Crank not start, fuel pump relay does not engage?
CARADIODOC
  • 34,468 POSTS
I didn't look closely at these diagrams, but I can add a couple of comments of value. First, it was common on Chrysler Engine Computers to find four ground wires. One was called a "power ground", meaning it was used for high power circuits like ignition coils, injectors, solenoids, and relays. The second was a "sensor ground". Then, for redundancy, there was a second one for each of those, thus, four ground wires in total.
The reason for separate grounds is there is always a little resistance in a wire. When current flows through that resistance, it causes a small voltage to be "dropped" across it. In the high-power ground circuit, that voltage drop could be in the order of a few hundredths of a volt, which is completely meaningless to how well those systems operate. The problem is if that ground wire was to be shared with the sensor grounds, a few hundredths of a volt means a lot to the computer. In the case of the very sensitive MAP sensor, for example, the voltage drop would affect engine performance due to the computer seeing the wrong signal voltage. In addition, as ignition coils and injectors turn off, they create voltage spikes from the collapsing magnetic fields in their coils. Those voltage spikes also show up on the power ground wires. If there was just the one shared ground wire, those voltage fluctuations would again show up in the sensor signals.
The second problem with testing ground wires is trying to perform a continuity test is pointless. All you need is one tiny strand of wire still intact for the ohm meter to show the entire wire is good. In fact, that would not allow enough current to flow without causing its own severe voltage drop. Think of a garden hose that's 99 percent blocked by a kink. As long as the nozzle is turned off, you would find normal pressure there, but open the nozzle and expect water, (current) to flow, and all it would do is drip on your shoes. Just like with the garden hose, to be accurate, you have to test the circuit while it's in operation. That means instead of the continuity test, measure the voltage drop on each ground wire. To say that in normal terms, measure the voltages on terminals 10, 43, and 50 while the engine is running.
I've never actually done this test except for training purposes, so I don't know what "normal" is, but I can share that you aren't going to find a questionable amount of voltage. If a power ground wire is open, as in corroded off at the terminal, you'll have a no-crank or a crank / no-start condition since the ignition coils and injectors can't fire. You'll find very high voltage on that power ground wire, as in probably 2 volts or more.
Most sensors are fed with a carefully regulated 5.0 volts. If their ground wires are open, that will put close to that 5.0 volts onto the signal wires. That will set all kinds of "signal voltage high" fault codes related to each of those sensors. When you get that code for just one sensor, suspect a break inside the sensor itself, a spread connector terminal, or a break in the wire from that sensor to where it splices together with the other sensors' ground wires. When you get those fault codes for multiple sensors, that's when to look at the sensor ground wire for the computer.
As a side note, power grounds go through the computer because that's where it turns those circuits on and off. Sensor grounds go through the computer so they can be monitored for proper operation. Because there is that monitoring circuitry in the computer, a small amount of voltage is dropped across it. To see that, go to the ground terminal for the throttle position sensor or the MAP sensor, and you'll find very close to 0.20 volts, not 0.00 volts like you might expect to see.
All of these voltages are part of the training story. In actual practice, we never waste our customers' time, (money), with these tests during the diagnosis. We might perform one or two to verify what we found, but there's too many other variables to make these tests worthwhile. A perfect example is the stray voltage that can be "induced" electromagnetically into your meter's leads. You may even find when your meter is set to its lowest voltage scale, it will show a small voltage just by sitting near the running engine without its leads even touching anything.
For the computer's 12-volt power wires, I've seen up to four of them. One is on all the time to keep the memory alive. That keeps any stored fault codes in memory and it retains learned values like individual sensor personalities and learned fuel trim data. The second will be a switched power wire that turns the computer on from the ignition switch. I briefly mentioned the automatic shutdown, (ASD) relay previously. The computer turns that on for just one second when the ignition switch is turned to "run", then again anytime it sees engine rotation, (cranking or running). When it's turned on, it sends 12 volts to the ignition coil(s), injectors, alternator field, oxygen sensor heaters, and to the fuel pump or pump relay. One additional place it sends 12 volts is back to the Engine Computer so it can verify that ASD relay did, in fact, turn on. That's the third 12-volt power wire and it is the one that powers the alternator's voltage regulator circuit and is where system voltage is monitored. That regulator is inside the Engine Computer. Chrysler developed the world's first electronic voltage regulator for 1970 models. One of its features was it included temperature compensation to boost battery charging voltage in cold weather. Today, with the regulator built into the computer, it can make fine tuning adjustments for all the variables the computer knows.
There's one more thing I want to point out that is a major source of confusion. That is the terminology used for some of these circuits. The biggest one that comes to mind is terminal # 6 in connector C1. It's listed as, "automatic shutdown relay output". That implies the ASD relay turns on, then its output 12 volts comes out on terminal #6. That's how most of us would read it. In fact, what it means is the ASD relay turns on, then, along with all the places I said it sends 12 volts to, this relay's "output" goes TO terminal # 6. The output of the relay is an input to the computer on terminal # 6. That's what happens when the engineers who design the circuits aren't the same people who write the service manuals.
