1999 Ford Taurus Where are relay's for the low and high Coo
TISENHOUR
  • 1999 FORD TAURUS
  • 6 CYL
  • FWD
  • 226,758 MILES
Where are relay's for the low and high Cooling Fan and Im also looking for the location of the the fuse for the coooling fan. From what I can see there are two relays for the cooling fan one in the "relay center box" (High) and one in the "fuse/relay box" (Low). Are there really two? One of, y diagrams shows that in slot 9 (40A) there is a place for the high speed and low speed fan and also there is a location in number 31 for just the low speed cooling fan so I am confused. So does that mean there is also a high speed somewhere else?However I though there was only one box under the hood for this. Also atrying to find the location of the fuse box so I can also replace the fuse! Any help would be greatly appreciated!
Tuesday, August 17th, 2010 AT 8:29 AM
WRENCHTECH
  • 20,761 POSTS
Your just duplicating questions now. I have already given you the fuse box layout identifying the fuse and the low speed relay.
The diagram shows the high speed relay outside of the relay box but doesn't identify the exact location. It's probably mounted independently in the engine compartment.
https://www.2carpros.com/forum/automotive_pictures/561653_Cooling_fans_99_Taurus_1.jpg
Tuesday, August 17th, 2010 AT 10:05 AM
