HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
1999 Ford Taurus engine
MOONANN
MEMBER
1999 FORD TAURUS
6 CYL
2WD
AUTOMATIC
178,000 MILES
My slight sake and sometimes dies after a while when idle in stop light.
Sunday, January 20th, 2008 AT 7:53 PM
BMRFIXIT
MECHANIC
Check for tune up
check vacuum leaks
check/clean idle air valve
Sunday, January 20th, 2008 AT 8:37 PM
Please
login
or
register
to post a reply.
Related Engine Content
99 Taurus Engine Into A '98 Taurus
Hi I Have A Wrecked '99 Taurus (engine Area Unaffected) And A '98 Taurus With A Thrown Rod. My Question Is: Is It Possible And Advisable...
Asked by
ragnarok628
1999
FORD TAURUS
VIDEO
Turn Over an Engine by Hand | Bar Over
Instructional repair video
GUIDE
Code Reading
A check engine light, also known as a service engine light, or a MIL (malfunction indicator light) is designed to let you know there is a problem with one of your car's...
1999 Ford Taurus Where Are Relay's For The Low And...
Where Are Relay's For The Low And High Cooling Fan And Im Also Looking For The Location Of The The Fuse For The Coooling Fan. From What I...
Asked by
tisenhour
1 ANSWER
1999
FORD TAURUS
The Engine Was Not Heating Properly
I Have Replaced The Thermostat And Antifreeze/coolant What Else Could It Be? I Have Also By Recommendation Of A Friend Unhooked Both Cooling...
Asked by
Daemien
1 IMAGE
1996
FORD TAURUS
1997 Ford Taurus Engine Performance
1997 Ford Taurus Two Wheel Drive Automatic 200000 Miles Original Question Was Where Is Cmp Located And Do I Just Disconnect The Battery...
Asked by
Brian Dunlap
1 ANSWER
1997
FORD TAURUS
1998 Ford Taurus Racing Engine
Engine Mechanical Problem 1998 Ford Taurus Automatic Hi, When I Put My Car Into Park And Let It Sit For A While, Then Engine...
Asked by
elizmason
1998
FORD TAURUS
VIEW MORE
P1000 Trouble
Hybrid Engine
Hybrid Car