Wednesday, May 28th, 2025 AT 12:23 PM
CHRYSLER 01
  • 68 POSTS
Okay, so telling me to check for 12 voltage on a ground wire, like put my test light or voltameter.
Wednesday, May 28th, 2025 AT 12:39 PM
CHRYSLER 01
  • 68 POSTS
Okay, you said the ASD relay power the alternator voltage regulator.
Wednesday, May 28th, 2025 AT 12:44 PM
CHRYSLER 01
  • 68 POSTS
You seem to know your stuff very well.
CARADIODOC
  • 34,468 POSTS
Test light won't do it. Those need a good 6 to 8 volts before they start to light up. You need a digital voltmeter, ideally with the lowest voltage range of less than 2.0 volts. You're expecting to find just a few hundredths of a volt. Put the meter's negative probe on a clean, rust and paint-free point on the body sheet metal or screw head, and the positive probe right on the computer's terminal by back-probing alongside the wire, through any rubber weather seal. You can go all the way back to the battery too, if you want to, and put the meter's negative probe on the battery's negative post. That will include more connections in the test, but you should still ideally, find close to 0.00 volts on the ground wires.
Remember, if you find any really low voltage with this test, that wire is okay. If you have a wire with a bad ground, say it's corroded off the terminal or the terminal is bolted to a badly rusted area of sheet metal, you're going to find some high voltage that is obviously too high. What I didn't do a good job of saying is you're not going to have to question whether a voltage you find is good or bad. If it's bad, it will be obvious.
Wednesday, May 28th, 2025 AT 12:50 PM
CARADIODOC
  • 34,468 POSTS
"Ok you said the ASD relay power the alternator voltage regulator"
To be clear, the alternator and regulator have nothing to do with the problem you're chasing. I just included them in my story to show all the places you need to have 12 volts at the Engine Computer. Unless I overlooked one, I only saw three 12-volt feeds that you can check.
Wednesday, May 28th, 2025 AT 12:53 PM
CARADIODOC
  • 34,468 POSTS
I'll be back tomorrow to see how you're doing, but expect to see me later in the day or early evening.
Wednesday, May 28th, 2025 AT 1:00 PM
CHRYSLER 01
  • 68 POSTS
Okay, so send my digital multimeter to lowest setting and measure volts on ground side #10 / #50 / #43.
Wednesday, May 28th, 2025 AT 1:03 PM
CHRYSLER 01
  • 68 POSTS
This is the email I got from all computer when I told to send me another PCM.
With these old SBEC Modules it is very important that the ECU makes a solid and secure connection to the harness. At times, it does require some force to get the locking tabs on the connector to lock in place. Please check this, and perhaps having an assistance push the module in while you try to start. If too much force is required but the vehicle does start, that means some of the connector terminals inside the harness have been pushed back and will need to be reset.
Wednesday, May 28th, 2025 AT 1:23 PM
CHRYSLER 01
  • 68 POSTS
They sold a program ECM at first the car was cranking, and starting and running 10 seconds now the problem came back no start.
Wednesday, May 28th, 2025 AT 1:24 PM
CARADIODOC
  • 34,468 POSTS
Pushing on the plugs is a common thing to look for, but they're really pretty good as far as connections. I always look for pushed out pins but I've never found one yet. The only bent over terminal I ever ran into is one that I caused through carelessness.
At this point, if the starter cranks okay but the engine doesn't run, you're going to need a scanner to see what the computer is seeing for the crankshaft position sensor and the camshaft position sensor. I described earlier how they should switch from "No" to "Present" or something similar when you start cranking the engine. If one of those doesn't switch to "Present", that is the circuit we need to look at closer.
Thursday, May 29th, 2025 AT 8:17 PM
CHRYSLER 01
  • 68 POSTS
I'm taking a break from this car. I'll let you know when I get back to it.
Tuesday, June 24th, 2025 AT 5:11 PM
CARADIODOC
  • 34,468 POSTS
Dandy. I'm here almost every day, usually late afternoon to late evening. I'll wait for your next update.
I do have one more comment while I think of it. This model was known for having a starting problem due to a broken solder connection on the plug on the back of the instrument cluster. I've read about it multiple times here, but I actually ran into it just once, on a relative's van. That was a few years ago, and I can't remember if it was a crank / no-start, or if it caused a no-crank condition. Regardless, it did not cause stalling after the engine was running. Banging on the dash was his solution for a few months until that no longer worked. Once the cluster is removed and disassembled, the broken solder joint was easy to see and resolder. The affected pin was in one of the corners of the plug.
Tuesday, June 24th, 2025 AT 5:24 PM
