It wouldn't hurt if it's been that long, however they normally wear and gain clearance and clatter. You said it ran better for a while but now acts up, did you disconnect the battery when you did the other work? I'm wondering if maybe there is a different issue. If you did, unhook it again, let it set a few minutes and reconnect and see if it still acts up? It might still be fuel related but on the other end, the idle is controlled by the throttle body and there is a relearn procedure that it follows and then adjusts over time, however if the throttle body is dirty inside it can cause a low idle as the throttle doesn't compensate properly.
Take a look in the throttle body and see if it has any built up crud, soot. If it does clean it and see if it helps. Book says you need to pull the TB to clean it, but if you have access I generally don't, instead I use a dowel rod wrapped with a towel and spray that with cleaner and scrub out the bore.
Friday, March 27th, 2026 AT 9:48 AM
