1992 Ford F-150
TISHPPRD
  • 1992 FORD F-150
  • V8
  • 4WD
  • 71,111 MILES
I got a 1992 f-150 we replaced the stock 302 motor which had a 154 firing order with a H.O 302 motor that has a 137 firing order now the truck runs rough idles real bad runs very rich and top speed is about 60 mph at 2800 rpm ive replace all the sensors on the motor can you please help me
Do you
have the same problem?
Tuesday, February 3rd, 2009 AT 12:16 PM
JACK42
You may need to use a computer for a HO engine to make it run right. Is the chek engine light on? If so what codes is it throwing?
Wednesday, February 4th, 2009 AT 7:53 AM
TISHPPRD
Thanks The code i've got are 41 25 23 33 21 I did put on the truck 302 induction system so all my wires an cable would line back up also the smog pump has been removed and this motor has not got mass air system on it thyank you Tim sheppard Williamsburg Va
Wednesday, February 4th, 2009 AT 10:41 AM
JACK42
What computer are you using.?
Wednesday, February 4th, 2009 AT 10:47 AM
TISHPPRD
Mustang computer
Wednesday, February 4th, 2009 AT 10:52 AM
JACK42
So this isnt just an engine swap, you took the entire harness and comp out of a mustang and put it in a truck?
Double check all grounds. Th ecodes may not match up to your truck. What year mustang?
Wednesday, February 4th, 2009 AT 11:14 AM
TISHPPRD
No I just swapped motors pulled computer put truck induction on mustang motor and used truck wire harness 1988 motor
Wednesday, February 4th, 2009 AT 11:26 AM
TISHPPRD
There is'nt any chance you could call 757 253 1429 is it?
Updated 2-5-09
Thanks for the help the codes i've got are 41 25 23 33 21 iv'e also removed the smog pump an put the truck induction system on the mustang 5.0 so all the wires and cables lineds up
Wednesday, February 4th, 2009 AT 11:28 AM
JACK42
Have you tried the trucks original computer?
Wednesday, February 4th, 2009 AT 12:29 PM
TISHPPRD
Wednesday, February 4th, 2009 AT 3:40 PM
JACK42
Did it act exactly the same? I just want to be sure, this comp is from a 92 truck, if so the codes are defined as follows
21- coolant sensor out of range
23-TPS out of range
25-Knock not sensed during dynamic response test
33- EGR not opening
41- No HEGO (o2 sensor) switching.
You should double check all grounds to be sure, most of the engine sensors share grounds, that may be why the TPS, Knock Sensor, EGR and Coolant sensor and o2 are having a problem
Wednesday, February 4th, 2009 AT 4:00 PM
TISHPPRD
Yes iv'e checked all gounds an replaced all sensors I was told that the comp has gone in limp mode and maybe the h. O motor comp won't work right because its out of a car not a truck tat maybe I should get a comp from a 5.8 which has the same firing order as the 5.0 HO motor Get it from the same year 1992 too tell you the truth i've about had with this truck ive spend around 450.00 on sensers and other elec parts tring to get it right an nothing seems to be working
Wednesday, February 4th, 2009 AT 6:51 PM
JACK42
I hear ya, for some reason Fords really dont like when you swap stuff around. Check theTPS and the Coolant sensor to see if they both have good ground and 1 of the wires on each sensor should be a 5 volt reference to the computer. Use a meter to test the continuity to ground on the wires. The ca/ truck thing may be accurate info as well, to verify this you would need the schematics for both computer plugs to compare them
Wednesday, February 4th, 2009 AT 8:56 PM
Recommended Guides
