD ESCAPE
  • 2.3L
  • 4 CYL
  • 155,000 MILES
Pulled a P0106 code, I was told the map sensor needs to be replaced. I have a four cylinder 2.3L and I am not entirely sure where the MAP sensor is or what it looks like. I am trying to purchase a replacement one. Thanks.
Thursday, August 30th, 2018 AT 11:56 AM (Merged)
ZALDYMAN
  • 5 POSTS
  • 2007 FORD ESCAPE
  • 2.3L
  • 4 CYL
  • 36 MILES
I had my vehicle scanned due to idling problem and the result is Manifold Absolute Pressure/BARO Sensor High. Please help in locating the MAP Sensor.
JOHNNYT73
  • 924 POSTS
This car has a MAP and MAF sensors. Here is a guide to help you with the MAF and a diagrams below that shows the MAP location:
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
USER NOTES: If this is a 2.3 then the oil filter is in the wrong place, I have a 2008 hybrid 2.3, I have changed the oil filter several times, any that filter is on the front of the motor, not the back as displayed here
ZALDYMAN
  • 5 POSTS
Noted with thanks. Do you know the Ford MAP Sensor part number and pictures or drawing of this MAP Sensor?
WRENCHTECH
  • 20,761 POSTS
OEM part number: 4S4Z9F479AA. However, there are plenty of aftermarkets out there probably cheaper.
ZALDYMAN
  • 5 POSTS
Thanks guys for the help. Appreciate it.
ZALDYMAN
  • 5 POSTS
Already replaced the MAP sensor with surplus MAP sensor and no more error code in the scanner. However, the idling problem still persist. What do you think is the problem? Erratic idling, rough idle when car is stationary. Car strong vibration at idle and sound skipping.
KIM SMITH SHANNON
  • 2001 FORD ESCAPE
  • 3.0L
  • V6
  • 100,000 MILES
Need location of the sensor.
WRENCHTECH
  • 20,761 POSTS
If you have an EGR valve check to see if it may be stuck open with a chunk of carbon or something. Make sure it is not being activated at idle.
Check your fuel pressure for leak down after shut off for possible injector leak.
This guide can help.
https://www.2carpros.com/articles/engine-vibration-at-idle
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,191 POSTS
Your car does not have a MAP sensor it has a MAF sensor which is located near the air filter housing.
Here is a a couple of guides and some diagrams (below) to help you locate it:
https://www.2carpros.com/articles/how-a-mass-air-flow-sensor-works-maf
and
Cheers, Ken
ZALDYMAN
  • 5 POSTS
Noted with thanks. We will try it out and keep you posted. By the way is there a idle air control valve sensor on Ford Escape 2007 XLS 2.3L gas?
WRENCHTECH
  • 20,761 POSTS
Yes, it does.
http://i1198.photobucket.com/albums/aa448/Wrenchtech/131012247.jpg.gif
PD8946
  • 0 POST
Thanks for the guide. My car had low compression in number two cylinder so I had to do a valve job cost me $1,400.00.
SLCHUBB
  • 2006 FORD ESCAPE
  • 3.0L
  • 6 CYL
  • AWD
  • 152,000 MILES
CARADIODOC
  • 34,344 POSTS
It is plugged into the intake manifold. There is an emissions sticker under the hood that shows the vacuum hose routing. The MAP sensor should be shown on that.
