1998 Ford Explorer
JDUKEFAN21
  • 1998 FORD EXPLORER
  • V8
  • 4WD
  • 165,000 MILES
The car will not heat up inside the car.I was told the heat sensors needed replacing? I thought it was a thermostat any help
Do you
have the same problem?
Thursday, December 27th, 2007 AT 2:04 AM
BLACKOP555
  • EXPERT
First turn the car on and let it get to operating temperature with the heater on full and the hottest setting, then go feel the heater core hoses, if they are both hot then you may want to check your blender door in the dash.
If one is hot and the other isnt you may want to flush the heater core.
And if neither are hot change the thermostat and check the heater control valve.
Thursday, December 27th, 2007 AT 10:24 AM
Recommended Guides
