Fuel pump getting no power.
SHANEPAYE
It has injector pulse even after its warm, what about ignition module.?
Tuesday, December 19th, 2017 AT 6:38 PM (Merged)
CJ MEDEVAC
  • EXPERT
I NEED YOUR ENGINE SIZE
I "MIGHT" BE ABLE TO GET THE WIRING DIAGRAM(S) FOR THE FUEL SYSTEM
MANY TIMES A VEHICLE OF THAT AGE DOES NOT SHOW UP IN MITCHELL I
YOURS DOES---I WANNA INSURE I GET YOU THE CORRECT DIAGRAM, AND NOT CONFUSE YOU WITH 4 OR 5 THAT DOES NOT PERTAIN TO YOUR TRUCK
IMMA JEEP CJ KINDA GUY, I HAVE EXPERIENCE WITH MY DAD'S '86 THUNDERBIRD----IT HAD 2 FUEL RELAYS
MITCHELL USUALLY HAS LOCATIONS OF COMPONENTS LABELED BESIDE THE SYMBOLS ON THE DIAGRAM. EZ TO READ AND TO FIND STUFF
EVEN IF THERE IS NOT A 2ND RELAY, YOU WILL EZily SEE EVERY ELECTRICAL COMPONENT IN THE SYSTEM, AND MIGHT COME UP WITH "WHAT ELSE" COULD BE CAUSING THE VOLTAGE TO CONSTANTLY FEED THE PUMP
I WAS ON-LINE WHEN YOU RESPONDED, I MAY STILL BE ON IF YOU RESPOND SOONRIGHT NOW, MITCHELL I IS STILL PULLED UP WITH YOUR INITIAL INFO
YOUR TURN
THE MEDIC
SHANEPAYE
It has injector pulse even after its warm, what about ignition module.? I put a new plugs cap rotor and wires on today, it starts a lot faster after its warm but still takes 6-10 cranks before it goes, and sometimes it doesn't start unless I turn pumps off
DIXON1
Sorry cant believe I left that out 302 efi
MERLIN2021
  • EXPERT
Remove the TFI module and bring it to the parts store, they can test it, check the sprk when it wont start, is it a good strong blur spark? Or weak orange yellow?
  • EXPERT
The pcm grounds the fuel pump relay. If you remove the relay, do the pumps turn off?
SHANEPAYE
Its a pretty weak spark, and I just replaces the coil and it helped it a little but still not right
CJ MEDEVAC
  • EXPERT
I JUST GOT BACK IN FROM A FUNERAL KINDA CHOW DEAL THINGEE FOR A FRIEND OF MY FAMILY
I'M ABOUT TO SEARCH FOR YOUR INFO
THE SITE OUTTA "PROMPT" ALL THAT KINDA INFO FROM YOU WHEN YOUR QUESTION IS SUBMITTED. SO FAR, THEY HAVEN'T INCORPORATED IT IN. THINGS LIKE "LX"--"LTD"--"SE" SOMETIMES MAKES A DIFFERENCE WHEN YOU LOOK FOR INFO
I'LL BE BACK SOON AS I GET IT
THE MEDIC
JAMES W.
I would follow Merlin2021's advise and have the TFI module tested. They have been known to break down under heat since the day they came out.
CJ MEDEVAC
  • EXPERT
2ND ATTEMPT TO SEND THIS
1-4) ENGINE COMPARTMENT
5) ENGINE COMPARTMENT AND UNDER DASH
6) UNDER DASH AND INSTRUMENTS
7) REAR COMPARTMENT AND ACCESSORIES
I'M SURE THESE WILL NOT BE CLEAR ON THIS SITE---I WILL SEND YOU A PRIVATE MESSAGE TO PRIVATELY OBTAIN YOUR EMAIL ADDRESSTHEY ARE VERY CLEAR IN MY DOWNLOADS
TO GET TO MESSAGES
AT TOP OF THIS PAGE CLICK YOUR USERNAME> PAGE COMES UP> LOOK LEFT---YOU WILL SEE MESSAGES. YOUR INFO IS NOT BROADCAST WORLD WIDE IN THERE
I CANNOT SEND ALL IN ONE SHOT ON THIS SITE (I JUST TRIED, LOST A NOVEL I WROTE YOU)---SO I WILL DO 2 POSTS
I CANNOT COPY CHARTS IN MITCHELL I---SO IF YOU NEED TO KNOW A COMPONENT LOCATION, TELL ME WHAT IT IS, I WILL SEARCH THE CHARTS AND PASS IT ON BACK TO YOU
IF YOUR TRUCK IS A KEEPER---YOU MIGHT WANNA DO LIKE I DID, WITH YOUR DIAGRAMS---MAKES IT SO EZ!
SEE JANUARY 4TH ON THIS POST---MY REPLY THAT STARTS OUT, "OK HERE'S THE DEAL"
MESSAGE SHOULD BE A MINUTE OR SO AFTER I POST THESE 2 POSTS
SHANEPAYE
I have disconnected the temperature sensor, not the one for the gauge the other one almost right next to it, it starts fine now and the check engine light came on. Does that sensor have anything to do with ignition or fuel, or is it just coincidence that it starts now?
CJ MEDEVAC
  • EXPERT
567
THE MEDIC
MERLIN2021
  • EXPERT
THATS THE ect AND ACT SIMILAR TO AN OLD CHOKE ON CARB MODELS, try replacing it, the code set because its unplugged. Computer is using an average on mixture with it unplugged.
CJ MEDEVAC
  • EXPERT
I'M S.CREWIN' IT ALL UP!
I WROTE THIS PREVIOUSLY:
THIS IS THE LINK:
http://www.2carpros.com/questions/1977-jeep-cj5-ignition-trouble
THE MEDIC
JAMES W.
That would be the coolant temp sensor. It sends a signal to the ECM telling the it how warm the engine is so it can adjust the fuel mixture. Disconnected, it "should" trip the engine light. If this turns out to be the problem, I'm going to slash my wrists. That doesn't make any sense at all. I can see affecting cold start, but not warm. Change it.
  • EXPERT
Nice job CJ
MIAMIII13
I have extra injector if u need them send me I pic of them r they coil on plug or 2 seperate oil paks
CJ MEDEVAC
  • EXPERT
THANK YOU!
IF HE HAD A JEEP CJ---I'D HAVE HIM SQUARED AWAY BY NOW!
TOO BAD THAT'S NOT THEIR NEWER DIAGRAMS
I MAY NOT KNOW HIS RIG WELL---BUT I CAN SHOVEL HIM PLENTY OF INFO
I FELT SURE HE'D BE BACK BY NOW
HOWS YOUR EVENING GOING ASEMaster6371?
THE MEDIC
SHANEPAYE
Well I thought the problem was solved when I unplugged the ect sensor but that only lasted for a week. I was doing some off-roading and all of the sudden it quit on me and wouldn't restart, I noticed that when I turn the key on the fuel pump relay was not activating. When I ground pin 6 of the test connector they come on and run fine, but not with the key. I replaced the eec for shits and giggles and still nothing. Any ideas of what would cause this, I was reading another forum and there was a lot about testing power and grounds but I do not have a manual and don't know what pins to check for power or grounds.
  • EXPERT
Not bad, pal. Just trying to help out these people.
You have a good weekend
