1998 Ford F-150 Check Engine Light
CHOBEEBOI25
  • 1998 FORD F-150
  • V8
  • 4WD
  • 118,000 MILES
My check engine light does not come on at all. What would cause this and how do I fix it so that it does come on like it is supposed to so that I will know if there is ever a problem.
Do you
have the same problem?
Sunday, February 24th, 2008 AT 10:49 AM
BMRFIXIT
  • EXPERT
The bulb it self may be at fault
or some one remove it,
before you took owner ship
for what ever reason
check fuses and if all ok
remove the cluster and check the bulb
have it scanned
good luck
Sunday, February 24th, 2008 AT 10:56 AM
CHOBEEBOI25
How do I check the bulb to see if it is there or if it is not and if it is blown?
Thanks
Sunday, February 24th, 2008 AT 11:07 AM
CHOBEEBOI25
How do I check to see if the bulb has been removed or if it is blown?
Thanks
Sunday, February 24th, 2008 AT 11:08 AM
BMRFIXIT
  • EXPERT
The fuses can be check using a test light
as for the bulb
key on engine off
if you don t have the check light on
then the only way to check it
is by removing the cluster only
with out a scanner
if you have a scanner you may command the light on off
Sunday, February 24th, 2008 AT 11:21 AM
CHOBEEBOI25
I have checked all the fuses and they are all ok. How do I remove the cluster to get to the bulb?
Thanks
Sunday, February 24th, 2008 AT 11:39 AM
BMRFIXIT
  • EXPERT
Up around the base of the steering pull the plastic cover and remove screws
also the cluster trim find 3 screws holding it up remove
remove plastic
remove the cluster hold down screws remove it
use common sense when looking and removing screws and cluster
good luck
Sunday, February 24th, 2008 AT 11:48 AM
